Running Daily Scrums: Alignment Without Overload
Temps estimé :6 minutes 252 vues
Never turn the daily Scrum into a status report. That one rule preserves 90% of its value. When you shift from “what did you do?” to “what’s blocking progress?”, you unlock real alignment and team ownership. I’ve seen teams fall into the trap of reporting tasks like factory workers—checking boxes instead of solving problems. The result? Meetings that feel bureaucratic, alignment that’s superficial, and real impediments left unspoken.
As a Scrum Master with two decades of experience, I’ve learned that the power of the daily Scrum lies not in what’s said—but in how it’s used to reveal hidden friction. This chapter walks you through a clean, practical approach that works for Scrum beginners and seasoned teams alike. You’ll learn the three core questions, how to run it remotely, where most teams go off track, and how to use visual tools that show progress without adding noise.
The Three-Question Framework
At its core, the daily Scrum is a 15-minute sync point. Not a meeting to update managers. Not a status tracker. A moment for the development team to inspect progress toward the sprint goal and adapt their plan.
Each team member answers three simple questions:
  1. What did you do yesterday? Focus on work completed—what contributed to the sprint goal.
  2. What will you do today? Identify actions that support the sprint goal. No vague promises.
  3. Are there any impediments? Be specific. Name the blockage and who it involves.
Keep answers short. One sentence per person is ideal. That’s not about speed—it’s about focus. When people are concise, they’re forced to think clearly about what truly matters.
Why This Works for Scrum Beginners
These questions aren’t random. They reflect the Scrum framework’s emphasis on empirical process control. You’re not tracking progress—you’re inspecting it. The team uses this moment to spot risks early, adjust the sprint backlog, and self-organize.
When I first worked with a team of engineers who’d never done daily Scrums, I noticed they were just listing tasks. So I asked: “If someone asked you what you did yesterday, would they understand how it helped the sprint goal?” That question changed everything. They started framing answers around outcomes—not chores.
Remote and Hybrid Adaptations
Remote work doesn’t require a different daily Scrum—it demands better structure. The same three questions apply, but the format must support visibility and connection.
Use a shared digital board. Each team member updates their card with:
  • What they completed yesterday (with a checkmark or green tag)
  • What they plan today (with a pending tag)
  • Any blockers (with a red flag or note)
Start the meeting with a shared screen showing the board. One person reads their updates aloud. The rest listen. No need to speak unless they have a blocker or a point of clarification.
Best Practices for Remote Daily Scrums
  • Keep the camera on to build trust and visibility.
  • Set a strict 15-minute timebox. Use a timer or a visible countdown.
  • Assign a rotating facilitator to keep the meeting on track.
  • Use a shared digital board with color-coded tags for tasks and impediments.
  • Only the Development Team participates—no managers, no observers.
Common Mistakes to Avoid
Even simple things can derail alignment. Here are the top four mistakes I’ve seen in the field:
  1. Turning it into a management report. When the Scrum Master or Product Owner speaks more than others, the team disengages.
  2. Long meetings that last 30+ minutes. This breaks the timebox and signals poor planning.
  3. Letting blockers go unaddressed. If someone says “I’m waiting on a file,” and no one acts, the meeting loses credibility.
  4. Skipping the sprint goal. Without it, people answer in isolation. The “what’s blocking?” question loses meaning.
Each mistake erodes trust. The team starts treating the meeting as a formality. You want it to feel urgent, focused, and valuable—every day.
Visual Progress Tracking
Don’t rely on verbal summaries. Use visual tools to make progress tangible. A burndown chart or task board shows what’s done, what’s in progress, and what’s blocked.
Here’s a simple example of how to set it up:
Task Status Owner Impediment
Design login form Done Alice None
Implement auth API In Progress Bob Waiting on API specs
Test user flow To Do Charlie None
Update this board in real time. It becomes a living artifact—visible to all, owned by the team.
Use color codes:
  • Green = Done
  • Orange = In Progress
  • Red = Blocked
  • Gray = Not Started
Visibility breeds accountability. When someone’s task turns red, the team sees it immediately.
How to Conduct Daily Scrum: A Checklist
Follow this checklist before each meeting:
  1. Confirm the sprint goal is visible to all.
  2. Ensure every team member has a physical or digital space to update their status.
  3. Start and end on time. Use a timer.
  4. Only the Development Team speaks—Scrum Master facilitates.
  5. Address impediments immediately after the meeting.
  6. Update the task board or board in real time.
Do this every day. The consistency builds a rhythm that teams come to rely on.
How long should a daily Scrum meeting last?
Exactly 15 minutes. Timebox it strictly. If you’re consistently going over, examine the root cause—probably the team isn’t self-organizing, or the sprint goal isn’t clear.
Can a remote team run a daily Scrum effectively?
Absolutely. Use a shared digital board, keep cameras on, and follow the three-question framework. The key is consistency and visual transparency, not physical presence.
Is the daily Scrum the same as a standup meeting?
Yes—“daily standup” is a common term, but “daily Scrum” is the official name. Use the formal term when teaching Scrum beginners to reinforce framework accuracy.
What if no one has anything to report?
That’s a red flag. It could mean the team hasn’t started, is blocked, or doesn’t understand the sprint goal. Ask: “What’s standing in the way of progress?” If there are no answers, the sprint goal may not be clear.
Can the Scrum Master or Product Owner speak during the daily Scrum?
Only if they’re a Development Team member. The meeting is for the team to inspect and adapt. Managers should not dominate it.
How do you handle a team member who’s always late?
Address it directly. Latecomers disrupt the rhythm and show a lack of respect for the team. If it’s a recurring issue, the Scrum Master should coach the individual on the importance of punctuality and shared commitment.
Retour en haut
