Common BPMN Modeling Mistakes and How to Avoid Them
Temps estimé :8 minutes 75 vues
One of the most common misconceptions I see when reviewing beginner diagrams is the belief that a BPMN model must be complex to be valuable. In reality, clarity trumps complexity every time. A well-structured process map should be easy to follow, even for someone without a technical background. Yet, I still see models with tangled flows, inconsistent symbols, and ambiguous decision logic—errors that undermine trust and collaboration.
These aren’t just style issues. They’re roadblocks. Misplaced gateways, missing end events, or unconnected sequence flows can distort the entire process, leading to misunderstandings in automation or stakeholder alignment. The good news? Most of these BPMN mistakes are preventable with a few foundational practices.
Over 20 years of modeling, I’ve worked with teams from finance to healthcare, and the same errors keep appearing—repeatedly. This chapter isn’t about shaming anyone for getting it wrong. It’s about building muscle memory for what works, what doesn’t, and how to fix it. You’ll walk away with a clear checklist of do’s and don’ts, practical examples, and real-world fixes for common BPMN error correction.
If you’ve ever looked at a diagram and thought, “I’m not sure what happens here,” this is the guide for you. Let’s go through the real trouble spots and learn how to build models that communicate clearly and last.
Common BPMN Mistakes and How to Fix Them
1. Using Gateways Without Clear Conditions
One of the most frequent BPMN mistakes is placing a gateway without a defined condition. You’ll see it often: a decision point with no label on the outgoing sequence flows.
Gateways are meant to express conditions. If a parallel or exclusive gateway appears with no labels, you’re asking people to guess. That’s not modeling—it’s guesswork.
Always label your sequence flows with clear, unambiguous conditions. Instead of “Yes” or “No,” write “Invoice Approved” or “Customer Credit Score ≥ 700.” These conditions should come directly from the business rule, not subjective interpretations.
BPMN do’s and don’ts:
  • Do label every sequence flow from a gateway with a condition.
  • Don’t leave flows unlabeled just because they seem obvious.
  • Do use language consistent with business rules, not technical jargon.
  • Do test conditions against real data—what if the score is exactly 700?
2. Misusing Event-Based Gateways
Event-based gateways are powerful, but often misapplied. A common mistake is using them to represent a decision, when they’re actually for event-driven branching.
For example, you might see a gateway with a “Payment Received” event and a “Payment Delayed” event. That’s correct. The process waits for either event to trigger the next step. But if you use it to split based on conditions like “Amount > $1000,” you’re misunderstanding its purpose.
Save event-based gateways for scenarios where the next activity depends on an external event—like a message arriving, a timer expiring, or a system status update.
BPMN troubleshooting tip: Ask yourself: Is this decision based on a condition, or on an external occurrence? If it’s the latter, use an event-based gateway. If it’s the former, use an exclusive or parallel gateway.
3. Ignoring Flow Consistency and Sequence Flow Rules
Sequence flows are the backbone of BPMN. But beginners often break the rules: starting a flow from the middle of a shape, ending on a non-event, or using lines to cross without clear hierarchy.
Sequence flows must start from the outward edge of a shape and end at the inward edge of the next. Flows should never “cut through” a shape or start from the center.
Use flow lines only between compatible elements. A sequence flow should connect an activity to an event, or an event to a gateway—never jump directly from one task to another without a clear reason.
Checklist for flow integrity:
  • Every sequence flow starts from the right edge of one node, ends at the left edge of the next.
  • Flow lines don’t intersect unless necessary—and then they’re clearly broken.
  • Every flow must have a clear start and end point, never “floating” in space.
4. Overusing Orphaned Events and Activities
It’s tempting to place an event or activity in a diagram just because it feels like it “fits.” But every element must be part of a valid flow.
An event without a sequence flow in or out is useless. An activity with no incoming or outgoing flow is an orphan—and a red flag in any BPMN model.
Every event must be connected to a sequence flow. Start and end events are especially critical. A process must begin with a start event and end with an end event. Missing either breaks the model’s integrity.
  • Do ensure every event has at least one incoming and one outgoing flow.
  • Do use start and end events to define process boundaries clearly.
  • Don’t place an event in the middle of a flow just for visual decoration.
  • Do validate that no activity exists in isolation.
5. Confusing Tasks and Sub-Processes
Beginners often treat every activity as a standalone task, even when it’s a complex workflow itself. This leads to overly large, unreadable diagrams.
When a task has multiple internal steps—like “Review Request,” “Check Documents,” “Contact Supplier”—you should group it under a sub-process. That’s what they’re for.
Use a sub-process to hide complexity. Label it clearly: “Supplier Onboarding” or “Customer Verification.” Then, use a “collapsed” or “expanded” view depending on the audience.
When to use sub-process:
  • When a task has more than 3 logical steps.
  • When the steps are repeated across multiple processes.
  • When you want to hide detail for high-level diagrams.
6. Overlooking Swimlane and Responsibility Clarity
One of the most underused features in BPMN is the swimlane. Yet, it’s essential for accountability.
When a task appears without a swimlane, the modeler assumes responsibility. But if the same task appears in multiple swimlanes, the reader assumes it’s shared. That’s not enough.
Always assign every task and decision to a specific swimlane—whether it’s a department, role, or system. Label it clearly. Use consistent naming: “Finance Team,” “Customer Portal,” “Automated System.”
A common BPMN error correction is to add a missing swimlane. If a task is performed by a person or system, it must be in a lane.
Quick Reference: Common BPMN Errors and Fixes
BPMN Mistake Why It’s Wrong How to Fix
Unlabeled gateways Creates ambiguity in decision logic Add clear, business-aligned conditions to each flow
Event-based gateway for decisions Confuses event triggers with conditions Use exclusive gateway for conditions; event-based only for external events
Flow lines crossing or starting mid-shape Breaks visual flow and causes confusion Start flow from right edge, end at left edge; avoid crossing unless necessary
Orphaned events or tasks Breaks process continuity and model validity Ensure every element has at least one incoming and one outgoing flow
Using tasks for complex workflows Overwhelms the diagram and hides structure Group internal steps into a sub-process with a clear label
Missing swimlane assignment Leaves responsibility unclear Assign every task to a specific swimlane based on role or system
Can I use multiple start events in one BPMN diagram?
Yes—but only if they represent distinct, parallel processes. For example, “Payment Request Received” and “Customer Registration Completed” could both be start events. But avoid multiple starts for the same process. Use a single start event and branch with gateways.
Do I need to use sub-processes even if the workflow is simple?
No. Save sub-processes for workflows with more than 3–4 steps or repeated logic. Keep simple tasks as single activities. The goal is clarity—not complexity.
What’s the difference between a gateway and a decision point?
Gateway is the BPMN symbol. Decision point is a concept. The gateway represents the decision. Always label flows from the gateway to reflect the decision logic.
Can I have a sequence flow that loops back to a previous task?
Yes—but only if it represents a valid loop condition. Use a loop gateway or a conditional flow. Avoid circular flows that don’t resolve. Always ensure the loop has an exit condition.
Should all BPMN models include swimlanes?
No—but you should include them whenever responsibility matters. Simple workflows can be modeled without swimlanes, but for cross-functional processes, they’re essential.
How do I know if my BPMN model is valid?
Check for: start and end events, valid sequence flow connections, labeled gateways, assigned tasks, and no orphaned elements. Use a tool like Visual Paradigm’s validation feature to catch errors automatically.
Every successful BPMN model starts not with perfection, but with intention. If you keep the core rules in mind—flow integrity, clear conditions, responsible assignment, and simplicity—you’ll avoid the most common BPMN mistakes.
Remember: clarity is the goal. If someone unfamiliar with the business can follow your diagram in under a minute, you’ve done it right. Keep practicing, keep validating, and keep improving. You’re not just learning BPMN—you’re learning to speak the language of process with confidence.
