Why Scrum? Foundations and Comparisons
Temps estimé :3 minutes 373 vues
If you’ve ever felt stuck in a rigid project plan that couldn’t adapt to change, you’re not alone. Many teams start with traditional methods only to find they’re delivering late, missing feedback loops, or struggling with scope creep. That’s where Scrum comes in—not as a rigid process, but as a practical way to bring teams together to solve complex problems adaptively.
As someone who’s guided hundreds of teams through the shift from command-and-control to collaborative delivery, I’ve seen how Scrum’s empirical foundation helps teams learn quickly, respond to change, and deliver real value. This section isn’t about jumping into ceremonies or roles right away—it’s about understanding why Scrum works, when it’s truly the right fit, and how it compares to other frameworks.
By the end, you’ll have a clear, grounded understanding of Scrum’s unique strengths and when to favor it—especially when your project demands adaptability, frequent feedback, and team ownership.
Here’s what you’ll learn as you progress through this section:
  • Key Benefits of Scrum: Faster Delivery and Team Empowerment – Explore how Scrum improves collaboration, accelerates delivery, and fosters transparency through time-boxed sprints and daily syncs. See how even small teams report faster feedback cycles and better predictability.
  • Scrum vs. Waterfall: Choosing the Right Approach for Your Project – Understand the fundamental differences between iterative Scrum and linear Waterfall. Learn when each method shines and how to transition from waterfall to Scrum with minimal disruption.
  • Scrum Compared to Kanban and Lean: When Scrum Fits Best – Compare Scrum’s structured sprints with Kanban’s continuous flow and Lean’s focus on waste reduction. Discover decision criteria for picking Scrum when predictability and regular delivery matter.
  • Explain the core reasons to use Scrum for beginners in plain language.
  • Identify key benefits of Scrum for beginners, especially in fast-changing environments.
  • Compare Scrum vs Waterfall and Scrum vs Kanban with real-world examples.
  • Decide when the Scrum framework is the best fit for a project based on team size, delivery pace, and change frequency.
  • Recognize common misconceptions about Scrum and why it’s not just for software teams.
  • Use simple decision aids to guide your choice between Scrum, Waterfall, Kanban, or hybrid approaches.
Understanding the “why” behind Scrum is just as important as the “how.” This section sets you up to make informed, intentional choices—not based on trends, but on what truly supports your team’s ability to deliver value.
Retour en haut
