Industry Applications: C4 in Web, Mobile, and Data Systems
Temps estimé :8 minutes 66 vues
Many beginners assume the C4 model is only useful for monolithic back-end systems. That’s a misunderstanding. The real power of the C4 model lies in its adaptability. It’s not a rigid framework—it’s a language for communication. Whether you’re modeling a React web app, a Flutter mobile experience, or a data pipeline with Kafka and Spark, C4 remains effective because it focuses on abstraction, not technology.
Consider this: a web app’s user context is just as important as a microservice’s interaction with a database. The C4 model doesn’t care if you’re using Node.js or Rust—it helps you clarify who interacts with what, and why. This isn’t about drawing pretty boxes. It’s about aligning teams around a shared understanding of where value flows and where risk lies.
You’ll learn how to adjust the model for different domains. You’ll avoid common missteps like over-correcting container boundaries in mobile apps or misrepresenting data flows in ETL pipelines. This chapter gives you the practical insight to apply C4 confidently—no fluff, no theory without context.
Adapting C4 for Web Development
Context Diagrams: Clarify User Interaction Early
When modeling a web application, start with the user. Who are they? Do they log in? Access data? Interact with third-party APIs? The System Context Diagram (Level 1) must answer these questions clearly.
Use roles like « Authenticated User » or « Admin » instead of vague labels like « User. » This forces you to define boundaries early—something often missed in fast-moving web projects.
For example, in a SaaS dashboard, the system might include: a React frontend, a Node.js backend, a PostgreSQL database, and an external OAuth provider. The diagram shows not just the components, but who depends on what.
Container Diagrams: Align Frontend and Backend Boundaries
Web apps often blur the line between frontend and backend. Don’t fall into that trap. In a Level 2 diagram, separate the frontend (e.g., React SPA), the backend API (e.g., Express.js), and external services (e.g., Stripe, Firebase).
Each container should have:
  • A clear name (e.g., “Customer Dashboard Frontend”)
  • A technology (e.g., React, Vite, Webpack)
  • A description of its responsibility
Label interactions with verbs: “renders,” “authenticates,” “fetches data.” This ensures clarity and avoids ambiguity.
Component Diagrams: Break Down the Frontend
Frontend applications are full of components. Use Level 3 to model critical sections like routing, state management (e.g., Redux), and API clients.
For example, in a React app:
  • “Router” — responsible for navigation and route resolution
  • “Auth Context” — manages login state and token storage
  • “API Service Layer” — handles all HTTP requests and error handling
These components are not just UI elements. They’re encapsulated units with defined behaviors and dependencies. This is where you catch hidden coupling and unnecessary re-renders.
Code-Level Views: When to Dive In
Code-level views (Level 4) aren’t needed for every component. Use them only where complexity demands it—like state management logic, routing guards, or authentication flows.
For example, a JWT token validation function might warrant a code diagram. But a simple form input component does not. The key is to avoid diagram bloat.
C4 for Mobile App Architecture
Mapping the Mobile Ecosystem
Mobile apps often interact with multiple systems: a backend API, cloud storage, push notification services, and device sensors. The C4 model helps visualize these dependencies clearly.
In a Level 1 diagram, define the user as “App User.” External systems might include: a backend REST API, Firebase Cloud Messaging, Apple HealthKit, and Google Maps.
Be specific. “Cloud Infrastructure” is vague. Instead, label the backend as “User Management API” or “Order Processing Service.” Precision prevents confusion during sprint planning.
Container-Level Structure: Mobile vs. Web
Mobile apps typically run on iOS and Android, each with its own app binary. The container diagram should reflect this.
Example structure:
  • Mobile App (iOS) – Swift/UIKit, Firebase, Core Data
  • Mobile App (Android) – Kotlin/Composable, Room, WorkManager
  • Backend API – Node.js, Express, PostgreSQL
  • Push Notification Service – FCM, APNS
  • Cloud Storage – AWS S3, Firebase Storage
Use color coding or icons to distinguish OS-specific containers. This helps non-mobile devs understand the architecture at a glance.
Component-Level Modeling: Handle Asynchronous Flows
Mobile apps rely heavily on async operations: background sync, network calls, and local storage updates. Use Level 3 to model these flows.
Consider a “Sync Manager” component responsible for:
  • Checking network status
  • Queuing pending data
  • Executing bulk syncs based on user activity
Visualize data flow with annotated arrows: “syncs to server,” “stores locally,” “notifies UI.” This prevents confusion between “loading” and “syncing” states.
Code-Level Views: Debugging Complex Logic
When a user reports a crash after syncing, the code-level diagram helps isolate the issue. Show how the sync flow passes through:
  • Data model
  • Network service
  • Database adapter
  • Error handler
Not every method needs a diagram—but the one that handles failure recovery? Yes. This keeps the model focused and valuable.
Modeling Data-Intensive Systems with C4
Integrating C4 with Data Flows
Data-heavy systems—think ETL pipelines, real-time analytics, or ML model training—often use complex flows. The C4 model can visualize this without diving into formal E-R diagrams.
Instead of treating systems as static entities, model data as a flow. A Level 2 diagram might show:
  • Data ingestion (Kafka)
  • Processing (Spark)
  • Storage (S3, BigQuery)
  • Consumption (Dashboard, API)
Label each container with its data role: “real-time stream,” “batch processor,” “data warehouse.” This is more intuitive than traditional database schemas for non-data engineers.
Component Diagrams: Break Down Pipelines
Model the pipeline as components:
  • Message Ingestor – consumes Kafka topics
  • Transformer – cleanses and enriches data
  • Loader – writes to target data store
  • Monitor – tracks throughput and errors
Use directional labels: “input,” “output,” “error log.” These help validate that data paths are correct and no components are isolated.
Code-Level Views: Model the Core Pipeline Logic
For critical logic—like data validation rules or transformation functions—use Level 4 to show the actual code structure.
Example: a function that validates user age from a raw JSON payload. Include:
  • Input schema
  • Validation rules (e.g., age > 13)
  • Error handling
  • Output transformation
This isn’t about showing every line. It’s about highlighting decision points and failure modes.
Comparative Summary: C4 Across Domains
Domain Key Focus in Level 1 Level 2 Differentiation Level 3 Focus
Web App User roles, frontend, API, external services Frontend vs backend vs API; tech stack State management, routing, API clients
Mobile App User, app binaries, cloud services OS-specific apps, push services, cloud storage Async flows, sync logic, UI state
Data System Data sources, consumers, processing pipelines Message brokers, processors, storage Transformation logic, error handling, monitoring
Best Practices for Domain-Specific C4 Modeling
  • Start with the user, not the tech. Always begin with who uses the system and what they do.
  • Use consistent naming. “User” vs “Authenticated User” matters. Avoid synonyms like “client” and “user” in the same diagram.
  • Limit the number of containers. 5–7 is ideal. More than 8 and you risk overwhelming the reader.
  • Document your decisions. Add a short legend: “Why we use Kafka for streaming,” or “Why React is in its own container.”
  • Review with non-technical stakeholders. If a product manager can’t understand your diagram, you’ve either missed context or added too much noise.
What’s the best way to model a React app using C4?
Start with a Level 1 diagram showing the user and the React app as one container. In Level 2, separate the frontend, API, and backend. For Level 3, model key components like routing, state management, and API clients. Use code views only for complex flows like authentication or sync logic.
Can C4 for mobile app architecture handle both iOS and Android?
Yes. Model each OS as a separate container in Level 2. Label them clearly: “iOS App,” “Android App.” Use color or icons to distinguish. This avoids confusion and shows that both share the same backend but have different implementations.
How do I model data flows in a C4 context?
Don’t treat data as an object. Model it as a flow: input → processing → output. Use components like “Data Ingestor,” “Transformer,” “Storage Layer.” Label interactions with verbs: “processes,” “stores,” “emits.” This keeps the model aligned with real workflows.
Should I use C4 model in web development for legacy systems?
Yes. C4 is especially useful in legacy systems where architecture drift has occurred. Use Level 1 to clarify who the users are and what external systems exist. Then work backward to map existing components. This helps modernize without rewriting.
How do I avoid over-documenting with C4?
Stick to one diagram per abstraction level. Ask: “Would this help a new team member understand the system?” If not, remove or simplify. Use code views only for high-risk or complex logic. Avoid diagramming UI components unless they contain behavior.
Can C4 model applications integrate with ERD or BPMN?
Yes. C4 is a communication tool, not a replacement for other models. Use ERD for data schema details, BPMN for process flows. But always anchor them to the C4 model—use C4 as the central reference. This way, all models stay aligned and readable.
