Learn Kanban
A visual board that helps you see exactly where every task is—from “To Do” to “Done.”
What is Kanban
Kanban is like a “Digital Sticky-Note Board.” Imagine a wall with three columns: To-Do, Doing, and Done. Every task is a sticky note that moves from left to right as you work on it. The main goal of Kanban is to “stop starting and start finishing.” It helps you see if you have too many things in the “Doing” column so you can focus on clearing them out before taking on new work. It’s the ultimate tool for keeping a steady, smooth flow of progress.
Recommended Guides
Przewijanie do góry
