Designing Effective Conditions and Actions
Temps estimé :7 minutes 57 vues
When I see a team stop arguing over whether a rule applies in a specific scenario, and instead say, “Let’s just check the decision table,” I know they’ve moved from theory to real-world use. That clarity isn’t accidental—it comes from structuring conditions and actions with precision.
My 20 years of modeling complex insurance, healthcare, and financial systems taught me one thing: the quality of your decision table starts with how you define its parts. Ambiguous conditions lead to missed exceptions. Vague actions cause inconsistent execution. The goal isn’t just to list rules—it’s to build a living document that reflects intent and survives changes.
This chapter gives you the exact framework I use to design decision table conditions and actions. You’ll learn how to minimize redundancy, ensure full coverage, and maintain readability across teams and over time. By the end, you’ll have a reliable method to turn business logic into a structured, error-resistant format.
Principles of Minimal and Complete Logic
Start not with the rules, but with the decision itself. Ask: What are we deciding? This defines the table’s purpose and keeps scope focused.
Conditions must be minimal yet complete. Aim for the fewest necessary variables that cover all relevant decision paths. Too many conditions create complexity and bloat. Too few leave gaps.
For example, in a credit approval system, “income” and “credit score” are essential. Adding “employment status” may be necessary only when income is below a threshold. But if it’s always relevant, include it in the main condition set.
Rule: One Condition, One Meaning
Each condition should test a single, unambiguous state. Avoid compound conditions like “customer is under 25 or has a job.” Instead, break these into separate conditions: “Age < 25” and “Employed.”
Why? Because it allows precise rule grouping, simplifies testing, and avoids confusion when logic evolves.
Use Normalized Variable States
Standardize how you express states: use consistent phrasing, capitalization, and terminology.
For example:
  • ✅ Use “Yes” / “No” or “Active” / “Inactive” consistently.
  • ❌ Avoid “Yes,” “Y,” “Active,” “On,” “TRUE” — they create inconsistency.
  • ✅ Define all states clearly in a glossary or metadata section.
Avoid ambiguous terms like “high risk” or “good credit.” Define them numerically: “Credit Score < 600” or “Debt-to-Income Ratio > 40%.”
Designing Clear, Actionable Actions
Actions are the outcome of a rule. They must be precise, measurable, and executable. Vague actions like “process the request” or “review status” fail in automation.
Instead, use verbs in the imperative mood: “Approve loan,” “Reject application,” “Send notification,” “Escalate to manager.”
Key Criteria for Action Definition
  • Atomicity: Each action should be a single, indivisible step.
  • Triggers: Clearly define when it executes—immediately, after delay, or in sequence.
  • Ownership: Assign system entities where applicable: “Create audit log entry,” “Update customer record in CRM.”
Example: Instead of “Update status,” write “Set application status to ‘Pending Underwriting’ and schedule review in 48 hours.”
Use Decision Table Actions Definition for Automation
When integrating with rule engines or BPMN workflows, actions must map cleanly to system behaviors. Use standardized action templates:
Approve Application (Loan ID: {id})
Reject Application (Reason: {reason})
Escalate to Underwriting Team
Send Email to Applicant: 'Your application is under review'
Log Event: 'Application Submitted' to audit trail
This format ensures actions are both human-readable and machine-processable.
Grouping and Prioritizing Rules
Just because a rule applies doesn’t mean it should execute. Priority determines execution order—especially when rules overlap or conflict.
For example, in a loan approval rule, a “High Risk” rule should override a “Standard Approval” rule even if both conditions are met.
Use Priority Columns to Resolve Conflicts
Add a priority column (e.g., High, Medium, Low) and sort rules accordingly. This is standard in most rule engines, but must be explicitly defined in the decision table.
Always validate that higher-priority rules are not superseded by lower ones in the logic flow.
Group by Business Context
Organize rules into logical groups. In a healthcare eligibility system, group rules by:
  • Eligibility by age
  • Eligibility by employment status
  • Eligibility by pre-existing conditions
Grouping improves readability and helps when auditing or delegating rule ownership.
Strategies for Simplification and Maintenance
Even well-structured decision tables can become unwieldy. Here’s how to keep them maintainable.
Apply the Rule of Three
If a condition has more than three distinct states, reconsider whether it should be split. For example:
  • “Credit Score” → Excellent, Good, Fair, Poor → Consider splitting into “Credit Score < 600” and “Credit Score ≥ 600.”
  • “Income Level” → Low, Medium, High, Premium → Break into “Income < $40k”, “$40k–$80k”, “> $80k.”
Three states are often sufficient for meaningful decision thresholds.
Eliminate Redundant Rules
Check for duplicate actions under different conditions. If two rules both result in “Reject application,” and one has a broader condition, the narrower one may be redundant.
Use a decision table comparison tool or manually check for overlapping conditions. Remove any rule where all outcomes are already covered by a higher-priority rule.
Use Wildcards Judiciously
“Don’t care” or “*” can reduce table size, but only when the outcome is truly independent of that variable.
Example: If “Age” doesn’t affect the outcome of a rule, “*” is acceptable. But if age thresholds matter (e.g., under 18), do not use a wildcard.
Validate for Completeness
Use a truth table or combination matrix to verify coverage. For n conditions with k states each, check that all k^n combinations are accounted for—or explicitly excluded.
If certain combinations are impossible (e.g., “Not employed” and “Has full-time job”), document this and ensure the table reflects validity constraints.
Decision Table Conditions Design: Checklist
  • Each condition tests a single, well-defined variable.
  • Condition states are mutually exclusive and collectively exhaustive (MECE).
  • Use consistent, standardized values (e.g., “Yes”/“No”, not “Y”/“N”).
  • Define all terms in a glossary or metadata section.
  • Avoid compound logic in condition rows unless absolutely necessary.
Decision Table Actions Definition: Checklist
  • Actions use imperative verbs: “Approve,” “Reject,” “Notify.”
  • Each action is atomic and executable.
  • Actions include sufficient context (e.g., “for Loan ID: 12345”).
  • Actions are compatible with workflow or rule engine integration.
  • Actions are traceable to business objectives or compliance requirements.
How do I avoid missing combinations in my decision table?
Start by mapping all possible combinations using a grid or matrix. For three conditions with two states each, you need 8 rules. Use a tool to generate all combinations, then prune only those that are logically invalid or redundant.
Can I use decision table conditions design for software-based rule engines?
Absolutely. Tools like Drools, IBM Opl, and Visual Paradigm translate decision tables directly into rule sets. But only if conditions and actions are well-defined and standardized.
Why are my decision table actions definition not working in production?
Most likely, actions are too vague or lack context. “Process the request” isn’t executable. Ensure actions specify the object, action, and any relevant parameters. Use templates from the previous section to standardize output.
How do I handle mutually exclusive conditions in decision tables?
Use a validation step: check that no two rules fire simultaneously with conflicting outcomes. If they do, assign priority or introduce a guard condition to prevent overlap. For example, “If credit score < 600, reject” should take precedence over “Approve if income > $100k.”
When should I use wildcards in conditions?
Only when the variable does not affect the outcome. For example, if a rule applies regardless of age, use “*” for age. But if age matters, list explicit ranges. Never use wildcards to hide logic.
How often should I review decision table conditions design and actions definition?
Review after every major business change, system integration, or audit. Update the table with input from stakeholders, QA, and operations. Treat decision tables as living documents—not static artifacts.
