Learn BPMN
A universal set of symbols used to map out every step of a business process from start to finish.
What is BPMN
Think of BPMN as the „Sheet Music for Business.” Just as musicians all over the world can read the same notes to play a song, business people use BPMN to show exactly how a process works. It uses simple shapes—like circles for the „Start,” rectangles for „Tasks,” and diamonds for „Decisions”—to show how a piece of work moves through a company. It’s the best way to make sure everyone agrees on how a job should be done.
Recommended Guides
BPMN Diagram Types Explained If you’ve ever struggled to choose between a BPMN process diagram, collaboration diagram, or choreography view—only to end up with a confusing, inconsistent model—you’re not…
BPMN Fundamentals for Beginners If you've ever stared at a blank canvas, wondering how to turn a complex workflow into a clear, shared diagram, you're not alone. Many beginners…
CMMN vs BPMN: When to Use Which? Have you ever spent hours refining a BPMN diagram, only to realize the process it models is too unpredictable to fit a rigid flow? Or…
Common BPMN Mistakes and How to Avoid Them Have you ever spent hours refining a BPMN diagram—only to have stakeholders walk away confused, or IT implement a process that doesn’t match your intent?…
Modeling Customer Journeys with BPMN Have you ever found yourself staring at a beautiful journey map—full of emotions, touchpoints, and moments of truth—only to realize it doesn’t help your team…
