CMMN vs BPMN: Conceptual Differences
预计阅读时间8 分钟 64 浏览
When modeling business processes, the choice between CMMN and BPMN isn’t just a matter of preference—it’s a foundational decision rooted in how work actually gets done. The key question isn’t “which is better,” but “which model reflects the reality of the work?” This distinction shapes every subsequent step, from design to execution. My experience across dozens of enterprise implementations shows that teams often misapply one or the other not because of complexity, but because they don’t grasp the underlying philosophy of each notation.
Understanding the conceptual differences between CMMN and BPMN is essential for anyone building adaptable, maintainable, and realistic process models. In this chapter, I break down the core architectural principles behind both standards: control flow versus constraint-based behavior, visual semantics, and how each handles exceptions and collaboration. You’ll learn not just what each notation does, but why it does it that way—and how to recognize when one is more appropriate than the other.
By the end, you’ll be able to assess any business scenario and determine whether to use a structured path (BPMN) or a flexible case (CMMN) with confidence. No guesswork. No over-engineering. Just clarity grounded in real-world patterns.
Control Flow vs Constraint-Based Modeling
BPMN is built on the principle of control flow. It assumes a predictable sequence of activities governed by explicit transitions. If you’ve ever modeled a loan approval, an order fulfillment chain, or a manufacturing process, you’re already familiar with this mindset.
Every step in a BPMN diagram is designed to be triggered by the completion of the previous one. Decision points (gateways) determine which path to take, and flow logic is rigidly defined—often via conditional expressions. This makes BPMN ideal for workflows where the sequence is known in advance and automation is key.
CMMN, in contrast, embraces constraint-based modeling. It doesn’t dictate the order of tasks—it defines the conditions under which they can be executed. The model is not a linear flow but a constraint network. Tasks become available based on entry criteria being met, and progress is driven by triggers (events) and business rules, not just upstream completion.
Consider a medical investigation: the doctor doesn’t follow a fixed checklist. A lab test may come in, prompting a new task. A patient’s symptom change may trigger a new assessment. The case evolves, not because someone manually moved a pointer, but because constraints were met. That’s the power of CMMN.
Real-World Example: Incident Response
Imagine a security breach detection system. With BPMN, you might map a fixed sequence: detect → log → notify → investigate → resolve. But what if the breach is not detected until a user reports it? Or if new evidence appears mid-investigation? The rigid flow breaks down.
CMMN handles this naturally. The case starts with the entry criterion: “Security incident reported.” Then, tasks like “Review logs” or “Interview user” appear when their criteria are met—e.g., “When user report is received and verified.” The model stays valid even when the path changes.
So when do you use which? If the logic is rule-driven and sequential, choose BPMN. If the work is ad-hoc, knowledge-intensive, or evolves over time, CMMN is more appropriate.
Visual Semantics: How the Diagrams Tell the Story
Both CMMN and BPMN visualize business decisions, but they do so in fundamentally different ways. In BPMN, the visual layout emphasizes flow: boxes connected by arrows, events at the edges, gateways in the middle. It’s a directed graph, where the direction matters.
CMMN uses a case plan structure. The case is represented as a container with stages, tasks, and milestones. Visual cues are not about direction but about availability and progress. A task is only visible when its entry condition is satisfied. This reflects how real workers manage their work—by condition, not by schedule.
Think of it like this: BPMN is a train schedule. You know when each stop happens, and the train moves forward regardless. CMMN is a GPS navigation system: it updates the route based on traffic, weather, or new information. The destination is fixed, but the path adapts.
Key Visual Differences
  • BPMN: Focus on sequence flow, artifacts, and event-driven triggers.
  • CMMN: Focus on stages, milestones, and task availability via entry conditions.
  • Both use events, but in BPMN, events are typically triggers; in CMMN, they are often conditions for task activation.
When reviewing a model, ask: Is the order fixed, or does progress depend on conditions? That question alone will help you identify the correct notation.
Handling Exceptions and Collaboration
Exception handling reveals another core difference. In BPMN, exceptions are managed through boundary events attached to activities. A timeout, failure, or error can trigger a subprocess designed to handle it. But the model remains tied to a specific path.
CMMN manages exceptions by allowing the case to re-evaluate its plan. If a task fails, the case doesn’t reroute through a predefined error path—it simply waits for new conditions to trigger a recovery step. This is powerful in environments like fraud detection, where the next action depends on new data, not a pre-specified fallback.
Collaboration is another key area. BPMN is designed for orchestration—it defines how multiple participants coordinate through messages and subprocesses. It’s ideal for cross-functional processes where one team completes a step and hands it off.
CMMN excels in collaborative case management. Multiple actors can contribute to the same case, and tasks can be created or updated based on input from any participant. The case file acts as a shared workspace. This makes CMMN ideal for investigations, legal cases, and customer dispute resolution, where teams work together dynamically.
When Each Excels: A Practical Summary
  • BPMN shines in predictable, repeatable, and automatable workflows (e.g., invoice processing, manufacturing, payroll).
  • CMMN wins in adaptive, knowledge-driven, or highly variable scenarios (e.g., insurance claims, IT incident response, legal investigations).
  • Both can be used together—BPMN for the main process, CMMN for the exception or adaptive sub-process.
BPMN vs CMMN Comparison Chart
Aspect BPMN CMMN
Primary Focus Control flow and sequence Constraint-based task availability
Modeling Approach Directed graph (flow-centric) Plan-based, event-driven
Task Trigger Completion of upstream activity Entry condition met
Exception Handling Boundary events, error catchers Case re-evaluation, adaptive rerouting
Best For Standardized, repeatable workflows Adaptive, knowledge-intensive work
Collaboration Model Orchestration (hand-offs) Collaborative case management (shared workspace)
This comparison chart is not a rigid rulebook. It’s a decision aid. The best models don’t follow a single notation—they reflect the actual behavior of the work. In practice, the most effective models often combine both.
Hybrid Modeling: When to Use Both
Don’t treat CMMN and BPMN as competitors. Think of them as complementary tools in your modeling toolkit. In many real-world systems, BPMN manages the primary workflow, while CMMN handles the exceptions, investigations, or adaptive subprocesses.
For example, in insurance claim processing:
  1. BPMN handles the standard path: claim submitted → validation → preliminary approval → payment.
  2. If fraud is suspected, a CMMN case is triggered. The case includes tasks like “Review transaction history,” “Interview claimant,” and “Consult risk team.”
  3. These tasks only appear when the criteria are met. The case evolves as new evidence emerges.
  4. Once resolved, the case closes, and the BPMN process resumes.
This hybrid approach maintains clarity: the main flow stays simple, while the complex path is isolated in a dedicated case. It also ensures that the human-in-the-loop decisions are modeled transparently.
As I’ve seen in multiple implementations, the most successful models are those that let the work decide—not the diagram.
What’s the main difference between BPMN and CMMN?
BPMN models predictable, sequential workflows where tasks are triggered by completion. CMMN models adaptive, case-based work where tasks are triggered when conditions are met. BPMN is flow-driven; CMMN is constraint-driven.
Can I use both BPMN and CMMN in the same process?
Yes. Many organizations use BPMN for standard workflows and CMMN for complex, exception-prone, or knowledge-intensive subprocesses. A BPMN subprocess can trigger a CMMN case when an exceptional condition arises.
How do I decide between BPMN and CMMN for a new project?
Ask: Is the sequence predictable and repeatable? If yes, use BPMN. If the path depends on data, events, or decisions made during execution, use CMMN. When in doubt, model the core flow in BPMN and the adaptive part in CMMN.
Why does CMMN have stages and milestones?
Stages represent logical phases in a case (e.g., Investigation, Review, Resolution). Milestones mark key points that must be achieved. They help visualize progress and ensure that the case moves forward based on business outcomes, not just time or task completion.
Are there tools that support both BPMN and CMMN?
Yes. Visual Paradigm offer full support for both standards. They allow you to model, simulate, and even execute hybrid diagrams, with traceability between BPMN processes and CMMN cases.
How do events differ in BPMN vs CMMN?
In BPMN, events are typically triggers (e.g., start, end, boundary). In CMMN, events are often used as criteria to activate tasks. For instance, “When a new document is uploaded” can be an entry condition, not just a trigger.
Trust your instincts. If you find yourself adding endless conditional branches or overriding flow rules, you’re likely in the wrong notation. Step back, reevaluate the work, and ask: Is this a path, or a case?
Mastering CMMN BPMN differences isn’t about memorizing rules. It’s about understanding the work—not the tool. The best models are those that mirror reality, not just templates.
