SWOT Analysis
TOWS Matrix in Action: Turning SWOT Insights into Strategies
If you’ve ever completed a SWOT analysis only to feel stuck on what to do next, you’re not alone. Too many teams stop at listing strengths, weaknesses, opportunities, and threats—without moving forward to actual strategy. This book cuts through the confusion. It’s built for professionals who want to go beyond analysis and turn insight into […]
SWOT vs. TOWS: What’s the Difference and When to Use Each
If you’ve ever completed a SWOT analysis only to feel stuck on what to do next, you’re not alone. Many professionals and students reach the same point—insightful but directionless. This book cuts through the confusion by clarifying the core difference between SWOT and TOWS, showing you not just how they work, but when to use
SWOT Analysis for Startups and Entrepreneurs
Starting a company means facing constant decisions with limited data. You’re not just building a product — you’re navigating uncertainty, managing scarce resources, and trying to stay ahead of competitors. Too often, founders jump into action without first clarifying their strategic position. That’s where SWOT analysis for startups becomes essential: not as a rigid report,
SWOT Analysis: A Practical Guide for Modern Businesses
Too many teams run SWOT analysis without a clear purpose—resulting in vague insights, wasted time, and decisions that don’t stick. You’ve likely been in meetings where strengths and weaknesses were listed, but no one knew what to do with them. That’s the real problem: SWOT isn’t just a checklist—it’s a strategic lens, and its power
PEST vs SWOT: Choosing the Right Strategic Tool
Have you ever completed a SWOT analysis only to realize it missed critical market shifts? Or used PEST analysis and felt like the insights didn’t connect to your internal capabilities? You’re not alone. Too many professionals apply these tools habitually—without asking the right question: Which framework best fits my current strategic challenge? This book is
Common SWOT Mistakes — and How to Avoid Them
Too many SWOT analyses end up as vague lists that inspire little more than polite nods and silence. You’ve probably sat through one yourself: surface-level strengths, unverified threats, and a final slide that says “We should take advantage of opportunities” — but no real plan, no ownership, no follow-through. It’s not that SWOT is broken.
Case Study Collection: Real-World Applications of SWOT Analysis
Too many strategy sessions stall when teams rely on abstract frameworks with little context. I’ve spent over two decades coaching leaders through real-world challenges — and I’ve seen how SWOT analysis case studies cut through the noise. This book isn’t about theory. It’s about learning from what actually happened: how companies pivoted, repositioned, and recovered
