Customizing Fishbone Templates for Different Industries
Geschätzte Lektüre: 8 Minuten 57 Ansichten
Too many teams start an RCA by copying a generic fishbone template without considering the real context. The result? A diagram that looks correct but fails to surface the actual root causes. I’ve seen this happen in over 150 investigations across sectors—manufacturing lines, software deployments, hospital safety reports, even service delivery failures. The flaw isn’t in the method. It’s in how we treat the template as a one-size-fits-all tool.
Fishbone diagrams are only useful when the categories reflect the systems you’re analyzing. A template that works for a mechanical failure in a factory won’t capture the human factors in a hospital medication error. The key isn’t to reuse a format—it’s to adapt it.
This chapter gives you ready-to-adapt fishbone format examples tailored to four core industries. You’ll learn how to customize fishbone layouts based on real workflows, not just theory. These aren’t abstract models—they’re tools I’ve refined through years of fieldwork, each built on the principle that the right structure unlocks deeper insight.
Why Generic Templates Fail Before You Even Start
Every template you see online starts with the same five or six categories: People, Process, Equipment, Environment, and Management. That’s a good starting point—but only if you stop there.
When I led a root cause analysis in a hospital, we used the standard 6M model. The team listed “staff fatigue” and “poor scheduling” under People. But the real issue wasn’t staffing—it was a breakdown in the electronic health record system that caused nurses to miss dose timing alerts. The standard model didn’t have a category for digital workflow failure.
The problem wasn’t the tool. It was the assumption that a universal structure fits every system. That’s why you need to customize fishbone layouts based on your operational reality.
Industry-Specific Fishbone Format Examples
1. Manufacturing: The 6M + Maintenance & Calibration
Manufacturing environments demand precision. The classic 6M model—Manpower, Method, Machine, Material, Measurement, Milieu—is solid, but it often misses two critical systems.
I’ve added two more branches: Maintenance and Calibration. These aren’t just add-ons—they’re where recurring machine failures often originate.
Here’s how to adapt the fishbone for manufacturing:
  • Manpower: Training levels, shift rotations, cross-functional skill gaps
  • Method: Work instruction clarity, changeover procedures, SOP adherence
  • Machine: Age, downtime frequency, vibration, tool wear
  • Material: Supplier consistency, batch variance, incoming inspection
  • Measurement: Calibration frequency, gauge R&R, sensor accuracy
  • Milieu: Lighting, ventilation, workspace ergonomics
  • Maintenance: Preventive maintenance schedule, repair response time, spare parts availability
  • Calibration: Calibration logs, drift in measurement tools, traceability records
Use this layout when investigating machine downtime, scrap rates, or process drift. It helps root out subtle issues like misaligned sensors or delayed maintenance that can cascade into defects.
2. IT & Software Development: The 8P Framework
Software delivery isn’t about physical parts. It’s about people, processes, and systems in motion. The standard fishbone doesn’t capture the complexity of deployment failures, CI/CD pipeline breaks, or test coverage gaps.
Instead, use the 8P model:
  • People: Team size, skill distribution, sprint capacity, onboarding time
  • Process: CI/CD pipeline steps, code review workflow, release checklist
  • Performance: API latency, error rates, deployment frequency
  • Planning: Sprint planning accuracy, backlog prioritization, scope creep
  • Products: Feature complexity, documentation quality, dependency stability
  • Platforms: Cloud provider reliability, container orchestration, OS version compatibility
  • Procedures: Incident response playbook, rollback strategy, monitoring setup
  • Partners: Third-party APIs, vendor SLAs, external tool integration reliability
When debugging a recurring release failure, this layout forces you to ask: Was it a code issue? A bottleneck in the pipeline? An unmanaged dependency? It’s not just about “what broke”—it’s about what enabled the break.
This framework is ideal for DevOps teams, software engineering leads, or IT incident responders. It turns vague blame like “the system failed” into actionable, evidence-based diagnostics.
3. Healthcare: The 4C Model
Medical errors aren’t just about equipment or people. They’re about systems, communication, and safety culture. The 4C model—Care Process, Communication, Culture, and Compliance—was born from real incident reports in surgical units and pharmacy operations.
  • Care Process: Diagnosis pathways, treatment protocols, medication administration steps
  • Communication: Shift handovers, team huddles, EHR documentation clarity
  • Culture: Psychological safety, reporting culture, leadership involvement in safety
  • Compliance: Adherence to checklists, audit findings, regulatory standards (e.g., Joint Commission)
When a medication error occurs, this model helps determine if the root cause was a misread label, a broken workflow, or a culture where nurses were afraid to speak up. It shifts focus from “who” to “how” the system allowed the error.
Use this for incident investigations in hospitals, clinics, or home care settings. It’s not about proving fault—it’s about understanding what allowed a failure to occur.
4. Services (Customer Support, Finance, HR)
Service failures often stem from unclear expectations, inconsistent processes, or misaligned roles. The 6S model—Service, Staff, Systems, Standards, Skills, and Satisfaction—was developed from service recovery cases in insurance, banking, and call centers.
  • Service: Customer journey touchpoints, service level agreements (SLAs), escalation paths
  • Staff: Training duration, role clarity, team turnover, motivation levels
  • Systems: CRM tools, ticketing systems, automation levels
  • Standards: Service KPIs, quality control checks, audit protocols
  • Skills: Technical knowledge, empathy, problem-solving ability
  • Satisfaction: Customer feedback, NPS, repeat complaint patterns
When a client complains about a delayed response, this model asks: Was it a system failure? A skill gap? A misalignment between customer expectations and service design? It reveals whether the cause is operational, cultural, or systemic.
Perfect for customer success, operations managers, or HR teams dealing with recurring process gaps.
How to Choose the Right Fishbone Format for Your Context
There’s no single best format. The goal isn’t to memorize a template—it’s to map the actual structure of your system.
Ask three questions before finalizing your fishbone layout:
  1. What kind of failure occurred? A machine breakdown? A customer complaint? A process delay?
  2. Which systems were involved? People, software, physical assets, third-party providers?
  3. What are the known pain points or recurring issues? High error rates? Long cycle times? Repeat incidents?
Use your answers to tailor the categories. You’re not limited to six or eight branches. If your process includes multiple handoffs, add “Handoff Points” as a branch. If your system relies heavily on third-party APIs, make that a core category.
Remember: the fishbone is a thinking aid, not a checklist. If a category feels artificial, it probably is. Replace it with something that reflects your reality.
Quick Reference: Industry RCA Templates
Industry Recommended Fishbone Format Key Categories Best For
Manufacturing 6M + Maintenance & Calibration Machine, Maintenance, Calibration, Material, Measurement Process drift, equipment failure, scrap rate
IT / Software 8P (People, Process, Performance, Platforms, Partners) CI/CD, Dependencies, Documentation, Monitoring Deployment failure, regression bugs, system outages
Healthcare 4C (Care, Communication, Culture, Compliance) Checklists, Handovers, Error Reporting, Safety Training Medication errors, patient misidentification, workflow breakdowns
Services 6S (Service, Staff, Skills, Systems, Standards, Satisfaction) SLAs, Escalation Paths, Feedback Loops, Training Customer complaints, delayed responses, repeat issues
Can I use a single fishbone template across multiple departments?
No. Each department has unique systems, workflows, and failure modes. Using the same layout across departments often results in missed or irrelevant causes. Customizing fishbone layouts ensures you’re analyzing the actual context.
How do I decide which categories to include in my fishbone?
Start by reviewing recent incidents or process failures. Identify the systems involved—people, software, workflows, tools. Then, map those to logical branches. If a category doesn’t relate to your situation, remove it. The goal is relevance, not completeness.
Are industry RCA templates better than generic ones?
Absolutely. Generic templates are placeholders. Industry RCA templates are built on real operational insights. They reflect actual failure patterns, making cause identification more accurate and corrective actions more effective.
Can I combine categories from different templates?
Yes—this is encouraged. For example, a healthcare IT team might use Communication (from 4C) and Systems (from 6S) together to analyze a delay in patient data access. Flexibility is key. Adapt the structure to match your environment.
What if my team resists changing the standard fishbone format?
Lead with data. Show how the standard format failed to identify real causes in past investigations. Then run a side-by-side comparison: one session with standard layout, one with a tailored one. The difference in insight will speak for itself.
Is it okay to have more than eight branches in a fishbone diagram?
Yes. There’s no rule limiting the number. If your process involves multiple handoffs, platforms, or stakeholders, include them. The fishbone is a tool for thinking, not a rigid structure. Focus on clarity and relevance over convention.
By now, you’ve moved beyond copying templates. You’re learning to shape the fishbone to your system, not the other way around. That’s where real insight begins.
Take the next step: choose one of the model layouts above, apply it to a recent incident, and test whether it uncovers causes that the generic version missed. That’s how you turn a diagram into a discovery engine.
