From CRC Cards to Class Diagrams
Geschätzte Lektüre: 6 Minuten 52 Ansichten
Imagine you’ve just wrapped up a lively CRC session for a student grading system. You’ve identified classes like Student, Grade, and Course, outlined their responsibilities, and mapped out how they collaborate. The cards are scattered across the table — a visual map of your design intent. But now, you need to move from informal sketching to a formal, shareable, and extensible model. That’s where converting CRC to UML becomes essential.
The leap from CRC cards to UML class diagrams isn’t a leap in complexity — it’s a leap in clarity. Your CRC session already contains all the ingredients: classes, responsibilities, collaborations, and dependencies. The challenge isn’t learning new theory; it’s organizing existing insights into a standardized format that tools and teams can use.
This chapter walks you through a step-by-step process to transform your CRC modeling output into a clean, accurate UML class diagram. You’ll learn how to extract structure, define visibility, assign attributes and methods, and validate relationships. These aren’t abstract rules — they’re practical decisions I’ve made on dozens of projects, from education platforms to enterprise systems.
Why Convert CRC to UML? The Practical Benefits
While CRC cards are excellent for early-stage brainstorming, UML class diagrams serve as a bridge to implementation. They formalize your design decisions and make them accessible to developers, architects, and even testers.
Converting CRC to UML isn’t about replacing one tool with another. It’s about evolving from a conversational model to a documented one — one that supports code generation, documentation, and team alignment.
Here’s what you gain when you make the transition:
  • Consistency across teams — A shared class diagram reduces misinterpretation between developers and designers.
  • Integration with UML tools — Platforms like Visual Paradigm accept UML diagrams natively.
  • Foundation for code generation — Many IDEs can generate skeleton classes from UML diagrams.
  • Scalability — Formal diagrams handle large systems better than stacks of cards.
Step-by-Step: From CRC Cards to UML Class Diagram
Step 1: Extract the Core Classes
Start by listing every class from your CRC cards. These are the foundation of your diagram.
For example, in a grading system, your classes might be:
  • Student
  • Course
  • Grade
  • GradingSystem
Each becomes a class box in your UML diagram.
Step 2: Assign Attributes from Responsibilities
Each responsibility often implies a data need. “Calculate final grade” suggests a method that depends on attributes like homeworkScore, examScore, and weighting.
Go through each class’s responsibilities and extract attributes. Ask: “What data does this class need to fulfill this responsibility?”
Step 3: Define Methods from Responsibilities
Responsibilities phrased as verbs (e.g., “calculate final grade”) become methods.
Turn “notify student of pending grade” into a method: notifyStudent().
Be careful not to overfill methods. A single responsibility should map to one or two methods max.
Step 4: Map Collaborations as Associations
Each collaboration in CRC — “Student uses Grade to record a score” — becomes an association in UML.
Draw a line between the two classes, and label it if needed. Use arrows to indicate directionality.
Example:
Student o-- Grade
Course o-- Grade
Step 5: Add Multiplicity and Constraints
Go back to your CRC cards. If a Student can have multiple Grades, add multiplicity: 1..* on the Grade side.
Use constraints to capture rules:
  • {must have valid score between 0 and 100}
  • {must be assigned by a Course}
These ensure your class diagram isn’t just visual — it’s semantically rich.
Step 6: Refactor and Validate
Now, step back. Ask:
  • Are there duplicate responsibilities across classes?
  • Can any class be merged or split for better cohesion?
  • Do associations make sense in the real domain?
Use this moment to refine. A good class diagram is not just accurate — it’s readable and maintainable.
Common Pitfalls in the Class Diagram Transition
Even when you’ve done a solid CRC session, transitions to UML can falter. Here are the most common mistakes and how to fix them:
Mistake Why It Happens Fix
Overloading class boxes with too many methods One class taking on too many responsibilities Split into smaller, focused classes using the Single Responsibility Principle
Missing multiplicity on associations Assuming relationships are bidirectional without checking Revisit CRC collaborations — clarify who depends on whom
Confusing attributes and methods Blending data and behavior without separation Ensure methods are verbs and attributes are nouns; use UML’s separation of fields and operations
Real-World Example: From CRC to UML in a Library System
Let’s walk through a small example.
From your CRC cards, you’ve identified:
  • Book: “Track title, author, and availability status”
  • Member: “Request a book”
  • Loan: “Record check-out and due date”
  • Library: “Manage all books and loans”
Now, build the UML class diagram:
  • Each class has a box with three sections: name, attributes, methods.
  • Attributes: title: String, author: String, isAvailable: Boolean
  • Methods: checkOut(), returnBook()
  • Associations:
    • Member o– Loan (1..*)
    • Book o– Loan (1..*)
    • Library o– Book (1..*)
    • Library o– Loan (1..*)
This output is now a valid, shareable UML class diagram ready for review or code generation.
Best Practices for a Smooth Transition
Here’s what has worked consistently across teams:
  1. Start with a clean canvas — Don’t try to copy CRC cards directly. Rebuild the diagram from scratch in UML.
  2. Group related classes — Use packages or subsystems to organize the diagram, especially in larger systems.
  3. Label associations clearly — “borrows” or “issues” make intent clearer than generic lines.
  4. Use stereotypes sparingly<<entity>>, <<business>> only if they add value.
  5. Review with a pair — Have someone else validate your diagram. Fresh eyes catch missing constraints and inconsistent multiplicity.
How do I convert CRC to UML when the responsibilities are vague?
Start by rephrasing responsibilities into active, measurable actions. “Manage grades” becomes “calculate final grade” or “assign a score.” This clarity directly translates to a method in the class diagram.
Can I use CRC modeling output to generate code automatically?
Yes, if your class diagram is well-structured, modern tools like Visual Paradigm or IntelliJ can generate class skeletons in Java, C#, or Python. But only if attributes and methods are properly defined from the start.
Do I need to convert every CRC card into a UML class diagram?
No. Prioritize classes that are central to the system — those used in multiple collaborations. Less critical classes can remain as CRC cards or be merged later.
What if my CRC session had too many classes?
Use the “Cohesion Rule”: if a class has more than 5 responsibilities, split it. Then re-evaluate the diagram. The goal is balance — not completeness.
How detailed should the UML class diagram be?
Focus on domain-level detail. Avoid internal implementation details like private helper methods unless they impact collaboration. Keep the diagram readable for both developers and stakeholders.
Is it acceptable to skip UML and just use CRC cards in production?
For small teams or prototypes, yes. But for long-term projects, UML is essential. It enables documentation, code review, and maintenance — things CRC cards alone can’t support.
