Common Pitfalls When Converting CRC to UML
Geschätzte Lektüre: 6 Minuten 55 Ansichten
About 6 out of 10 teams I’ve worked with overlook the behavioral nuance when converting CRC cards to UML, leading to models that are syntactically correct but semantically hollow. The issue isn’t with the mechanics—it’s in how the collaborative intent of CRC gets flattened into static structure. CRC cards are about communication, responsibility, and interaction. When we rush to convert them into UML without preserving that intent, we lose the very foundation the team built together.
What you’ll gain here is a real-world guide to spotting and fixing the most common CRC to UML errors. I’ve distilled years of feedback from design reviews, team workshops, and model audits into clear, actionable insights—no fluff, no jargon overload. You’ll learn how to detect over-engineering, misinterpret collaborations, and misapply relationships, along with practical model validation tips to check your work before it becomes code.
Over-Engineering the Model: When Simplicity Gets Lost
One of the most frequent CRC to UML errors is adding attributes and operations that aren’t directly tied to the CRC responsibilities. It’s tempting to anticipate future needs, but this erodes clarity and invites technical debt.
I once saw a team add 17 attributes to a PaymentProcessor class because someone said, “We might need to track the payment method later.” The problem? The original CRC card only listed “process payment” and “verify funds”—no mention of method tracking. The extra complexity made the class harder to test, maintain, and understand.
  • Only add attributes or operations that directly serve a responsibility listed on the CRC card.
  • Use intent-driven modeling—ask: “Does this element help fulfill the responsibility?”
  • Delay implementation details until the design is validated and refined.
When to Hold Back
If a class has more than 5 attributes or 8 operations without clear behavioral grouping, re-evaluate. Chances are, you’ve merged responsibilities or introduced hidden complexity.
Misinterpreting Collaborations: The Hidden Risk
CRC cards say “collaborates with” — but UML treats this as an association, aggregation, or dependency. The misstep? Assuming all collaborations are direct associations, especially when they aren’t.
For example, a Customer card might list “collaborates with: Order, Invoice.” In UML, this often becomes a direct association. But in reality, Order might be created by a ShoppingCart, and Invoice is generated by Order—so the relationship isn’t direct.
Misinterpreting collaboration leads to inaccurate dependencies, broken lifecycles, and poor maintainability.
CRC Collaboration Correct UML Mapping Common Mistake
Customer → Order Customer creates Order via ShoppingCart Direct association between Customer and Order
Order → Invoice Order generates Invoice (dependency) Association without proper direction or multiplicity
Invoice → Payment Invoice triggers Payment (dependency) Association with no semantic intent
Always trace the actual behavior. Ask: “What object creates or triggers this?” Use dependencies for temporary or event-driven links. Reserve associations for stable, long-lived relationships.
Ignoring Behavioral Intent: The Silent Model Degradation
When teams focus only on structure—class names, attributes, methods—they forget that CRC cards were never just about static elements. They were about what objects do together.
Consider a CRC card saying: “BankAccount → transfers money to: SavingsAccount.” The intent is behavioral: a transfer is an action involving two accounts. In UML, this becomes a method like transferTo(SavingsAccount, amount).
But too often, this gets reduced to: transferTo(SavingsAccount) with no mention of the source. Worse, some teams rename it to sendFunds()—which sounds more generic and loses the domain-specific intent.
Model validation tips:
  • Review method names: Do they reflect the action and participants?
  • Check if responsibilities are mapped to methods with clear, domain-relevant verbs.
  • Use behavioral naming patterns: “transferTo”, “validate”, “generateReport” instead of “process” or “doSomething”.
Example: Better Intent in Action
CRC: “LoanApplication → sends to: Underwriter”
Bad UML: sendTo(underwriter)
Good UML: submitTo(underwriter) or forwardTo(underwriter)
Small change, big difference in clarity and maintainability.
Skipping Model Validation: The Cost of Oversight
Many teams assume that because the model looks like a UML diagram, it’s valid. But visual correctness ≠ structural or behavioral correctness. This is where design pitfalls UML often emerge.
Here’s a simple checklist I use in every design review:
  1. Every method in the UML diagram must derive from a specific CRC responsibility.
  2. Every association must have a justified reason based on collaboration or lifecycle behavior.
  3. No class should have more than two responsibilities unless clearly separated by public and private sections.
  4. All cardinalities must be validated: e.g., Is “0..1” correct for a one-time event?
  5. Check that inheritance hierarchies don’t emerge from accidental abstraction—ask: “Would a subclass replace or extend this behavior?”
These model validation tips are not optional. They’re the difference between a working design and a maintenance nightmare.
Underestimating the Power of Feedback Loops
One of the most overlooked CRC UML mistakes is treating the conversion as a one-way process. But good design is iterative.
If your UML class diagram causes confusion in a team meeting, or a developer asks, “Why is this class so big?”, you’ve missed a feedback loop. Revisit the original CRC cards. Do they still reflect the current understanding?
Every time you find a discrepancy:
  • Go back to the CRC card.
  • Re-ask: “What were we trying to model here?”
  • Revise the UML model to reflect the shared understanding.
This isn’t a failure—it’s design maturity. The model evolves, just like the team’s understanding.
Why do my UML models look too complex after CRC to UML conversion?
Complexity usually comes from adding elements not grounded in CRC responsibilities. Go back to the original CRC cards and ask: “Does this attribute or method directly support a listed responsibility?” If not, remove it. Focus on intent, not completeness.
Can I use CRC cards after creating the UML diagram?
Absolutely. The beauty of CRC is that it stays useful throughout development. Use CRC cards during maintenance, refactoring, or team onboarding to quickly re-establish context. They’re your design memory.
How do I know if my UML model is correct?
Use the model validation tips: every method should have a CRC root, every association should serve a behavioral need, and no class should have more than two core responsibilities. Run a team walkthrough—ask someone unfamiliar with the code to explain the model. If they struggle, you’ve overcomplicated it.
Should I draw associations for every CRC collaboration?
No. Not all collaborations are stable relationships. Use associations only when two objects interact persistently over time. Use dependencies (dashed line with arrow) for temporary or event-driven links—like “Order generates Invoice” or “Customer notifies System”.
What if the UML model contradicts the CRC card?
This signals a breakdown in communication. Revisit the original brainstorming session. Was the collaboration misunderstood? Was the responsibility misattributed? Use this as a learning moment to improve team clarity.
Is it okay to merge CRC cards into a single class in UML?
Only if the responsibilities are unified and logically cohesive. A class should not be a container for unrelated behaviors. If you’re merging, ask: “Is this one object fulfilling multiple roles?” If yes, consider splitting it into separate classes with clear responsibilities.
