Mastering the Four Levels of C4
Temps estimé :3 minutes 373 vues
Have you ever struggled to explain your system to stakeholders, only to realize your diagrams are either too vague or too technical? You’re not alone. Most teams start with a high-level vision but quickly get lost in implementation details—or worse, fail to communicate anything meaningful at all. This section is where clarity begins.
Mastering the four levels of C4 gives you a structured way to communicate software architecture across different audiences—whether you’re aligning with business stakeholders, planning a scalable system, or helping new developers understand the codebase. Each level serves a specific purpose, and learning how to move between them is key to avoiding both oversimplification and analysis paralysis.
You’ll learn how to build effective system context diagrams that define boundaries and relationships, how to break down systems into containers using real-world examples, and how to drill down into components and code views with precision. Along the way, you’ll discover the right time and place for each level, and how to avoid common pitfalls like over-documenting or under-explaining.
Over the next few chapters, you’ll gain hands-on experience with all four levels of the C4 model. You’ll learn how to create meaningful diagrams that serve their intended audience and support real decision-making.
  • Building Effective System Context Diagrams: Learn how to define your system’s scope, identify users and external systems, and clearly show interactions—keeping stakeholders on the same page from day one.
  • Diving into Container Diagrams for Scalable Designs: Break down systems into containers (web apps, databases, services) and visualize technology choices, interactions, and scalability concerns.
  • Component Diagrams: Detailing Internal Logic: Explore how to decompose containers into components, model dependencies, and use patterns to prevent hidden complexity.
  • Code-Level Views: Connecting Diagrams to Implementation: Understand when and how to link diagrams to actual code—without turning every class into a diagram.
  • Comparing C4 Levels: When to Zoom In or Out: Master the decision-making framework for selecting the right level based on audience, goal, and project phase.
  • Create a C4 system context diagram that clearly shows the system boundary and key stakeholders.
  • Design a C4 container diagram that reflects the system’s architecture and technology stack.
  • Break down a container into components using clear responsibilities and relationships.
  • Use C4 code diagrams appropriately to bridge architecture and implementation.
  • Decide which C4 level to use in any given scenario—avoiding both under- and over-documentation.
  • Explain the purpose of each C4 model level in plain language to non-technical audiences.
These skills aren’t just about drawing diagrams—they’re about building shared understanding. Whether you’re starting a new project or refactoring an old one, the C4 model helps you think, plan, and communicate with clarity. Let’s begin.
Retour en haut
