Writing Stories Without Examples or Models
Temps estimé :8 minutes 64 vues
One of the most persistent gaps I’ve seen in product backlogs is the absence of tangible references. A story like “The system should process orders quickly” may sound plausible until you ask: what does “quickly” mean in context? How fast is fast enough? Without a shared model or example, the team defaults to assumptions—often wrong ones.
When I first led a product discovery session in a legacy system, I noticed the team kept describing flows without anchoring them to concrete examples. They’d say, “The user gets an email when the order is ready,” but no one could define what “ready” meant. That’s when I introduced a simple scenario: “When the order status changes to ‘shipped’ and the tracking number is generated, send the confirmation email.” Suddenly, the conversation shifted from vague intent to clear conditions.
Stories without examples or models don’t fail because they’re poorly written—they fail because they’re abstract. They don’t invite collaboration. They don’t become conversation starters. Instead, they turn into guesswork wrapped in Agile jargon.
This chapter shows how to fix that. You’ll learn to use story model visualization and story mapping tools not as optional extras, but as foundational practices. These aren’t just diagrams—they’re conversation catalysts that reveal hidden complexity, clarify behavior, and prevent rework.
The Hidden Cost of Abstract Stories
Abstract stories are invisible to the team. They can’t be tested. They can’t be discussed. They’re just promises with no proof.
Take this example: “As a customer, I want to see my order history so I can track past purchases.” The goal is clear, but how do we know when it’s done? What counts as “see”? Is it a list? A calendar view? A search filter?
Without a concrete example, acceptance conditions are guessed at. The developer builds a table. The tester finds no test coverage. The product owner says it’s not what they meant. Rework begins. All because the story lacked a model or example.
The truth is: if you can’t show it, you can’t be sure it exists. That’s why story model visualization is not a luxury. It’s essential.
Why Models Matter
Models—whether decision tables, state diagrams, or flowcharts—turn abstract behavior into observable, testable logic. They help the team see the full range of possible outcomes, not just the happy path.
Consider a story about refunds:
As a customer, I want to request a refund so I can get my money back if I’m not satisfied.
That’s insufficient. But with a decision table, you can map the rules:
Order Status Return Window Refund Eligible?
Shipped Within 30 days Yes
Shipped After 30 days No
Delivered Within 90 days Yes
Canceled Any time No
Now the story has boundaries. The team knows what to build—and what not to. This is story model visualization in action.
How to Use Story Mapping Tools Effectively
Story mapping tools— like Visual Paradigm —turn conversations into visual artifacts. They help you sequence stories by user workflow, spot gaps, and identify technical debt.
I’ve seen teams use story maps to uncover a hidden dependency: a “user login” story was missing, but the map revealed that all other user actions required authentication. That wasn’t in the original backlog. With a map, it became obvious.
Here’s how to use story mapping tools to avoid writing stories without examples or models:
  1. Start with the user journey. List every step a user takes from start to finish.
  2. Group related stories. Cluster them by phase—login, browse, order, pay, track.
  3. Insert examples for each story. For “Enter payment details,” show a sample form with valid/invalid inputs.
  4. Use color coding. Mark stories with unclear acceptance criteria in yellow, high risk in red, and ready in green.
  5. Update the map after every sprint. This keeps the backlog aligned with reality.
These tools aren’t about perfection. They’re about visibility. They force the team to confront ambiguity early.
Common Pitfalls in Story Mapping
Even with story mapping tools, teams fall into traps:
  • Building maps only at planning time. Maps should evolve. A static map is worse than no map.
  • Using them only for estimation. They’re far more powerful as discovery tools.
  • Letting one person own the map. It’s a team artifact. If only the product owner draws it, the team isn’t engaged.
  • Overcomplicating the model. A simple flowchart beats a 10-page UML diagram. Clarity over completeness.
The goal isn’t to create a masterpiece. It’s to make the invisible visible.
Examples Are More than Acceptance Criteria
Acceptance criteria are often written as a checklist: “Given X, when Y, then Z.” That’s useful—but it’s still text. It doesn’t show the full behavior.
Examples are different. They’re specific, concrete scenarios that represent a class of behavior. They’re not just tests—they’re conversations.
For instance:
As a user,
I want to reset my password
so I can regain access to my account.
Now, instead of just listing criteria, show two examples:
  • Example 1: Valid email input
    Given I’m on the password reset page,
    When I enter my registered email and click “Send Reset Link”,
    Then I should see a confirmation: “A reset link has been sent to your email.”
  • Example 2: Invalid email input
    When I enter an unregistered email and click “Send Reset Link”,
    Then I should see an error: “No account found with that email.”
These aren’t just test scripts. They’re part of the story. They’re what make it real.
This is story model visualization at work. The example isn’t a supplement—it’s the story’s skeleton.
When to Use Which Tool
Not every story needs a full diagram. The key is matching the model to the complexity.
Complexity Level Recommended Tool Use Case
Simple Simple decision table Refund eligibility based on date and status
Medium Flowchart or sequence diagram User login with two-factor authentication
High State machine or story map Order lifecycle with multiple transitions and roles
Don’t over-invest. Don’t under-invest. Match the model to the risk.
Final Insight: A Story Without an Example Is a Promise
I’ve worked with teams who said, “We don’t need examples. We’ll figure it out in dev.” That’s not how it works. You don’t figure out requirements in code—you figure them out in conversation.
A story without examples or models is a promise to deliver value without a plan to deliver it. It’s not a story. It’s a placeholder for confusion.
Use story model visualization. Use story mapping tools. Let them turn vague abstractions into shared understanding. Let them turn silence into dialogue.
When your team can point to a diagram and say, “That’s what we’re building,” you’ve won. The story is no longer just written—it’s lived.
Why should I use story model visualization instead of just writing acceptance criteria?
Acceptance criteria are good for testability, but they don’t show the full behavior. A decision table or flowchart reveals edge cases and dependencies that text alone can’t. It’s about seeing patterns, not just testing conditions. Story model visualization makes complex logic tangible.
Do story mapping tools slow down backlog refinement?
No—on the contrary, they accelerate it. A story map reveals gaps, duplicates, and dependencies early. It prevents the team from building a feature only to discover it doesn’t fit the user journey. The time saved in rework far outweighs the time spent creating the map.
What if the team resists using models?
Start small. Pick one high-risk story. Show the team the difference between a story with and without a model. Let them see how the model prevents rework. Over time, they’ll see it’s not overhead—it’s insurance.
Is there a standard format for story maps?
No one-size-fits-all. The structure should reflect your user journey. The key is horizontal alignment (steps) and vertical organization (features). Use colors, labels, and symbols to clarify risk, effort, and dependencies. The goal is clarity, not aesthetics.
How do I know when a story needs a model?
If the story involves conditions, transitions, or multiple outcomes, it likely needs a model. If you find yourself asking, “What if this happens?” or “What should the system do next?”—it’s time for a diagram. When the behavior isn’t obvious, model it.
