Working with Pools, Lanes, and Messages
Temps estimé :7 minutes 126 vues
One of the most common mistakes I see in beginner BPMN diagrams is treating every process as a single, isolated flow. This leads to tangled, confusing models that fail to show who does what. The real breakthrough comes when you stop thinking about process flow alone and start modeling collaboration. That’s where BPMN pools and lanes come in—they’re not just visual decoration. They’re the backbone of how processes interact across departments, teams, or even organizations.
When you shift your mindset from “what happens next?” to “who’s involved, and how do they communicate?”, you unlock clarity. The key is understanding how pools represent participants and lanes define responsibilities. This isn’t a design choice—it’s a structural necessity for real-world workflows.
By the end of this chapter, you’ll know exactly how to structure a BPMN collaboration diagram with accurate pools and lanes. You’ll understand when and how to use message flow BPMN to show communication, and how BPMN swimlanes make responsibilities unambiguous. No more guessing what role each task belongs to.
Understanding BPMN Pools and Lanes
BPMN pools and lanes are the foundation of collaboration diagrams. They allow you to visualize interactions between different participants in a business process.
What Is a BPMN Pool?
A pool is a container that represents a participant in a collaboration. This could be a company, department, or system. Think of it as a designated role in a conversation.
Each pool contains one or more lanes, which define specific responsibilities within that participant.
What Are BPMN Lanes?
Lanes break down the responsibilities within a pool. They’re like swimlanes in a team meeting—each lane shows what a specific role or team is responsible for.
For example, in a loan approval process, one pool might be “Bank,” and its lanes could be “Loan Officer,” “Credit Department,” and “Manager.”
How They Work Together
When you combine pools and lanes, you create a clear picture of who does what. The diagram becomes a map of responsibility, not just a sequence of steps.
Every task or activity should fall into a single lane. This eliminates ambiguity. If you see a task that spans multiple lanes, it’s likely a signal that the process needs restructuring.
Constructing a Clear BPMN Collaboration Diagram
Building a collaboration diagram isn’t about adding more boxes. It’s about organizing responsibility with precision.
Step-by-Step Setup
  1. Identify participants – Ask: Who is involved in this process? Each major actor gets its own pool.
  2. Determine responsibilities – Break down roles within each participant. Each distinct role becomes a lane.
  3. Assign activities – Place every task in the correct lane. No exceptions.
  4. Connect with message flows – Use message flow BPMN to show communication between lanes, not sequence flow.
Visual Example: Loan Approval Process
Imagine a loan request moving from a customer to a bank. The bank has three roles: Loan Officer, Credit Check, and Manager.
Each role is a lane inside the “Bank” pool. The customer is a separate pool.
This structure makes it instantly clear: the customer sends a request (message flow), the loan officer receives it (in their lane), then forwards it to credit, and so on.
Mastering Message Flow BPMN
Message flows are the lifeblood of collaboration. They represent communication between participants, not execution steps.
Key Rules for Message Flow
  • Use message flow BPMN only between pools.
  • It is a dashed line with an open arrowhead.
  • It should not cross lanes within the same pool.
  • It conveys intent: a message is sent, not a decision made.
Don’t confuse message flow with sequence flow. Sequence flow is internal—within a process. Message flow is external—between processes.
Common Mistake: Mixing Flow Types
Beginners often use sequence flow between pools. This is incorrect. Sequence flow shows execution order. Message flow shows communication.
When a customer submits a form, the system sends a notification to the bank. That’s message flow. The bank then processes the request—sequence flow within its pool.
Best Practices for BPMN Swimlanes
Swimlanes are the visual manifestation of lanes. They make responsibility visible at a glance.
Design Tips for Clarity
  • Label lanes clearly – Use titles like “Sales Team,” “IT Support,” or “Customer.” Avoid vague labels like “Team A.”
  • Keep lanes horizontal or vertical – Choose consistency. Most collaboration diagrams use horizontal lanes.
  • Group related tasks – Don’t scatter similar activities across multiple lanes. Keep related work together.
  • Avoid overloading – If a lane has more than 6–7 tasks, consider splitting it or using a sub-process.
When to Use a Sub-Process in a Lane
If a lane contains complex or recurring work (like “Verify Identity” or “Update CRM”), consider wrapping it in a sub-process. This keeps the main diagram clean and readable.
Sub-processes are like hidden layers—only expand if needed. They don’t change the external structure, just the internal detail.
Real-World Example: Customer Onboarding Workflow
Let’s walk through a real example using BPMN swimlanes and message flow BPMN.
Pool Lane Key Activities
Customer Customer Submit application, upload documents
Bank Onboarding Team Review documents, initiate KYC check
Bank Credit Department Run credit check, score applicant
Bank Manager Approve or reject, notify customer
Messages flow between pools:
  • Customer → Bank: Submit application (message flow)
  • Bank Onboarding → Credit: Forward for review (message flow)
  • Bank Credit → Manager: Provide score (message flow)
  • Manager → Customer: Final decision (message flow)
The sequence flow stays inside each lane for execution steps. This structure ensures that every participant knows their role and when they need to act.
Why You Should Use BPMN Collaboration Diagrams
These models are not just for show. They serve real business purposes:
  • Clarity in cross-functional workflows – Prevents misunderstandings in shared responsibilities.
  • Foundation for automation – Clear lanes and message flows make integration with workflow engines easier.
  • Stakeholder alignment – Executives, developers, and team leads all understand the workflow the same way.
  • Traceability and auditability – You can track who did what and when.
When you model a process without pools and lanes, you risk creating a “black box” that only one person fully understands.
With them, the process becomes a shared language. That’s the power of BPMN swimlanes.
What is the difference between a BPMN pool and a lane?
A pool represents a participant in a collaboration—like a company or department. A lane is a subdivision within that pool that defines a specific role or team responsible for certain tasks. Think of a pool as a room, and lanes as desks in that room.
Can I use message flow BPMN within the same pool?
No. Message flow BPMN is strictly between pools. If communication happens within a process, use sequence flow. Message flow is for cross-participant interaction.
How do I decide how many lanes to include?
Include one lane for each distinct role responsible for a unique set of actions. If two roles perform similar tasks, consider combining them. If a role is too broad, break it into sub-lanes or use a sub-process.
Do I need to include every single employee in a lane?
No. Lanes represent roles, not individuals. For example, “Sales Team” is a role. Include the team or function, not specific names.
Can I have multiple pools with no message flow between them?
Yes. But if they’re part of the same business process, it’s likely they should communicate. No message flow suggests the pools are independent—perhaps different processes entirely.
Is there a standard way to organize swimlanes?
Yes. Use horizontal lanes for top-to-bottom flows (common in customer-facing processes). Use vertical lanes if you’re modeling system-to-system interactions. Keep the layout consistent across diagrams for better readability.
