Structure and Core Components
Temps estimé :6 minutes 50 vues
Most beginners start with flowcharts or decision trees when modeling business logic. That’s natural. But they often discover too late that these approaches become unwieldy with complexity. Flowcharts grow tangled. Decision trees become unmanageable in branching depth. The real breakthrough comes when you shift to a structured, tabular format—where rules are columns, and conditions and actions are rows. This is the foundation of decision table structure.
Over two decades of working with business analysts, architects, and developers has taught me one truth: clarity in decision logic isn’t about visualization—it’s about structure. The decision table structure I’ll walk you through isn’t just a notation. It’s a disciplined method to ensure completeness, eliminate ambiguity, and scale rule management. You’ll learn how to build models that are readable by humans, automatable by systems, and maintainable over time.
Why Columns Are for Rules, and Rows for Conditions and Actions
Let’s begin with the core principle: **rules as columns**, and **conditions and actions as rows**. This may seem backward at first, but it’s intentional and powerful.
Each column represents a unique decision rule—each a distinct scenario based on combinations of input conditions. Breaking rules into columns allows you to see every possible path side by side.
Conditions appear in rows above the action section. They define the input states that trigger a rule. Actions appear below—what happens when those conditions are met.
This arrangement makes it easier to validate: you can scan each column to check if all conditions are logically consistent and whether actions align with the rule’s intent.
The Power of Compartments
A well-structured decision table is divided into four distinct compartments:
  • Decision name — A short, descriptive label for the rule set.
  • Conditions — The inputs or attributes that define the state of the system.
  • Actions — The operations or outcomes triggered when conditions are met.
  • Rules — The individual columns that combine conditions and actions.
These compartments aren’t arbitrary. They create a mental model that maps directly to how business logic is evaluated: what is the state? What should happen?
When you use decision table compartments correctly, you avoid missing edge cases. For example, in an insurance underwriting table, you’ll see how each combination of age, medical history, and lifestyle is tested. The compartment structure forces you to list every relevant condition and assess it across all possible values.
Decision Table Conditions and Actions: Precision Matters
Conditions must be atomic and mutually exclusive. Never write “Age is 18 or older” and “Age is over 65” as separate conditions—this leads to overlap and confusion. Instead, define them as discrete, non-overlapping states: “Age < 25”, “Age 25–64”, “Age ≥ 65”.
Actions should be precise, unambiguous verbs: “Approve application”, “Request additional documents”, “Reject application with reason X”. Avoid vague terms like “Handle case” or “Take next step”.
Here’s a real-world example from my work in credit scoring:
Condition Income ≥ $75,000 Debt-to-Income Ratio ≤ 36% Bank Account Age ≥ 12 months
Rule 1 Yes Yes Yes
Rule 2 Yes No Yes
Action Approve Request additional documentation Refer to underwriter
This example shows how decision table conditions and actions are aligned with clear, testable logic. Every rule is traceable, and every outcome is predictable.
Decision Table Rules Columns: How to Build Them Correctly
Every decision table must answer a single question: What’s the decision?. Whether it’s “Should this claim be paid?” or “Is this user eligible for a discount?”
Then, for each rule column, systematically combine all possible values of the conditions. This is where decision table rules columns become powerful.
If you have three conditions—each with two values (Yes/No)—you’ll have 2×2×2 = 8 rules. That’s not just a count—it’s a test of completeness.
Here’s a checklist for building correct decision table rules columns:
  1. Identify all input variables.
  2. Define each condition’s valid values (e.g., “High”, “Medium”, “Low”).
  3. Generate all combinations using a systematic method (e.g., binary counting or truth table logic).
  4. Eliminate impossible or redundant combinations early.
  5. Ensure every column maps to a valid business outcome.
Never skip the combination phase. I’ve seen teams skip it and end up with gaps—like missing a scenario where income is high but debt is too high. That’s an error that surfaces after deployment.
Notation and Clarity: Avoid Common Pitfalls
Notation matters. Use consistent, plain language across all conditions and actions.
Never use abbreviations without definition. “M” for “Married” might be clear to you—but not to someone reviewing the table six months later.
Avoid ambiguity in conditions. “Good credit” is subjective. Instead, define: “Credit Score ≥ 700”.
Use standardized symbols:
  • Y for Yes
  • N for No
  • - or for “don’t care” or “irrelevant”
But be cautious: “Don’t care” should only be used when the outcome doesn’t depend on that condition. Overusing it leads to confusion and hidden logic.
Decision Table Compartments: A Visual and Analytical Framework
The four compartments aren’t just for layout—they’re a diagnostic tool.
When reviewing a decision table, ask:
  • Is the decision clearly named?
  • Are all conditions clearly defined and mutually exclusive?
  • Do actions correspond to rules?
  • Are all combinations covered?
  • Are there overlapping or conflicting rules?
This framework is how you catch errors early. In a health care eligibility table, I once found a rule where “Medicaid status = Yes” led to “Approve”, but another rule with “Medicaid status = No” also said “Approve”. That wasn’t a logic error—it was a redundancy. Fixing it saved the team from over-issuing benefits.
What is the standard structure of a decision table?
The standard structure places rules as columns, conditions and actions as rows. The table is divided into four compartments: decision name, conditions, actions, and rules. This format ensures clarity, completeness, and consistency.
How do I define decision table rules columns?
Define rules columns by generating all valid combinations of conditions. Use a systematic approach like binary counting or truth table generation. Each column must represent a single, unique decision path.
Why are decision table conditions and actions critical?
Conditions define the input states that trigger decisions. Actions define the output behavior. When these are ambiguous or incomplete, the logic becomes unreliable. Clear, atomic conditions and precise actions ensure that rules are predictable and testable.
Can decision table compartments be rearranged?
No—rearranging compartments breaks the logical flow. The standard order (decision, conditions, actions, rules) is designed for human and system processing. Deviating from it increases cognitive load and risk of error.
What are common mistakes in decision table structure?
Common mistakes include overlapping conditions, missing combinations, ambiguous language, inconsistent notation, and using “don’t care” where logic depends on the value. Always validate with a completeness and consistency checklist.
How can I use decision table compartments to improve governance?
Compartments enforce structure, making it easier to audit, trace, and version control. They enable clear ownership—conditions by business analysts, actions by developers, and rules by test leads. This separation supports compliance and maintainability.
