Private (Internal) Process Modeling Explained
Lectura estimada: 9 minutos 77 vistas
Over 80% of the BPMN models I’ve reviewed in the past five years were private processes—internal workflows modeled within a single pool, with no external message flows. This isn’t a coincidence. Teams use this format because it aligns with how work actually happens inside an organization: a sequence of actions, decisions, and handoffs, all contained within one unit of responsibility.
What makes a BPMN private process unique is its focus on internal logic. It shows the full flow of work from start to finish, without exposing interactions with other teams or systems. This is ideal when you’re documenting a process for internal training, designing automation in a workflow engine, or analyzing bottlenecks in a department’s daily operations.
As a mentor, I’ve seen teams struggle when they try to use collaboration diagrams for internal tasks—adding pools and message flows where none exist. It creates confusion. The private process avoids that. It’s not about who sends what to whom. It’s about what happens next in the sequence.
By the end of this chapter, you’ll know how to model a private process with clarity, decide the right level of detail, and handle internal handoffs without overcomplicating the diagram. You’ll also learn how to distinguish this from collaboration or choreography views—so you pick the right tool for the job.
What Is a BPMN Private Process?
A BPMN private process is a process diagram that represents the internal workflow of a single participant—typically a department, role, or system—within a single pool.
It does not show message flows to external participants. There are no inter-pool connections. All sequence flows are internal.
This is the most common type of BPMN diagram used in organizations. It’s the go-to choice when you’re documenting how a team performs a task, from initiation to completion.
Think of it as a “how it really works” map—inside the organization, not across it.
Why Use a Private Process?
There are three main reasons teams choose private process modeling:
  • Clarity of internal logic – When the focus is on the sequence of steps, decisions, and handoffs within a single unit, a private process removes external noise.
  • Automation readiness – Most workflow engines (like Camunda, Activiti, or Flowable) execute private processes. If you’re modeling for automation, this is the format to use.
  • Stakeholder alignment – Internal teams, such as HR, finance, or IT, benefit from seeing their own process in full detail without needing to understand external dependencies.
When I worked with a mid-sized insurance company, they modeled their claims processing as a private process. The result? A 30% reduction in onboarding time for new claims analysts. Why? Because the diagram showed exactly what each step involved—no assumptions, no guesswork.
Modeling a BPMN Private Process: Key Principles
Modeling a private process isn’t just about drawing a flowchart. It’s about making choices that reflect the reality of how work is done.
Start with a Single Pool
Every private process begins with a single pool. This pool represents the participant—e.g., “Claims Department” or “Customer Service Agent.”
Do not split it into lanes unless you’re modeling distinct roles within the same team. Even then, use lanes sparingly. The goal is to keep the focus on the process, not the people.
When I see a private process with five lanes, I ask: “Is this really a process, or is it a collaboration?” If the handoffs are between different teams, it’s likely a collaboration diagram in disguise.
Use Sequence Flows, Not Message Flows
Only use sequence flows inside a private process. Message flows should never connect to external pools.
Message flows are for collaboration diagrams. They show what is sent or received between participants. In a private process, all flows are internal—what happens next in the sequence.
Example: If a customer service agent approves a refund, the next step is “Process payment.” That’s a sequence flow. If the agent sends a message to the finance team, that’s a message flow—and it belongs in a collaboration diagram, not here.
Handle Internal Handoffs with Clarity
Internal handoffs—when one role passes work to another within the same team—are common. But they can blur the lines of ownership.
Use lanes to represent different roles. But avoid over-lane-izing. One lane per role is usually enough.
For example, in a loan approval process, you might have:
  • Loan Officer (enters application)
  • Underwriter (assesses risk)
  • Manager (approves or rejects)
Each lane contains the activities they perform. The sequence flows move from one lane to the next, showing the handoff.
Don’t use message flows between lanes. That’s a red flag. It suggests you’re modeling a collaboration, not an internal process.
Choosing the Right Level of Detail
One of the biggest challenges in private process modeling is knowing how much detail to include.
Too little detail? The diagram is useless for training or automation.
Too much? It becomes a wall of text and icons, unreadable by anyone.
Here’s my rule of thumb: model at the level of execution.
If the process will be automated, include all tasks, decisions, and data inputs/outputs. If it’s for documentation, focus on key decision points and major handoffs.
Decision Tree: How Much Detail?
Use this checklist to decide:
  1. Is this process going to be automated? → Include all tasks, data objects, and conditions.
  2. Is it for training or onboarding? → Focus on major steps and decision points. Use swimlanes to show role responsibilities.
  3. Is it for executive review? → Simplify. Use a conversation diagram instead.
  4. Is it part of a larger system? → Keep it modular. Break it into sub-processes if needed.
When I worked with a logistics team, we modeled their invoice reconciliation process. Initially, we included every field and validation rule. It was too dense. After a review, we simplified it to show only the key decision points: “Is the invoice valid?” and “Is the amount correct?” The rest was moved to a separate data model.
Result? The team understood it faster. And the automation team could still map the logic precisely.
BPMN Private Process Example: Employee Onboarding
Let’s walk through a real-world BPMN private process example: employee onboarding in a mid-sized tech company.
Pool: HR Department
Lanes: HR Coordinator, IT Admin, Manager
Key Steps:
  • Receive new hire paperwork (Start Event)
  • Verify documents (Task)
  • Is documentation complete? (Exclusive Gateway)
  • Yes → Create user account (Task, IT Admin lane)
  • No → Notify hiring manager (Task)
  • After account creation → Send welcome email (Task, HR lane)
  • Send onboarding schedule to manager (Task, HR lane)
  • End (End Event)
Notice: All flows are sequence flows. No message flows to external pools. The handoffs are between roles within HR and IT—internal.
This is a BPMN single pool process that clearly shows the internal workflow. It’s ideal for training, automation, or auditing.
Common Mistakes in Internal Process Modeling
Even experienced modelers make these errors. Watch out for them:
  • Mixing sequence and message flows – If you’re using a message flow inside a single pool, you’re likely modeling a collaboration by mistake.
  • Over-lane-izing – Too many lanes make it hard to follow the flow. Use lanes only to show distinct roles, not every individual.
  • Ignoring data – Tasks often depend on data. Include data objects or input/output parameters where relevant.
  • Starting with a collaboration diagram – If you begin with multiple pools, you’re already in collaboration territory. Switch to private process only when you’re modeling a single unit.
When I reviewed a model from a financial services firm, they had a private process with three pools. The diagram was labeled “Internal Process,” but it showed message flows between HR, Finance, and IT. I asked: “Who’s sending what?” The answer was “We don’t know.” That’s a red flag. It’s not a private process. It’s a collaboration.
When Not to Use a Private Process
Just as important as knowing when to use it is knowing when not to.
Use a private process only when:
  • You’re modeling a single participant’s workflow.
  • There are no external handoffs or message exchanges.
  • The goal is documentation, training, or automation.
Don’t use it when:
  • You need to show interactions between departments.
  • Work is passed between teams or systems.
  • You’re defining a contract or agreement with a partner.
In those cases, use a collaboration or choreography diagram instead.
Summary: Key Takeaways
A BPMN private process is the right choice when you’re modeling internal workflows within a single team or system.
Use a single pool. Avoid message flows. Focus on sequence flows and internal handoffs.
Decide the level of detail based on your goal—automation, training, or audit.
Remember: internal process modeling BPMN is about clarity, not complexity. If your diagram feels cluttered, simplify it. If it’s too vague, add the missing logic.
And always ask: “Is this really a private process, or am I modeling a collaboration in disguise?”
What’s the difference between a BPMN private process and a collaboration diagram?
A private process shows the internal flow of a single participant, using only sequence flows. A collaboration diagram shows interactions between multiple participants, using message flows. If there’s no external exchange, use a private process.
Can a BPMN private process include multiple lanes?
Yes, but only to represent distinct roles within the same team. For example, HR Coordinator and IT Admin in the same department. Avoid using lanes to represent separate departments or external teams.
Is a BPMN private process executable?
Yes, if it includes all necessary elements for automation: tasks, gateways, data objects, and valid sequence flows. Most workflow engines expect private processes for execution.
When should I use a BPMN single pool process instead of a collaboration diagram?
Use a single pool process when the workflow is entirely internal. Use collaboration when work is passed between teams, departments, or systems. If there are no external message flows, it’s a private process.
How do I decide how much detail to include in a private process?
Ask: “Who will use this diagram?” If it’s for automation, include all tasks and data. If it’s for training, focus on key steps and decisions. Avoid unnecessary detail that obscures the flow.
Can a private process be part of a larger model?
Yes. A private process can be a sub-process within a collaboration or choreography diagram. It’s a common pattern to break down complex workflows into smaller, internal processes for clarity and reuse.
