Understanding the Gap Between CRC Models and Class Diagrams
Temps estimé :7 minutes 54 vues
Most teams don’t fail because they misunderstand the tools—they fail because they confuse exploration with execution. CRC cards are not a draft of a class diagram. They’re not a blueprint. They’re a conversation starter. The real danger lies in treating CRC as if it were a finished model. The difference CRC and UML represents isn’t just syntax—it’s mindset. One is for thinking. The other is for communicating with precision.
I’ve spent two decades guiding teams through this exact shift. The moment you start drawing lines and boxes before the team has settled on responsibilities, you’ve already lost the benefit of collaborative design. CRC cards are about shared understanding. UML is about shared commitment.
This chapter gives you a field-tested framework to recognize where you are in the design lifecycle, how to avoid rushing into formality, and what to look for before jumping from CRC models to class diagrams. You’ll learn how to distinguish between conceptual and structural modeling, and how to time the transition so that your documentation reflects real insight—not just notation.
Why CRC and UML Are Fundamentally Different
CRC cards were never meant to be precise. They were conceived as a lightweight way to explore roles, responsibilities, and collaborations in a team setting. Each card is a hypothesis, not a declaration.
UML, by contrast, is a formal language. Its grammar governs visibility, multiplicity, inheritance, and interface contracts. Drawing a class diagram isn’t just sketching—it’s defining a system’s public face.
The difference CRC and UML isn’t about capability. It’s about intent. One is exploratory. The other is declarative. One helps you discover. The other helps you document.
Conceptual vs Structural Modeling: A Critical Distinction
Let’s be clear: conceptual modeling is not a lower-fidelity version of structural modeling. It’s a different phase of design.
When you’re in early object design stages, you’re not yet defining attributes or method signatures. You’re asking: “Who’s responsible for managing the user session?” “Who handles the payment confirmation?”
That’s conceptual modeling. It’s about roles, behaviors, and dependencies—what the system does, not how it’s built.
Structural modeling, on the other hand, is about precision. It’s where you define the class name in PascalCase, declare attributes with types, specify method return types, and assign ownership to a package or namespace.
Trying to assign a return type to a method before the team agrees on its purpose is like writing code before you’ve decided what the app is for.
The Hidden Risks of Premature Formality
Jumping too early into UML from CRC isn’t just inefficient—it introduces bias. The moment you draw a class with attributes, you imply that those are fixed, agreed-upon properties. But in reality, they’re still hypotheses.
Here’s a common trap: a developer draws a “User” class with “name,” “email,” and “password” before the team has even defined what “managing a user” means in context. That’s not design—it’s assumption.
I’ve seen teams lose weeks of rework because they skipped CRC and went straight to UML. The result? A model that looks correct but doesn’t reflect the actual domain logic.
When Premature Formality Backfires
  • Teams lock into a single interpretation of a role before consensus.
  • Attributes are added without understanding their purpose or lifecycle.
  • Collaborations become rigid associations before dependencies are understood.
  • Feedback is stifled—because the diagram « looks complete » even when it’s wrong.
These aren’t minor errors. They’re design traps. The fix? Let the CRC phase do its job.
How Teams Actually Transition from CRC to UML
There is no universal formula. But there is a rhythm. The transition isn’t a one-time event—it’s a process of refinement.
After several rounds of CRC card sessions, the team should be able to answer: “What are the core entities? What do they do? Who interacts with whom?”
That’s when you begin the shift to formal structure. But it’s not about redrawing. It’s about validating.
Key Signals That You’re Ready to Transition
  1. All key domain entities have been identified and named consistently.
  2. Responsibilities are no longer vague—phrases like “handle payment” have become “validate payment details and initiate transfer.”
  3. Collaborations are stable: the team agrees on who calls whom and why.
  4. Multiple team members can explain the model without referencing notes.
If these aren’t met, you’re not ready. Don’t rush the next step.
Mapping CRC to UML: A Practical Workflow
When the time is right, here’s how to convert CRC into a UML class diagram with integrity:
  1. Extract Classes: Each CRC card becomes a class. Use PascalCase. Avoid abbreviations unless they’re universally understood.
  2. Define Responsibilities as Methods and Attributes: “Calculate total” becomes a method. “Billing address” becomes an attribute.
  3. Model Collaborations as Associations: If “Order” sends a message to “PaymentProcessor,” draw a line with a label like “uses” or “initiates.”
  4. Assign Visibility and Types: Use + for public, - for private, # for protected. Add types like String, DateTime, PaymentStatus.
  5. Refactor for Inheritance and Interfaces: Look for shared behavior. Can “Payment” and “Refund” share a common base? Do they implement a “Processable” interface?
This is not a mechanical conversion. It’s a transformation of intent into structure.
Comparing CRC and UML: A Side-by-Side View
Aspect CRC Cards UML Class Diagram
Primary Use Brainstorming, team alignment Documentation, communication with developers and testers
Modeling Focus Responsibility, collaboration, behavior Structure, visibility, type safety
Formality Level Low (free-form, sticky notes) High (strict syntax, notation)
Change Frequency High (iterative, responsive) Limited (requires formal revision)
Team Role Shared ownership Designer or analyst responsibility
This table is not just a comparison—it’s a reminder. The difference CRC and UML isn’t just technical. It’s cultural. One fosters discovery. The other enforces agreement.
When to Hold Off on UML: A Checklist
Use this checklist before converting CRC to UML. If any item is missing, pause.
  • Are all core domain entities named and agreed upon by the team?
  • Are responsibilities phrased in active verbs (“calculate,” “validate,” “notify”)?
  • Have collaborations been tested with real-life scenarios?
  • Can a new team member explain the core model without diagrams?
  • Are there no more than three unresolved ambiguities in collaboration paths?
If any answer is “no,” the model isn’t ready. Don’t force it.
What’s the main difference between CRC cards and UML?
CRC cards are for thinking—exploring roles and responsibilities in a collaborative, informal setting. UML is for documenting—expressing the precise structure of a system with standardized notation. One is exploratory; the other is declarative.
Can I use CRC cards and UML together in the same project?
Absolutely. CRC cards come first. They help discover the model. UML comes next, to formalize and communicate it. Teams that skip CRC often end up with over-engineered or misaligned diagrams.
Is it wrong to start with UML if I’m more comfortable with it?
Not wrong—but risky. UML without CRC can lead to premature design decisions. You might define a class with attributes before understanding its role. CRC ensures you’re modeling the domain, not just the code.
When should I move from CRC to UML?
When the model is stable—when roles are clear, responsibilities are verbs, collaborations are tested, and the team agrees on the core structure. That’s when you transition, not before.
Are CRC cards still useful after creating the UML diagram?
Yes. CRC cards remain valuable during maintenance. When a new feature arises, revisiting CRC sessions helps revalidate responsibilities. They’re not obsolete—they’re a living part of the design process.
Can I use tools like Visual Paradigm to convert CRC to UML automatically?
Some tools support digitizing CRC cards and generating UML. But automation can’t replace understanding. The tool helps you structure your thinking—but only you can ensure the model reflects real business intent.
