Modeling Collaborations that Make Sense
Lectura estimada: 7 minutos 228 vistas
Many beginners start by listing every possible interaction between classes, like a shopping list without a purpose. The result? A tangled web of connections that feel artificial, hard to trace, and ultimately unhelpful in real design. The root issue isn’t poor logic—it’s a failure to anchor collaborations in real intent. I’ve seen teams waste hours drawing lines between classes that never actually talk in code. The fix is simple: model collaborations only when they serve a real responsibility. This chapter teaches how to build meaningful CRC interactions by focusing on purpose, not just proximity.
You’ll learn to distinguish between superficial connections and genuine, necessary collaborations. We’ll walk through practical patterns, common pitfalls, and how to use CRC interactions as a compass during early design. No jargon overload. No abstract theory. Just honest, field-tested practices that help you make better design decisions from the start.
Why Most CRC Collaborations Fail
When teams rush to sketch collaboration lines, they often miss the real question: why would these classes need to talk?
Too many model collaborations are based on proximity, not necessity. A Customer might “collaborate” with Invoice just because they’re both in the same domain. But if the Invoice is created by a System and never directly accessed by Customer objects, that connection adds noise.
Here’s the key insight: collaborations should emerge from responsibilities, not class names. If a class doesn’t need to communicate to fulfill its duty, it shouldn’t be in the collaboration list.
Red Flags in Poorly Designed CRC Interactions
  • Collaborations that don’t support any class responsibility
  • One-way interactions with no clear trigger or purpose
  • Unidirectional links that don’t reflect a real method call
  • Overuse of “manages” or “controls” without a concrete use case
These are signs of weak modeling. They don’t break the system—but they break clarity.
Building Meaningful CRC Interactions
Good CRC interactions are not random links. They’re logical extensions of responsibilities. Think of each collaboration as a question: “What does this class need to do its job?”
Let’s say Order has the responsibility “notify customer of shipment status.” To fulfill this, it needs to access the Customer’s email. The collaboration is clear: Order → Customer (for email access). That’s a real, necessary interaction.
Four Ways to Evaluate a Valid CRC Interaction
  1. Does it support a responsibility? If the collaboration doesn’t help a class fulfill one of its duties, remove it.
  2. Is the communication bidirectional or necessary? If Customer doesn’t need to respond to Order, don’t make them interact.
  3. Does it reflect actual method calls? A real collaboration implies a method call like customer.getEmail() or order.notify(customer).
  4. Is it inevitable in the current context? Can the responsibility be fulfilled without this link? If yes, reconsider.
These filters act as a team’s design checkpoint. They stop us from over-connecting and encourage intentionality.
Common Patterns in Effective CRC Collaborations
While every system is different, certain collaboration patterns emerge consistently in real-world modeling.
1. Responsibility Delegation
When a class has a complex task, it delegates part of it to another class. For example:
  • Order → PaymentProcessor (to validate payment)
  • ReportGenerator → DataRepository (to fetch data)
These are clean, single-purpose interactions. They represent clear method calls and avoid mixing concerns.
2. Event-Driven Collaboration
Some collaborations happen in response to events. A PaymentConfirmed event triggers the Order to update its status and notify the Warehouse.
  • PaymentService → Order (on payment success)
  • Order → Warehouse (to fulfill order)
This reflects real behavior in modern systems. It’s not about class proximity—it’s about intent and timing.
3. Data-Driven Collaboration
When one class needs data from another, the collaboration is often passive but essential.
  • Invoice → Customer (to get billing address)
  • ShippingService → AddressValidator (to verify delivery location)
The key is to ensure the data access is justified by a responsibility. If Invoice doesn’t use the address, don’t model the link.
Modeling Collaborations: A Step-by-Step Checklist
Use this checklist when defining CRC interactions to ensure they’re logical and purposeful.
Step Action Why It Matters
1 Start with a responsibility: “What must this class do?” Collaborations are byproducts of duties, not the other way around.
2 Ask: “Who or what does it need to help with this?” Identifies potential collaboration partners.
3 Verify: Does the partner actually do something needed? Prevents phantom or speculative links.
4 Check: Is the interaction one-way or bidirectional? Helps avoid over-involving classes in unnecessary feedback loops.
5 Test: Can this be fulfilled without this collaboration? Ensures each link is truly necessary.
Apply this each time you consider adding a line between two CRC cards. It keeps your model lean and meaningful.
When to Avoid CRC Interactions
Not every class relationship needs to be modeled as a collaboration. Some are irrelevant to the current design scope.
  • Utility classes: A MathUtils class rarely needs to collaborate with domain objects. It’s a helper, not a partner.
  • Infrastructure objects: Things like Logger or DatabaseConnector often don’t need to be on collaboration lists unless they’re actively involved in a core responsibility.
  • Passive data containers: A CustomerInfo object without behavior doesn’t need to coordinate with others unless it’s part of a transformation or validation step.
These are often implications, not collaborations. They belong in the background, not in the flow.
Real-World Example: Order Processing
Let’s apply this in a simple e-commerce system.
Class: Order
Responsibility: “Verify payment, update status, notify customer”
Now, what collaborations does it need?
  1. Order → PaymentService (to verify payment)
  2. Order → Customer (to send confirmation email)
  3. Order → Warehouse (to trigger shipment)
Each line supports a responsibility. No extras. No “just because they’re in the system.”
This is what model collaborations should look like: clean, intentional, and traceable.
Final Tips for Better CRC Interactions
  • Start with responsibilities, not classes. Let the work determine who’s involved.
  • Use real verbs. Instead of “interacts with,” say “calls,” “requires,” or “updates.”
  • Revisit after writing responsibilities. If a collaboration doesn’t support any duty, remove it.
  • Keep it visible. Draw lines only when the interaction is meaningful. Avoid clutter.
  • Ask: “Would the code break if this connection vanished?” If no, it might not belong.
These habits build cohesion and prevent the “network of no purpose” syndrome that plagues early designs.
How do I know when a collaboration is necessary?
If a class needs data, behavior, or an event from another class to fulfill its responsibility, the collaboration is valid. Ask: “What does this class need to do its job?” If the answer references another class, include the link.
Can a class collaborate with itself?
Not directly. CRC interactions model object-to-object relationships. If a class performs an action on its own data, it’s internal behavior, not a collaboration. Avoid self-collaborations—they create confusion.
Should I model every possible object interaction in a CRC session?
No. Only model collaborations that support a responsibility. The goal isn’t completeness—it’s clarity and intentionality. Over-modeling leads to noise, not insight.
What if two classes need to talk, but no one’s responsibility mentions it?
Re-express the responsibility. If two classes interact, there must be a reason. Ask: “What task is being done?” and “Who is responsible for it?” The collaboration likely supports an overlooked duty.
How do I handle asynchronous or event-based interactions?
Model them as triggers or events, not direct method calls. For example, “PaymentConfirmed → Order” indicates a response to an event. This mirrors reality and avoids over-constraining the model.
Are CRC interactions the same as UML associations?
They’re closely related but not identical. CRC interactions describe why a connection exists—the purpose. UML associations are structural. Use CRC to validate and justify UML links.
Scroll al inicio
