Incident Management Across Departments
Geschätzte Lektüre: 8 Minuten 66 Ansichten
When the structure breaks, the case takes over.
That’s the truth I’ve learned over two decades of modeling complex business scenarios. Incident management isn’t a rigid sequence—it’s a dynamic response to unpredictable events that span departments, roles, and systems. In this chapter, I’ll show how to model that reality using the right tools: BPMN for the predictable flow, CMMN for the adaptive response.
You’ll see a real-world case where an IT outage triggers a structured routing process in BPMN, but the actual resolution unfolds in a flexible CMMN case—driven by human judgment, evolving data, and shifting priorities. This hybrid approach isn’t theoretical. It’s how leading organizations manage incidents today.
By the end of this section, you’ll know: when to use each notation, how to integrate them without confusion, and how to avoid the most common modeling pitfalls in cross-departmental cases.
Why Incident Management Demands Hybrid Modeling
Incident management is rarely a linear process. A server crash may trigger a predefined escalation path—but the root cause might require forensic analysis, stakeholder coordination, or compliance checks that no flowchart can capture.
Modeling this with only BPMN leads to over-structured diagrams that ignore real-world variability. Trying to force a case into BPMN results in tangled gateways, excessive conditions, and models that no one can maintain.
That’s why the most effective incident management systems use hybrid modeling: BPMN for the known, CMMN for the unknown.
Consider this: a minor network glitch might only need a 5-minute fix via a predefined workflow. But a data breach? That’s a full-scale investigation. The same incident, different management mode.
Key Triggers That Demand Flexibility
Not every incident starts as a complex case. But these signals mean CMMN is needed:
  • Multiple root cause possibilities
  • Multiple stakeholders with different roles
  • Unplanned data discovery during resolution
  • Decision points requiring expert judgment
  • Changes in severity or scope mid-process
These aren’t exceptions—they’re the norm in mission-critical environments. Rigid BPMN models can’t handle them without constant rework.
Modeling the Incident: A Hybrid Approach
Let’s walk through a real example from a global financial services firm. An incident occurs in the IT infrastructure department, but its impact reaches customers, legal teams, and compliance officers.
BPMN: Structured Routing and Escalation
Here’s what the BPMN model handles:
  • Initial detection via monitoring tools
  • Automated assignment to Tier 1 support
  • Escalation to Tier 2 if unresolved in 15 minutes
  • Notification of business impact to customer service
  • Creation of a formal case ID and logging to the incident registry
These steps are clear, repeatable, and rule-based. BPMN is perfect here. The sequence flows predictably from event to task to outcome.
But when Tier 2 support identifies a configuration error in the firewall, the real work begins.
CMMN: Adaptive Investigation and Resolution
The incident now transitions into a CMMN case. A case plan is activated with the following elements:
  • Stages: Initial Assessment → Evidence Collection → Root Cause Analysis → Resolution & Validation → Closure
  • Tasks: Interview system engineers, review log files, analyze network traffic, simulate fix, approve changes
  • Case File: Contains logs, firewall rules, network topology, stakeholder contacts, compliance templates
  • Sentries: Event triggers when new logs arrive or when a stakeholder updates the case
What makes this work? The model doesn’t force a path. It allows the team to move between stages, revisit earlier steps, and add new tasks based on discoveries.
For example, if the audit team raises concerns about the fix’s compliance, a new task is added. If the logs reveal a pattern of repeated issues, the case may be linked to a larger problem tracking system.
This isn’t an exception. It’s the expected behavior of a knowledge-intensive, adaptive process.
How to Integrate BPMN and CMMN in Practice
Integrating the two doesn’t mean merging diagrams. It means connecting them logically, so the BPMN model triggers the CMMN case, and the CMMN case feeds back into the BPMN workflow when needed.
Step-by-Step Integration Pattern
  1. BPMN triggers CMMN: When an incident reaches a certain severity or escalation level, a subprocess is initiated to create a CMMN case.
  2. Case ID is shared: The CMMN case references the BPMN incident ID, enabling traceability and auditability.
  3. Tasks update status: As CMMN tasks are completed, the BPMN model updates its progress (e.g., “Root cause identified”)
  4. Exit conditions trigger BPMN continuation: Once the CMMN case reaches closure, the BPMN process resumes—e.g., “Notify customer service of resolution”
This creates a seamless workflow where the predictable and the adaptive coexist.
Example: Incident Resolution Flow
BPMN Step CMMN Case Activation Trigger Condition
Escalation to Tier 2 Case created Severity = High or Medium
Resolution initiated Root Cause Analysis stage Case status = „In Progress“
Fix approved Case closed All tasks complete
This table shows how the two models communicate without overlapping in structure. The BPMN process remains clean and focused on coordination and timing. The CMMN case handles the complexity of discovery and decision-making.
Common Mistakes in Incident Workflow Modeling
Even experienced modelers fall into traps. Here are the top three I see:
  • Overloading BPMN with conditions: Using 10+ gateways to handle “what if” scenarios creates a diagram that no one can read or maintain.
  • Underestimating CMMN’s need for definition: Not defining entry/exit criteria leads to ambiguity—“Can we start this task?” becomes a recurring debate.
  • Missing data flow between models: If the CMMN case doesn’t pass key findings back to BPMN, you lose visibility into resolution quality.
These issues aren’t flaws in the notation—they’re modeling errors. You can prevent them with three rules:
  1. Use BPMN for what happens next. Use CMMN for what might happen next.
  2. Define clear criteria for when a CMMN case is created and when it ends.
  3. Always link the case back to the original incident ID for traceability.
These are not preferences. They are requirements for model integrity.
When to Use Each Notation: A Decision Checklist
Use this simple checklist to decide:
  • If the incident follows a known, repeatable path—BPMN
  • If the resolution path depends on discovery, judgment, or evolving data—CMMN
  • If multiple teams must collaborate without a fixed sequence—CMMN
  • If you need to automate escalation, timelines, and status reporting—BPMN
  • If the process must adapt to new information—CMMN
  • If you need to track compliance and audit trails—BPMN
There’s no one-size-fits-all. But when you see a cross-departmental case with unpredictable steps, CMMN is almost always the right choice.
Can I use BPMN to model a full incident response process?
Yes, but only if all steps are predictable and repeatable. For example, a simple password reset incident can be modeled entirely in BPMN. But for complex, high-impact events, forcing the entire process into BPMN leads to fragile models that break on change.
How do I know when to switch from BPMN to CMMN?
Switch when you encounter tasks that can’t be scheduled in advance, decisions that depend on new data, or collaboration that doesn’t follow a fixed sequence. If you find yourself asking “What happens next?” instead of “What happens after this step?”, it’s time for CMMN.
What happens if the CMMN case never closes?
That’s why you need clear exit criteria. In practice, every CMMN case should have a defined endpoint—whether it’s “Root cause confirmed,” “Compliance reviewed,” or “Customer notified.” Without one, cases become stuck, and the model loses its integrity.
Can I use both BPMN and CMMN in the same system?
Absolutely. In fact, it’s best practice. Use BPMN to manage the incident lifecycle (detection, escalation, notification) and CMMN for the investigation and resolution. They serve different purposes and work best together.
How do I ensure model consistency between teams?
Define a shared modeling policy. Use templates. Enforce naming conventions. And above all: require peer review for every hybrid model. I’ve seen teams skip this—and pay for it with miscommunication and delays.
Do I need special tools to model cross-departmental cases?
While any BPMN/CMMN tool can handle it, I recommend one with integrated case and process modeling—like Visual Paradigm. It allows you to link BPMN subprocesses to CMMN cases, simulate both, and track changes across the lifecycle.
Incident management is not a process to be controlled. It’s a system to be governed. The best models reflect reality, not rules.
Let BPMN handle the predictable. Let CMMN handle the unpredictable. Together, they make incident response not just reactive—but resilient.
Now go build something that works.
