Core Concepts Every Modeler Must Know
Temps estimé :6 minutes 58 vues
Every effective BPMN diagram begins with a clear grasp of its foundational elements. There’s no need to memorize every symbol at first—just understand how events, activities, and gateways work together to form a logical flow. Think of them not as isolated shapes but as building blocks that speak the language of process.
As someone who’s guided hundreds through their first BPMN model, I’ve found that beginners often overthink complexity. The truth is, you don’t need advanced tools or perfect layout to start. What matters is consistency and clarity. Each element serves a purpose: events mark moments, activities represent work, and gateways control decision points.
By focusing on these core concepts, you’ll learn to interpret and build diagrams that communicate effectively across teams. This chapter gives you the essential knowledge to move from blank canvas to meaningful workflow—without the confusion.
The Three Pillars of BPMN: Events, Activities, and Gateways
What is a BPMN Event?
Events signal something that happens—either at the start, end, or somewhere in the middle of a process. They are always represented as circles and define a moment in time.
There are three main types:
  • Start Events: Trigger the process. Can be message-based, timer-triggered, or conditional.
  • Intermediate Events: Occur during a process—often to capture a condition, cancellation, or message.
  • End Events: Signal the conclusion of a process. Can represent normal completion, errors, or termination.
For example, a “Customer places order” event is a start event. An “Invoice received” event might be an intermediate event. A “Process completed” message would be an end event.
Understanding BPMN Activities
Activities are the actual work being done. They appear as rectangles with rounded corners and represent a task or a group of tasks.
There are three types:
  • Task: A single work item—like “Approve invoice” or “Send confirmation email.”
  • Sub-Process: A set of activities nested within a larger task. Use this for complex steps that don’t need full detail upfront.
  • Transaction: A transactional activity that includes a boundary event and can fail or roll back.
When modeling, ask: “What is the actual work happening here?” If it’s a single, atomic action, it’s a task. If it’s a cluster of related actions, consider grouping them into a sub-process.
Think of a task like a single instruction in a recipe. You can’t break it down further. But a sub-process is like a full cooking step—bake the cake—which contains multiple smaller actions.
Mastering the Gateway in BPMN
Gateways are the decision-makers of a BPMN diagram. They control how flows branch and merge, using logical conditions to guide execution.
  • Exclusive Gateway (XOR): Only one outgoing flow can be taken. Think “If this, then that.”
  • Parallel Gateway (AND): All outgoing flows are taken simultaneously. Use for steps that must all happen.
  • Inclusive Gateway (OR): One or more outgoing flows can be taken. Ideal for “if any of these conditions apply.”
Here’s a common real-world example:
When processing a loan application:
  • Use an exclusive gateway: “Is credit score above 700?” → Yes → Approve, No → Reject.
  • Use a parallel gateway: “Verify income” and “Check employment history” → both must run.
  • Use an inclusive gateway: “Does applicant have at least one of these documents?” → Passport, ID card, or driver’s license.
Always ensure that gateways are used to represent real decisions—never just for visual separation.
BPMN Elements Guide: How to Use Each Effectively
Understanding the core elements is only half the journey. Applying them correctly is where clarity and communication shine. Here’s how to align your modeling with best practices.
BPMN Tasks and Events: When to Use What
Don’t confuse a “task” with an “event.” A task is an action. An event is a trigger or milestone.
Use a task when you’re describing what someone or something does—like “Review application,” “Generate report,” or “Update database.”
Use an event when you’re capturing what happens—like “Application submitted,” “System failure detected,” or “Payment received.”
When in doubt, ask: “Is this a moment in time or an action?” If it’s a moment, it’s an event. If it’s a job to be done, it’s a task.
For example, in a customer onboarding workflow:
  • “Customer submits application” → Start Event
  • “Send onboarding email” → Task
  • “Onboarding completed” → End Event
Designing Smarter Flows with the Gateway in BPMN
One of the biggest mistakes beginners make is overusing the exclusive gateway. Remember: if multiple paths must run together, use a parallel gateway. If only one path should be chosen, use XOR. If any of several conditions can trigger, use OR.
Always validate that all outgoing flows from a gateway are accounted for. A missing path can create an incomplete model.
Use gateways to represent real decisions—not assumptions. For instance:
  • “Is the document approved?” → XOR gateway
  • “Is the customer a VIP?” → OR gateway
  • “Verify identity and credit status” → AND gateway
These choices ensure the model reflects real business behavior.
Practical Guidelines for BPMN Modeling
Let’s walk through a simple but realistic example to reinforce everything so far.
Consider a loan approval process:
  1. Start Event: “Loan application received”
  2. Task: “Verify customer identity”
  3. Gateway in BPMN: “Is identity valid?” (XOR)
  4. If yes → “Check credit score”
  5. If no → “Notify applicant: identity not verified” → End Event
  6. “Check credit score” → “Is score ≥ 700?” (XOR)
  7. If yes → “Approve loan” → End Event
  8. If no → “Reject loan” → End Event
This simple flow uses only core elements but captures the logic accurately. The key is to keep the model focused, avoid unnecessary branches, and always link decisions to real business logic.
What are the three primary BPMN elements?
The three core elements are events, activities, and gateways. Events mark moments, activities represent work, and gateways control decision paths.
How do I know which gateway in BPMN to use?
Use XOR for exclusive decisions (one path only), AND for parallel execution (all paths), and OR for inclusive conditions (any one or more). Always tie the choice to actual business rules.
Can I use multiple start events in a single BPMN diagram?
Yes, but each should represent a distinct trigger—like “email received” and “system alert.” Avoid multiple start events unless they represent unique entry points.
Is a task the same as a subprocess in BPMN?
No. A task is a single work item. A subprocess is a group of tasks bundled into a single activity. Use subprocesses to simplify complex steps without losing clarity.
How do events improve process readability?
Events signal key milestones—like when work begins or ends. They make it easier for stakeholders to understand the timeline and flow without reading every task.
What’s the biggest mistake when modeling with BPMN tasks and events?
Confusing events with tasks. Mistaking a “Payment received” event for a “Process payment” task leads to logic gaps. Always ask: “Is this an action or a trigger?”
Mastering these core concepts isn’t about memorizing shapes. It’s about seeing the workflow through the lens of logic, clarity, and real-world behavior. With consistent practice, you’ll begin to think in BPMN—not just draw it.
