Diagnosing a Broken Story: A Step-by-Step Checklist
Temps estimé :8 minutes 57 vues
Every user story is a promise—of clarity, value, and testability. But too many teams treat story writing as a formality, not a gateway to shared understanding. The real cost of a broken story isn’t just in rework—it’s in wasted time, misaligned efforts, and stories that never deliver.
I’ve seen teams spend hours refining a story that, once tested, revealed a fundamental misunderstanding of the user’s need. Not because the developers were wrong, but because the story itself was poorly defined from the start. That’s where a structured diagnosis becomes essential.
My experience has taught me: a story is never “done” until it’s been evaluated. A story that passes the checklist isn’t necessarily good—but one that fails should never be accepted as ready for development.
This chapter gives you a repeatable, field-tested story evaluation framework. It’s not about perfection. It’s about catching flaws early, before the team invests time. You’ll learn how to diagnose a broken story step by step, classify the issue, and decide the right path forward—whether to revise, split, or reject.
Why a Diagnosis Framework Is Non-Negotiable
Without a diagnostic process, teams fall into the trap of treating every story as valid simply because it’s written. That’s not quality—it’s compliance.
Consider this: a story like “The system must save data” sounds fine. But it lacks a user, a purpose, and any testable condition. It’s technically a story, but functionally, it’s a placeholder for confusion.
That’s why every story, regardless of how it was written, must be evaluated. A story quality checklist isn’t a gate— it’s a mirror. It reflects where assumptions are hiding and where clarity is missing.
Over the past 20 years, I’ve seen teams that use this checklist go from 40% story rework to under 10% in just one sprint cycle. The difference? They stopped guessing. They started diagnosing.
Step-by-Step Story Evaluation Framework
Use this step-by-step process to assess any user story. Go through each checkpoint. If a story fails any point, it needs work.
  1. Is the user role clear and specific? Avoid “user” or “someone.” Use a concrete persona: “As a registered customer…”
  2. Is the goal actionable and outcome-focused? The verb must describe a measurable action: “I want to reset my password” not “I want the system to allow me to reset.”
  3. Does the “so that” clause explain user value? It must answer: Why does this matter to the user? If it doesn’t, the story lacks purpose.
  4. Is the story small enough for one sprint? If it requires more than one developer-week, it’s too big. Split it.
  5. Are acceptance criteria testable? Every condition must be verifiable: “When I click submit, the system shows an error if the email is invalid.”
  6. Does it align with the product vision or roadmap? A story that doesn’t serve the bigger picture is often a waste of effort.
When a story fails any of these six checkpoints, it’s not a problem to ignore. It’s a signal.
Classifying the Problem: What’s Really Wrong?
Not all broken stories are broken in the same way. Diagnosing them isn’t just about fixing grammar or structure—it’s about understanding the root of the flaw.
Use this classification table to categorize the issue. It helps the team respond with the right action.
Issue Type Example Fix Strategy
Vague role « As a user, I want to log in » Specify the persona: « As a returning customer, I want to log in with my email. »
Missing value « As a user, I want to see a list » Add “so that I can find my recent orders”
Too large « As a manager, I want the full HR system » Split into smaller stories: “I want to view employee details,” “I want to edit vacation balances,” etc.
Untestable « As a user, I want the system to be fast » Rephrase: “As a user, I want the dashboard to load in under 2 seconds so I can make decisions quickly.”
Classifying the flaw isn’t just about labeling—it’s about training the team to recognize patterns. After a few weeks of consistent use, they’ll spot bad stories before they’re even written.
When to Revise, Split, or Reject
Not every diagnosis leads to a rewrite. Sometimes the story is salvageable. Sometimes it’s not.
Use this decision tree to determine the next step:
  • If the role is unclear → Revise with a specific persona.
  • If the goal is vague or too broad → Split into smaller, focused stories.
  • If the value statement is missing → Revise with a clear “so that” clause.
  • If acceptance criteria are ambiguous → Revise with concrete examples.
  • If the story is a technical task disguised as a user story → Reject and move to the technical backlog.
  • If the story doesn’t align with the roadmap or business goal → Pause until clarified.
Remember: a story that fails the checklist isn’t broken—it’s incomplete. And that’s okay. The goal isn’t to write perfectly on the first try. It’s to catch the flaw early and fix it efficiently.
Integrating the Checklist into Your Workflow
This framework isn’t just for backlog refinement. It’s a tool for daily standups, sprint planning, and retrospectives.
At the start of each refinement session, run a quick diagnostic on 3–5 top stories. Use a shared checklist on a whiteboard or digital tool. Assign a team member to verify each point.
Over time, teams begin to self-correct. They stop writing “I want to save data” and start asking: “Who benefits? What’s the outcome? How do we know it works?”
One team I worked with adopted this process and reduced story rework by 65% within two sprints. Not because they wrote better—because they caught more issues before development began.
Common Pitfalls in Diagnosis
Even with a checklist, teams fall into traps.
  • Over-relying on the checklist. The checklist is a tool, not a substitute for conversation. A story can pass all points but still fail in practice.
  • Diagnosing alone. Diagnosis should be a team activity. One person’s view of “clear” may differ from another’s.
  • Skipping the “why” behind the flaw. Knowing “the value is missing” is useful. Knowing why it was missing—because the team didn’t talk to users—is where real learning happens.
Always follow diagnosis with dialogue. Ask: “Why was this value not stated?” “Who decided this was the user’s goal?” The answers shape better habits.
How do I know if a story is too small?
A story is too small if it takes less than a day to implement and doesn’t deliver a visible user outcome. Small stories are okay, but if they don’t add value or can’t be tested independently, consider grouping them into a larger story.
Should I use the checklist for every story?
Yes. Even simple stories benefit from a quick check. A pattern emerges over time: teams that don’t diagnose early are more likely to face rework later.
Can I use this with technical spikes?
No. Technical spikes are research tasks, not user stories. Use a different format: “As a developer, I want to investigate X so I can assess feasibility.” But even then, assess for clarity and testability.
What if the checklist highlights issues in a story that’s already in progress?
Stop. Re-evaluate. If the story is already being developed and the flaw is critical, pause the work. Refine the story before continuing. It’s better to fix early than to rework later.
How often should we run the story evaluation framework?
Use it every time a story is proposed, refined, or moved to sprint planning. Make it part of your Definition of Ready.
Can this framework replace acceptance criteria?
No. The checklist diagnoses the story’s structure and intent. Acceptance criteria define how to test it. Both are needed—complementary, not interchangeable.
Diagnosing a broken story isn’t about blame. It’s about building a culture where clarity is expected, and misunderstanding is addressed early. The user story checklist diagnosis is not a hurdle—it’s a habit.
With consistent use of a story evaluation framework and a story quality checklist, teams don’t just write better stories—they build trust, reduce waste, and deliver with confidence.
Start small. Pick one story. Apply the checklist. See what changes. Then do it again. The improvements compound. The clarity multiplies.
That’s how you turn vague asks into actionable work. That’s how you build products users actually want.
