Why BPMN Diagrams Go Wrong in Real Projects
Geschätzte Lektüre: 8 Minuten 156 Ansichten
Most BPMN diagrams fail not because of poor tools or bad intentions, but because of invisible missteps made early in the modeling process. The quietest and most damaging issue? Assuming clarity comes from familiarity instead of structure.
When teams skip foundational alignment and jump straight into tooling, they build on sand. A diagram may look complete, but its logic is ambiguous, responsibilities are blurred, and stakeholders interpret it differently. That’s not a minor flaw—it’s a systemic risk.
Over two decades of auditing BPMN models has taught me one truth: a diagram’s value isn’t measured by how many boxes and arrows it contains, but by how reliably it communicates intent across roles and boundaries.
This chapter dissects the real causes behind bad BPMN models—why they happen, what they cost, and how to stop them before they start. You’ll learn to spot the hidden traps, avoid common pitfalls, and build models that stand the test of time, audits, and automation.
Root Causes of Bad BPMN Models
Unclear Modeling Goals
Too many teams start with a blank canvas and no direction. They don’t ask: *Who is this for? What happens if it’s wrong?* Without a clear purpose, models turn into catch-all diagrams that serve no one.
Common mistake: Creating a single “as-is” diagram to capture everything—business, IT, legal, compliance—without defining scope or audience.
Best practice: Define the goal before drafting. Is it for stakeholder alignment? System automation? Audit compliance? Each goal shapes the level of detail, notation, and structure.
Mixed Audiences, Confusing Language
Modelers often write for one group but expect another to understand. A diagram full of technical jargon like “invoke,” “commit,” or “transaction roll-back” may be clear to developers but meaningless to business users.
Conversely, using vague terms like “handle request” or “process data” fails to convey actual actions. Ambiguity invites assumptions—and misinterpretations.
Real example: A bank’s “loan approval” process used “Review application” as a task. Was it credit check? Underwriting? Legal review? The modeler didn’t know—and neither did the auditor.
Lack of Basic Notation Training
Many teams assume BPMN is intuitive. It isn’t. Without training, modelers misuse symbols, misapply flows, and create unexecutable diagrams.
Consider this: one modeler used a **Message Flow** to connect two internal activities in a single pool. That’s not just wrong—it breaks the entire concept of roles and responsibility boundaries.
Even seasoned professionals often confuse **Event Sub-Processes** with **Boundary Events**, leading to unintended interruptions. These are not typos. They’re fundamental misunderstandings.
Copied from Bad Sources
Too many diagrams are not created—they are copied from outdated templates, legacy systems, or poorly written blog posts. The source is often flawed, and the copy inherits the error.
One client reused a “customer onboarding” diagram from five years ago. The process involved a “manual task” that required two people, but no one knew who. The handoff was never defined. The model was never reviewed. It stayed in production for years.
Copying bad diagrams multiplies risk. A flawed model becomes a default. And that’s how process decay begins.
Rushing into Tooling
Modern BPMN tools promise speed and automation. But they can’t compensate for poor structure or bad logic. When teams skip pre-modeling and dive straight into drawing, they end up with visually clean but semantically broken diagrams.
Tooling accelerates mistakes. A flow that loops forever may look fine in the editor—but misrepresents reality. Tools don’t verify business intent—they only check syntax.
Real case: A workflow engine rejected a BPMN file because it contained a **terminate end event** with no incoming flow. The modeler didn’t realize this meant the process could end with no trigger. The tool caught the error. The business didn’t.
How These Issues Manifest in Practice
Anecdote: The Insurance Claim That Never Ended
A claims team modeled a “claim processing” workflow. It had 27 tasks, five gateways, and a single, massive loop. The end event was a “Terminated” event with no incoming sequence flow. It was never reachable.
When the automation team deployed it, the system hung. No one noticed because the diagram looked “complete.” The root cause? No validation, no peer review, and no clarity on process boundaries.
Anecdote: The Customer Journey That Wasn’t
A retail company modeled its customer checkout as a BPMN process. But the model didn’t include the customer at all. The only actors were internal roles: “Payment Team,” “Shipping Coordinator.”
When they measured customer satisfaction, the data didn’t align with the model. Why? Because the customer’s actions—adding items, choosing delivery, confirming payment—were invisible. The journey wasn’t modeled. Only the back office.
Common Patterns Behind BPMN Problems in Organizations
  • Modeling for tech, not business – Focusing on system screens and API calls instead of customer actions.
  • Flattened processes – No decomposition. One diagram covers everything from initiation to closure, making it impossible to navigate.
  • Unclear handoffs – Tasks assigned without specifying who does what, especially in cross-functional collaboration.
  • Overloaded gateways – Trying to express complex logic in a single decision point, leading to unreadable conditions.
  • Ignoring validation – Skipping built-in tool checks that flag missing end events, invalid flows, or unpaired gateways.
Why These Matter: The Hidden Costs
Bad BPMN models don’t just cause confusion. They lead to:
  • Re-work: Teams spend weeks fixing logic after implementation.
  • Misaligned expectations: IT builds one thing; business expects another.
  • Failed automation: Systems crash because the model didn’t define end conditions.
  • Compliance failure: Auditors can’t verify process controls because the diagram is ambiguous.
One organization spent $80,000 on a BPMN-based workflow engine only to realize the models were invalid. The cost wasn’t the software—it was the time spent correcting fundamental errors.
How to Avoid the Pitfalls
Start with Purpose
Before drawing a single line, ask:
  • Who will use this diagram?
  • What decision will it support?
  • What is the scope? What’s in, and what’s out?
Answering these cuts through noise. It prevents over-engineering and keeps the model focused.
Use a Lightweight Modeling Style Guide
Don’t require full documentation. Just define:
  • How to name activities: Verb-Object (e.g., “Review application,” “Send confirmation email”)
  • How to label gateways: Business-friendly (e.g., “Is credit score ≥ 650?” not “Condition 1”)
  • How to use pools: One role per lane, unless collaboration is intentional.
  • How to handle complexity: Use sub-processes or call activities for reusable logic.
Consistency beats perfection. A team of 10 modelers using the same rules will produce better diagrams than one expert chasing elegance.
Validate Early, Validate Often
Enable your BPMN tool’s validation rules. Check for:
  • Missing start or end events
  • Unpaired gateways (split without join)
  • Invalid event types (e.g., throw event in middle of flow)
  • Orphaned activities
Run validation after every major edit. Treat warnings as issues—especially when they involve flow continuity or responsibility.
Review with Stakeholders, Not Just Peers
Don’t just ask IT to review. Walk through the model with a business user. Ask:
  • “Does this match how you actually do the process?”
  • “What would happen if this step fails?”
  • “Is there anything missing from your perspective?”
Stakeholder walkthroughs expose assumptions. They reveal gaps no internal team can see.
Why do so many BPMN diagrams fail in real projects?
Because they’re built on assumptions, not alignment. Without clear goals, proper notation, and validation, models become unreliable—no matter how polished they look.
How can I tell if my BPMN model is bad before it’s used?
Run a diagnostic: Does it have a clear start and end event? Are responsibilities assigned to lanes? Is flow logical and unbroken? If any answer is “no,” the model is likely flawed.
Is it okay to use informal names like “Do Stuff” in BPMN?
No. Vague names like “Do Stuff,” “Handle Request,” or “Process Data” hide intent. Use precise, business-oriented language. A task named “Check customer credit” is far more actionable than “Approve.”
Should I model everything in one diagram?
No. A single diagram should not contain multiple unrelated processes or scenarios. Split them by purpose: e.g., “Order Processing,” “Returns Handling,” “Customer Onboarding.” Use reference links or call activities to connect them.
Can a BPMN diagram be too simple?
Yes—when it oversimplifies. A diagram that omits key decisions, exceptions, or handoffs becomes misleading. The right level of detail depends on the audience. For automation, include all critical paths. For strategy, focus on high-level flows.
Why do teams keep reusing bad BPMN templates?
Because they don’t know better. Templates are shortcuts—but if the template itself is flawed, the reuse multiplies the error. Always audit templates before use. Better yet: create your own based on real process needs.
