Case Management in the Age of Digital Transformation
Geschätzte Lektüre: 7 Minuten 50 Ansichten
When I first stepped into a large financial services firm, the claim processing system was a tangled web of hardcoded rules and rigid workflows. Agents weren’t following a timeline—they were reacting. That’s the heart of digital case management: not automation for its own sake, but structured flexibility for complex, human-driven processes.
Digital case management isn’t about replacing people with bots. It’s about empowering experts to make real-time decisions within a coherent framework. The real value lies in adaptive process modeling—where the path isn’t predefined, but guided by context, triggers, and experience.
Over two decades of working with organizations across insurance, healthcare, and legal services has taught me one truth: every case is different. But not all differences are chaos. CMMN helps us recognize patterns in unpredictability and build models that respond, not rigidly follow.
By the end of this chapter, you’ll understand how to model dynamic, real-world scenarios using CMMN, apply adaptive process modeling principles, and use meaningful case management examples to guide your design—no templates, no shortcuts.
Why Adaptive Process Modeling Is Essential
Traditional BPMN excels at structured, repeatable processes. But what happens when the work is unpredictable? When decisions hinge on expert judgment, document quality, or evolving circumstances?
Enter adaptive process modeling. This approach allows you to define a framework—not a sequence—so the case can evolve based on real-time inputs. You’re not designing a script. You’re designing a decision space.
Consider a medical intake case. The triage nurse may initiate tests, but whether a specialist consult is needed depends on lab results, patient history, and clinical judgment. The path forward isn’t pre-determined. It’s event-driven, context-sensitive, and dynamic.
That’s where CMMN shines. It doesn’t force a linear flow. It lets the case progress based on conditions, events, and decisions. This is adaptive process modeling in motion.
Key Principles of Adaptive Process Modeling
  • Model the context, not just the steps – Include data, triggers, and goals early in the case plan.
  • Use sentries to control transitions – Define when a task becomes available based on events or conditions.
  • Design for human autonomy – Let experts decide the next action, not a system rule.
  • Track progress through milestones – Even in unstructured workflows, milestones provide visibility.
  • Revisit and adapt – The model evolves as new case patterns emerge.
CMMN vs. BPMN: When to Use Each
People often ask, “Should I use BPMN or CMMN?” The answer isn’t binary. It’s about intent.
BPMN is ideal for processes that are predictable, repeatable, and rule-bound. Digital case management, on the other hand, thrives in environments where the path is shaped by events, data, and expert decisions.
Think of it this way: BPMN is a scheduled flight. CMMN is a helicopter. One flies a fixed route. The other can adjust mid-air, responding to weather, terrain, or new objectives.
Here’s a practical comparison:
Aspect BPMN CMMN
Best for Structured workflows Unstructured, knowledge-intensive work
Control flow Predefined sequence Event-driven, adaptive
Decision points Gateways Sentries, milestones
Human involvement Task-level Case-wide, role-based
Use case example Loan approval Insurance claim review
Real-World Example: Claim Review in Insurance
Let’s walk through a case management example from insurance. A claim comes in with a damaged vehicle. The initial action is to assess the damage. But the next task depends on multiple factors:
  • Is the damage under $5,000? → Auto-approve if no dispute.
  • Is the vehicle totaled? → Trigger appraisal and legal review.
  • Was the accident reported within 72 hours? → If not, flag for fraud review.
This isn’t a flowchart. It’s a context-sensitive case. In CMMN, we model this with stages and sentries:
  • Stage: Initial Assessment – Task: Damage Inspection (sentry: claim submitted)
  • Stage: Decision Point – Task: Review Threshold (sentry: damage value > $5k OR not reported in time)
  • Stage: Risk Assessment – Task: Fraud Check (sentry: triggers based on delay or anomaly)
Each task activates only when its sentry condition is met. This is adaptive process modeling at its finest.
Building a Case Plan: A Step-by-Step Approach
Creating a robust case model isn’t about drawing every possible path. It’s about defining the framework that supports it.
Here’s how I guide teams through modeling a new case:
  1. Identify the case goal – What is the desired outcome? (e.g., “Approve or deny claim with justification”)
  2. Define the main stages – What are the logical phases? (e.g., “Review”, “Assessment”, “Decision”)
  3. Break down tasks within each stage – Who does what? What data is needed?
  4. Set sentry conditions – What triggers a task? (e.g., “After photos uploaded and damage report received”)
  5. Define milestones – When is the case “on track”? (e.g., “All documents received”)
  6. Link to case file items – What data is stored? (e.g., claim ID, vehicle details, photos)
Each step is flexible. The model doesn’t lock in. It evolves as new case management examples emerge.
Case Management Example: Customer Support Ticket
Consider a support case where a user reports a login issue. The agent investigates. The path forward depends on:
  • Is it a password reset? → Send reset link.
  • Is the account locked? → Unlock and notify.
  • Is there evidence of a breach? → Escalate to security team.
Using CMMN:
  • Stage: Initial Contact – Task: Reproduce Issue (sentry: ticket created)
  • Stage: Diagnosis – Task: Check Logs (sentry: user confirms issue)
  • Stage: Resolution – Task: Reset Password (sentry: no breach detected)
  • Stage: Escalation – Task: Alert Security (sentry: anomaly detected)
Each task is conditionally enabled. The case adapts in real time. This is digital case management in action.
Even experienced modelers fall into traps. Here are the top three, with fixes:
  • Over-modeling the path – Don’t try to define every possible outcome. Focus on key decision points and triggers.
  • Ignoring case file data – The case file isn’t a side note. It’s the backbone of the case. Model data dependencies early.
  • Forgetting to validate with users – Experts know their workflows best. Involve them in the modeling process, not just the validation.
Remember: a CMMN model isn’t a deliverable. It’s a living tool. Treat it as such.
Final Thoughts: The Future of Digital Case Management
Digital case management is not a trend. It’s the future of enterprise work in knowledge-intensive environments. As AI tools begin to predict outcomes and recommend actions, CMMN becomes even more valuable—not as a static diagram, but as a dynamic decision engine.
Adaptive process modeling is not about abandoning structure. It’s about building structure that bends. It’s about trusting people, not forcing them into workflows that don’t fit.
When you model with CMMN, you’re not just drawing boxes and arrows. You’re designing a space where expertise, context, and data coexist. And that, ultimately, is what digital case management is all about.
What is digital case management in practice?
Digital case management is the use of adaptive process modeling to handle complex, unstructured work that requires expert judgment. It’s used in insurance, healthcare, and legal services to manage cases where the path isn’t predefined.
How does adaptive process modeling differ from traditional BPMN?
Adaptive process modeling allows workflows to evolve based on events, data, and decisions. BPMN enforces a fixed sequence. CMMN supports dynamic, event-driven control, ideal for unpredictable scenarios.
Can you give a real example of case management?
Yes. In insurance claim processing, a case may require an appraisal if damage exceeds $5,000, or a fraud review if the claim is delayed. The next step depends on conditions, not a fixed path—this is a case management example.
When should I use CMMN instead of BPMN?
Use CMMN when the process is knowledge-intensive, decision-heavy, or event-driven. Use BPMN when the process is predictable, repeatable, and rule-based.
How do sentries work in CMMN?
Sentries control when tasks become available. They can be based on events (e.g., “after document uploaded”), data (e.g., “if claim amount > $10,000”), or time (e.g., “after 72 hours”). They are the gatekeepers of case progression.
Is CMMN suitable for large-scale enterprise use?
Absolutely. CMMN integrates well with BPMN and DMN in hybrid models. With proper governance, modular design, and version control, CMMN scales for enterprise-level case management.
