Advanced Modeling and Integration Practices
Geschätzte Lektüre: 2 Minuten 323 Ansichten
So you’ve built your first CMMN models—good work. But as your cases grow in complexity, you’ll find that basic models start to show cracks. The rigid boundaries of simple case plans don’t handle hierarchical dependencies, nor do they scale well across teams or systems. That’s where advanced CMMN modeling comes in.
This section isn’t about mastering the basics—it’s about mastering the edge. Here, you’ll learn how to structure complex, real-world case models using nested cases CMMN, integrate flexible case logic with structured BPMN and decision logic via DMN, and validate your designs through simulation. These aren’t just theoretical exercises; they’re the tools professionals use to manage high-stakes, knowledge-intensive processes in healthcare, legal services, and finance.
If you’ve ever felt stuck trying to model a case that spans multiple teams or systems, this section will give you clarity. You’ll move beyond one-size-fits-all diagrams and start thinking in terms of dynamic, interconnected case ecosystems.
Explore how to build scalable, adaptive case models that work across organizational boundaries and integrate with other enterprise standards.
  • Nested Case Models and Sub-Case Strategies: Learn to structure hierarchical case models, manage subcases, and trigger dependencies based on real-time data and conditions—ideal for large-scale investigations or multi-tier approvals.
  • Integrating CMMN with BPMN and DMN: See how hybrid modeling enables both structured workflows and adaptive decision-making. This is where CMMN BPMN DMN integration makes sense—no more siloed diagrams.
  • Executing and Simulating CMMN Models: Validate your models before deployment. Learn how to simulate CMMN behavior across different scenarios to test logic, performance, and real-time adaptability.
  • Design and manage nested cases CMMN for complex, multi-level processes
  • Integrate CMMN with BPMN and DMN using practical, real-world examples
  • Simulate and test CMMN models to uncover logic gaps before execution
  • Align case models with enterprise systems, ensuring smooth runtime coordination
  • Use hybrid modeling to combine structured and adaptive behaviors in a single solution
  • Apply CMMN subcase logic to manage dependencies and data flow across case levels
These aren’t just advanced skills—they’re the foundation for professional-grade case management modeling. Whether you’re working on a regulatory review, a claims investigation, or a customer dispute, you’ll now have the tools to build models that adapt, scale, and perform.
