Formulating the Implementation Plan: From Model to Execution
Leitura estimada: 7 minutos 51 vistas
One decision separates success from stalled transformation: whether you plan the rollout before validating the model. Too many teams begin with a to-be process and immediately assign tasks. That’s a trap. The real breakthrough happens when you pause, assess dependencies, sequence phases, and build a clear, time-bound rollout plan that accounts for change fatigue, technical handoffs, and stakeholder capacity.
I’ve led over 40 BPR initiatives. The ones that failed often had perfect diagrams—beautiful, optimized, and technically sound—but no execution plan. The ones that succeeded? They started with a rollout strategy, not just a design. This chapter walks you through turning your redesigned process into a living execution blueprint. You’ll learn how to sequence tasks, manage risk, and use Visual Paradigm’s Gantt chart to align teams, avoid bottlenecks, and keep momentum.
If you’re serious about process re-engineering execution, this is where theory becomes action. You’ll learn how to avoid common BPR project management missteps, assign realistic timelines, and build a plan that resists the natural pull toward “just get it done.” We’ll build the foundation for sustainable transformation—step by step.
Turning Design into a Rollout Strategy
Redesigning a process in BPMN is just the start. The real challenge lies in translating that model into a phase-based rollout plan. The key is not just what you change—but how, when, and with whom.
Before you assign tasks, ask: What’s the critical path? Which steps depend on others? Can we pilot in one department before scaling? These questions dictate your rollout structure.
Define Rollout Phases Based on Risk and Readiness
Not all processes can be transformed at once. Use a triage approach:
  • High risk, high impact: Implement in phases with pilot teams.
  • Low risk, high impact: Roll out across departments after validation.
  • Low risk, low impact: Automate or refine in parallel with core rollout.
For example, when reengineering an accounts payable workflow, we piloted the new invoice validation step with the procurement team before rolling it out to finance and operations. This allowed us to catch system integration gaps early—saving over 120 hours in rework.
Map Dependencies and Critical Path
Every process step has dependencies. Use a dependency matrix to identify which tasks must finish before others can begin. This is where Visual Paradigm’s Gantt chart shines.
Key dependencies to track:
  • System upgrades must precede workflow activation.
  • Training must conclude before live usage.
  • Data migration must complete before the new process starts.
These aren’t just logistics—they’re risk points. Missing one leads to delays, rework, or failure to meet KPIs.
Building the BPR Implementation Plan
A solid BPR implementation plan isn’t a timeline. It’s a decision framework grounded in execution reality.
Step 1: Break Down the To-Be Process into Execution Tasks
Use your to-be BPMN model as a foundation. For each major task, ask: Who owns it? What resources are needed? When must it be complete?
Example: The “Invoice Approval” step in a procurement process isn’t one task. It breaks into:
  • Receive invoice from vendor
  • Verify PO match
  • Route for approval
  • Log in system
  • Update payment schedule
Each becomes a discrete task in your WBS. Now you can assign owners, durations, and dependencies.
Step 2: Estimate Effort and Allocate Resources
Underestimate timelines, and your project derails. Overestimate, and you waste capacity. Use historical data from past BPR projects to calibrate effort.
Task Estimated Duration (days) Owner Resource Type
System integration test 5 IT Lead Technical
Stakeholder training 3 Change Manager Human
Process validation 4 Operations Lead Process
This table becomes the backbone of your Gantt chart. Visual Paradigm auto-generates timelines from this data.
Step 3: Sequence with Gantt Charts for Clarity and Accountability
Visual Paradigm’s Gantt chart is not just a visual aid—it’s your project’s nervous system.
  • Drag tasks onto the timeline.
  • Link dependencies using dependency lines.
  • Assign team members and color-code by department.
  • Flag critical path tasks in red.
I once led a BPR project where the critical path was hidden in the project charter. Only after building the Gantt chart did we see that “data migration” was delayed by six days—because the vendor wasn’t on the chart. That one insight saved two weeks of rework.
Proactive Risk Management in BPR Project Management
Risk isn’t an afterthought. It’s baked into execution.
Identify Risks Early, Not After They Hit
Use a risk register to capture potential threats. Categorize by:
  • Technical: System incompatibility, data loss
  • Organizational: Resistance, lack of sponsorship
  • Resource: Staff shortages, skill gaps
  • Timeline: Scope creep, dependency delays
For each risk, assign:
  1. Probability (Low/Medium/High)
  2. Impact (Low/Medium/High)
  3. Response plan (e.g., “Implement backup data migration script”)
Build Contingency into the Timeline
Don’t pad the entire project. Instead, allocate buffer time to high-impact, high-probability risks.
Example: If training is high-risk due to low digital literacy, add 2 days of buffer. If the system integration is low-risk, keep the timeline tight. This is how you optimize for reality, not optimism.
Monitor and Reassess Weekly
Process re-engineering execution isn’t a one-way street. Reassess the plan every week.
Ask: Is the critical path shifting? Are new risks emerging? Are team members overloaded?
Use Visual Paradigm’s real-time dashboard to track task completion, resource load, and timeline variance. Adjust the plan—don’t ignore the data.
Key Success Factors for BPR Project Management
The difference between a successful rollout and one that stalls often comes down to how well the team understands their role in the broader chain.
  • Ownership: Assign clear owners—not just “team” or “department.” Specificity drives accountability.
  • Communication cadence: Daily stand-ups for high-risk tasks, weekly syncs for all teams.
  • Feedback loops: After each phase, conduct a “lessons learned” session. Document what worked, what didn’t.
  • Change champions: Identify 1–2 stakeholders per team to advocate for the new process. They’re the bridge between leadership and frontline users.
A well-structured BPR implementation plan isn’t about perfection. It’s about adaptability, transparency, and relentless execution.
How do I handle resistance during process re-engineering execution?
Resistance isn’t a sign of failure—it’s a signal. Identify who resists and why. Is it fear of job loss? Lack of trust in the new system? Address it with involvement: invite key resisters into the design phase, show them the data, and let them co-own the rollout.
Can I implement BPR without a formal project manager?
It’s possible, but risky. BPR project management requires coordination across departments, tech teams, and leadership. Without a central point of control, communication breaks down. Designate a change lead—even if it’s a part-time role—to manage timelines, risks, and stakeholder alignment.
What’s the biggest mistake in BPR implementation planning?
Not aligning the rollout timeline with the actual readiness of people, systems, and data. Rushing a rollout because the model looks perfect leads to failure. The model is the blueprint. The plan is the structure. You need both.
How do I ensure the new process is sustainable after launch?
Don’t stop at go-live. Embed performance monitoring into daily operations. Use KPIs tied to the redesigned process—like cycle time, error rate, or approval speed. Hold monthly review meetings with process owners. Sustainment comes from measurement and reinforcement, not just deployment.
When should I use a pilot versus full rollout?
Pilot for high-risk, complex, or unfamiliar processes. Use full rollout when the process is stable, well-understood, and supported by strong change management. Pilots reduce risk and build confidence.
How often should I update the BPR implementation plan?
Review and update the plan weekly. Adjust for delays, scope changes, or new risks. Visual Paradigm’s real-time collaboration features ensure all stakeholders see the current version. A static plan is a failed plan.
