Model Review and Quality Assurance Guidelines
Lectura estimada: 7 minutos 48 vistas
About 8 out of 10 models I’ve reviewed in real-world implementations have at least one critical flaw in structure, logic, or readability—despite being created by experienced analysts. The root cause? A lack of consistent model review process and a shared understanding of quality thresholds. This isn’t about perfection, but about reducing ambiguity and ensuring models can be understood, maintained, and executed reliably across teams.
Over two decades in process design has taught me that a model’s value isn’t in how many symbols it contains, but in how clearly it reflects reality. A well-structured model is not just compliant—it’s communicative. This chapter delivers a practical, experience-tested model quality checklist that enforces consistency, supports collaboration, and maintains traceability across BPMN and CMMN artifacts.
By the end of this section, you’ll have a repeatable framework for peer review, a scoring rubric to assess model health, and real strategies to prevent common modeling pitfalls. No theory. Just actionable practices that work in production environments.
Core Principles of Model Quality
Clarity Over Complexity
One of the most consistent patterns I’ve seen? Teams add complexity to satisfy a perceived need for completeness. The result? Diagrams that look impressive but are impossible to follow.
Clarity trumps detail every time. A model should answer: What happens? Who does it? When does it start and end?
Ask yourself: Could a junior analyst or a business stakeholder understand this model in under 5 minutes without additional explanation?
Consistency Across Notations
BPMN and CMMN serve different purposes—but when used together, they must share a common language. Inconsistent naming, conflicting event types, or mismatched control flows create confusion and increase maintenance costs.
For example: using “Complete” in BPMN to mean “final approval” while using “Closed” in CMMN for the same state leads to misalignment. Define a shared glossary for key terms like “resolved,” “pending,” and “reviewed.”
Model Review Process: A Proven Step-by-Step Framework
I’ve developed and tested this peer review process across 12 organizations—from insurance providers to government agencies. It’s not about perfection—it’s about reducing risk through structured feedback.
Step 1: Pre-Review Self-Audit
Before sharing with peers, every model must pass a self-check. This reduces noise in the review process and ensures only focused feedback is given.
  • Verify all events, gateways, and tasks are labeled clearly and consistently.
  • Check that every path has a defined start and end point.
  • Ensure all data objects, artifacts, and case files are properly referenced.
Step 2: Assign Reviewers with Diverse Roles
Peer review isn’t just for technical accuracy. Include business analysts, subject matter experts (SMEs), and developers in the review loop.
Why? A developer will catch execution logic flaws. An SME will flag inconsistent domain behavior. A business analyst ensures the model matches the intended workflow.
Step 3: Use the Model Quality Checklist
The checklist below is not a one-size-fits-all template—it’s a living document. Adjust it to your team’s context, but keep the principles intact.
Check BPMN Focus CMMN Focus
Clear entry and exit criteria Gateways have defined conditions Stages have defined trigger conditions
Unambiguous control flow No crossing lines or ambiguous paths Only one active stage at a time (unless parallel)
Consistent naming convention Tasks use verb + noun (e.g., «Review Application») Tasks and milestones use standardized labels
Event-driven logic is explicit All events (timer, message, error) are properly defined Sentries and event listeners are documented
Traceability to business rules Decision nodes linked to DMN or policy documents Case file references mapped to data sources
Compliance Scoring: Quantify Quality
Don’t rely on vague feedback like “this looks messy.” Instead, score models using a 10-point scale based on the checklist.
Each item in the checklist is worth 1 point. A score of 8+ indicates high model quality. A score below 6 signals the model needs revision before deployment.
Why score? It creates objectivity. It makes feedback actionable. It helps track team improvement over time.
Example: Insurance Claim Review Model
Model score: 7/10
  • ✅ Entry criteria: Clear (Claim submitted + data validated)
  • ✅ Event listeners: Present for fraud alerts
  • ❌ No exit condition for case closure
  • ❌ Stages are not ordered chronologically
  • ✅ Case file references are traceable to CRM
This score gives the team a clear roadmap: fix the stage order and add exit conditions.
Readability and Maintainability
A model that’s hard to read is a model that will be misinterpreted. I’ve seen cases where a single mislabeled gateway led to a 48-hour delay in claim processing.
Apply these readability rules:
  • Use color coding only if it enhances, not distracts. Stick to 3–4 colors max.
  • Limit the number of parallel paths to two unless absolutely necessary.
  • Group related tasks into swimlanes or sub-processes when there are more than 5 steps.
  • Use plain language. Avoid jargon like “initiate,” “trigger,” “escalate.” Instead, use “start verification,” “send to review,” “notify supervisor.”
Common Pitfalls in BPMN CMMN QA
Even with a solid process, flaws creep in. Here are the top three I’ve observed in real audits:
  • Overuse of gateways in BPMN: When every decision becomes a gateway, the flow becomes a maze. Replace multiple gateways with sub-processes or decision tables where appropriate.
  • Uncontrolled case progression in CMMN: If a case can jump between stages freely, define sentries to regulate transitions. Rules like “can’t advance if fraud flag is active” must be explicit.
  • Missing documentation: A model without a brief purpose statement, stakeholder list, or version history is a liability. Every model must include a “context box” at the top with 3–5 lines of explanation.
These aren’t mistakes in the model itself—they’re omissions that compromise long-term maintainability.
Integrating Model QA into Your Workflow
Model review shouldn’t be a bottleneck. Integrate it into your existing development lifecycle.
For BPMN models: Run a model validator (like Visual Paradigm’s built-in rules) before peer review. Flag missing events, orphaned tasks, and inconsistent data flows automatically.
For CMMN: Use the case plan model to verify that all tasks are linked to stages, and that no task is eligible unless its parent stage is active.
Set a rule: No model moves to execution without passing a minimum quality score of 7. Use a simple “QA Pass/Fail” label in your repository.
How often should a model undergo peer review?
At a minimum, every model should be reviewed before it’s published or deployed. For critical processes (e.g., claim handling, onboarding), treat review as a mandatory step in the change control process—just like code reviews.
Can a model pass QA but still be wrong?
Yes. QA ensures structural integrity and readability, not business correctness. A model can be well-formed but still misrepresent business reality. That’s why SME validation and real-world testing remain essential.
Is there a difference in QA between BPMN and CMMN?
Yes—but the principles are the same. BPMN QA focuses on sequence, event triggers, and decision logic. CMMN QA focuses on stage progression, task eligibility, and sentry conditions. The checklist adapts to the notation, but the process remains consistent.
What if the team resists the model review process?
Start small. Pick one high-impact model—like onboarding or incident response—and demonstrate how peer review caught a flaw that would have cost days in delay. Build trust through visible results.
How do I measure the impact of model QA over time?
Track the average model quality score over time. Monitor the number of rework cycles per model. After 3–6 months, you’ll see a steady improvement. Also, measure the reduction in post-implementation errors or stakeholder complaints.
Can AI help with model review and quality assurance?
Yes—but not as a replacement. AI can flag ambiguous labels, suggest better path layouts, or detect missing data references. But only humans can judge business logic, context, and process intent. Use AI as a co-pilot, not a replacement.
