Conclusion: Designing with Intent, Not Just Structure
Temps estimé :7 minutes 52 vues
Too many developers treat UML class diagrams as a mechanical exercise in notation—checking boxes for associations, multiplicities, and visibility. That’s a trap. The real power lies not in the diagram itself, but in what it represents: a living expression of design decisions rooted in intent.
After years guiding teams from CRC cards to fully realized class diagrams, I’ve learned this: the best models aren’t those that follow every rule perfectly. They’re the ones where the team can trace every class, method, and relationship back to a clear “why.”
Here, you’ll learn how to move beyond formalism and apply UML design principles with clarity and purpose—anchored in the CRC philosophy and a responsibility-driven mindset. This isn’t about tools. It’s about culture, consistency, and communication.
Why Structure Alone Isn’t Enough
UML is a language. But like any language, it’s not the grammar that conveys meaning—it’s the intent behind the sentence.
A class diagram can be syntactically perfect: correct visibility, accurate multiplicities, well-structured inheritance. Yet if the team can’t explain why the class exists, or what responsibility it owns, it’s just a facade.
Consider this: a class named PaymentProcessor might have a method process(). But if no one can say whether it’s responsible for validation, authorization, or reconciliation, then the method has no behavioral context. The diagram looks complete—but the design is fragile.
This is why design intent modeling is the critical next step after formalizing CRC cards into UML. It’s not about adding more lines. It’s about asking: What problem is this model solving?
The CRC Philosophy as a Foundation
When we start with CRC cards, we’re not choosing a notation—we’re choosing a responsibility-driven mindset. Each card is a conversation about behavior, not just structure.
That mindset must survive the transition to UML. The class Order isn’t just a container of data. It’s a participant in a business process—responsible for validating, accepting, and notifying. That responsibility must be visible, traceable, and justifiable in the class diagram.
Ask yourself: Can I explain the responsibility-driven mindset behind this class in under a minute? If not, the model is missing its soul.
Translating Intent: The UML Design Principles Checklist
Formalizing CRC into UML isn’t about mapping symbols. It’s about preserving intent. Use this checklist to ensure your class diagrams reflect real design thinking.
  • Every class must have a single, clear responsibility. If it has multiple reasons to change, it’s probably doing too much.
  • Each method must stem from a defined responsibility. No hidden behaviors. If a method doesn’t serve a named purpose, reconsider its existence.
  • Associations must reflect meaningful collaborations. A relationship between Order and Customer isn’t just “they’re connected”—it’s “Order depends on Customer for shipping details.”
  • Visibility should reflect encapsulation, not convenience. Use private for internal state, protected for inheritance, public only for contracts with the outside world.
  • Use inheritance only when behavior is truly shared. Don’t inherit just because two classes look similar. Ask: Is this a is-a relationship, or just a has-a?
These principles aren’t optional. They’re the difference between a diagram that documents and one that guides.
From CRC to UML: A Step-by-Step Intent Mapping
Here’s how to translate CRC insights into UML while preserving design intent. The goal is to answer: Why is this class here? Why does it work this way?
  1. Start with the CRC class name. Ask: What business role does this represent? E.g., InventoryManager isn’t just a data holder—it manages stock levels and alerts.
  2. Map responsibilities to methods and attributes. A responsibility like “calculate total value” becomes a method calculateTotalValue(). “Track stock levels” becomes an attribute currentStock: int.
  3. Turn collaborations into associations. If Order collaborates with PaymentService, the UML association should reflect a dependency, not just a line.
  4. Label relationships with intent. Don’t just add a name like “relation.” Instead, name it “handles payment validation” to clarify purpose.
  5. Review every class: Can I explain its intent in one sentence? If not, revise.
This process turns UML from a static artifact into a living document of design decisions.
Even experienced teams fall into traps when moving from CRC to UML. Here are the top three, with real fixes.
Pitfall Why It Happens How to Fix
Overloading classes with responsibilities Trying to capture every behavior in a single class Revisit CRC cards: If a class has more than 2–3 responsibilities, decompose it into smaller, focused classes.
Missing intent in associations Adding lines without explaining purpose Every association should have a navigable role name. E.g., Order —> Customer (responsible for delivery address).
Forgetting to model constraints and invariants Assuming logic is implied by structure Add constraints in curly braces: {totalPrice > 0} to clarify validation rules.
These are not syntax errors. They’re design flaws. Fix them early, and your model becomes a shared truth.
Building a Culture of Intent-Driven Design
UML design principles aren’t just technical rules. They’re cultural ones.
When teams adopt a responsibility-driven mindset, they stop asking “What should this class have?” and start asking “What should it do?”
I once worked with a team who spent weeks refining a ReportGenerator class. It had 12 methods, 30 attributes, and 6 associations. But when we asked: “What’s your single responsibility?”—no one could answer. We stripped it down to two methods and one core behavior: “generate a PDF report from data.” The model became simpler, clearer, and more maintainable.
This is the power of design intent modeling. It forces teams to reflect on their choices, not just execute them.
How to Foster Intent in Your Team
  • Start every modeling session with: “What business problem does this class solve?”
  • During reviews, ask: “Can you explain this class in one sentence?”
  • Use the CRC philosophy as a litmus test: “Would this class exist in the real world?”
  • Encourage naming that reflects purpose: DiscountCalculator instead of Calc or Helper.
These habits don’t just improve diagrams. They improve communication, reduce rework, and create systems that evolve with clarity.
How do I know if I’ve captured the correct design intent in my UML model?
Ask three questions: Is every class responsible for one clear purpose? Can you explain its role in simple business terms? Can another developer understand its behavior without reading code? If yes to all, intent is likely preserved.
Does the CRC philosophy still matter after moving to UML?
Yes. CRC cards are a thinking tool, not a step. The CRC philosophy—responsibility-driven design, collaboration modeling, lightweight documentation—must persist. Use it to guide every UML decision, especially when naming, structuring, or refining.
Can UML design principles be applied to legacy systems?
Absolutely. Start by reverse-engineering the existing model. Identify classes and their behaviors. Then, apply the intent checks: “Does this class have a single responsibility?” “Is the association meaningful?” Use this as a foundation for refactoring, not just documentation.
What if my team insists on following UML rules but ignores intent?
That’s a red flag. Rules without purpose breed brittle models. Introduce a “one-sentence intent” rule: every class must be explainable in one clear sentence. Make it part of your design review checklist. Over time, teams begin to value clarity over compliance.
How do I balance UML precision with rapid prototyping?
Use CRC cards for early exploration. Convert only what’s necessary. Focus on core classes and key collaborations. Let the model evolve through feedback, not perfection. The goal is not to “complete” the diagram—it’s to build shared understanding.
Is UML design principles relevant in agile development?
More than ever. Agile isn’t about skipping documentation—it’s about making it useful. UML design principles help teams create models that evolve with the code, support refactoring, and guide sprint planning. When every diagram is tied to intent, it becomes a living artifact, not a relic.
