Missing or Misused Story Structure
Temps estimé :8 minutes 57 vues
Never write a user story without a clear ‘As a / I want / so that’ structure. I’ve seen teams ship features that no one wanted—just because the story wasn’t built around a real user, goal, or outcome. This single guardrail prevents 90% of ambiguity-driven rework.
When the format is ignored or misused, the story ceases to be a conversation starter and becomes a command, a task, or a vague promise. That’s not a user story—it’s a technical specification in disguise.
You’ll learn how to spot faulty structure, correct common story writing mistakes, and build stories that actually get understood, tested, and delivered. I’ll walk through real examples of bad user story format and how to fix them with precision and clarity.
Why Story Structure Matters
The ‘As a / I want / so that’ format isn’t a formality. It’s a proven mechanism for forcing clarity about three core elements:
  • Who the story serves (the role)
  • What they need (the goal)
  • Why it matters (the value)
Skipping any part breaks the chain. Without the role, you’re not speaking to a real person. Without the goal, you’re describing a task, not a need. Without the outcome, you can’t verify if it was successful.
When teams cut corners, they end up with stories that read like project management directives—“Add login form”—which sounds like a task, not a story. That’s a red flag: if you can’t rephrase it as a user’s desire, it’s not a story.
Common Patterns of Poor Structure
Here are the most frequent user story format errors I’ve seen across 200+ backlogs:
  • Missing the ‘As a’ clause – “I want to see my order history” – No role specified. Who is “I”?
  • Missing the ‘so that’ clause – “As a shopper, I want to filter by price” – But why? What benefit does it provide?
  • Replaced with technical jargon – “As a developer, I want to use JWT authentication” – This isn’t a user story. It’s a system requirement.
  • Overloaded with details – “As a customer who has previously made a purchase and lives in California, I want to receive personalized offers…” – Too many conditions in the role.
These errors aren’t just cosmetic. They undermine the entire Agile process by weakening conversation, testing, and prioritization.
Real Examples: Bad vs Good User Story Format
Let’s look at actual cases where story writing mistakes led to real delays and rework.
Example of Bad User Story Format
Bad: “I want to add a filter to the product list.”
This is a task disguised as a story. No user, no purpose, no value. What does “add a filter” even mean? By whom? Why?
Developers might build a dropdown, a slider, or a search bar—without knowing which suits the user’s actual need.
Fixed: “As a shopper browsing products, I want to filter by price range so that I can quickly find items I can afford.”
Now we know: the user is a shopper, the goal is filtering by price, and the outcome is affordability. Acceptance tests can be written: “Show only products under $100.”
This is a real user story. It invites discussion. It’s testable. It delivers value.
Another Example of Bad User Story Format
Bad: “As a user, I want to log in with my email and password.”
It’s a common mistake to assume login is a user story. But “log in” is a system function, not a user goal. The user isn’t trying to log in—they’re trying to access their account.
Fixed: “As a returning customer, I want to log in with my email and password so that I can access my order history and view my saved addresses.”
The value is now clear: access to personal data. The story is now about user needs, not technical actions.
When Structure Breaks Down
Even when the format is used, teams often misuse it. Here’s a table showing common misuses and their fixes.
Common Mistake Why It Fails Correct Approach
“I want to update the database” Technical task, not user value “As a customer support rep, I want to update the status of a case so that I can track resolution progress.”
“As a user, I want search” Too vague—what are you searching for? Why? “As a shopper, I want to search by product name so that I can quickly find what I’m looking for.”
“As a manager, I want reports” No purpose, no outcome “As a product manager, I want a weekly summary of user engagement so that I can assess feature adoption.”
Each correction introduces clarity, purpose, and a measurable outcome. That’s how stories become actionable and testable.
How to Fix Structural Flaws
If you’re reviewing a backlog and spot a broken story, ask these three questions:
  1. Who is the user? Can you name a real person or role the story is built for?
  2. What are they trying to do? Is the goal clear and user-centered?
  3. Why does it matter? Can you explain the benefit to the user or business?
If any answer is “no,” the story needs work.
Start by isolating the user. Replace “I want” with “As a [role], I want [goal] so that [outcome].” Then test each clause:
  • Is the role specific? “Customer” is better than “user.”
  • Is the goal action-oriented and focused? “See my order details” is clearer than “view order info.”
  • Is the outcome meaningful? “So that I can track my purchases” adds value; “so that I can see my orders” is just restating.
There’s a rhythm to good story writing: identify, clarify, connect. The structure is the scaffold.
When to Deviate (and When Not To)
Some teams argue that the format is rigid. I’ve heard, “We don’t need ‘As a’ every time.” That’s dangerous.
One exception: sprint planning or refinement sessions where the context is already established. But even then, the role and value must still be evident.
If you’re writing standalone stories, never skip the format. The value of the structure isn’t in the words—it’s in the discipline it enforces.
And if you must shorten, do so only after agreement. Replace “As a shopper, I want to filter by price” with “As a shopper, filter by price” only if the team collectively agrees it’s unambiguous. Never assume.
What happens if I skip the ‘so that’ clause?
Without a purpose, the story becomes a task. You lose the ability to verify value. Acceptance criteria will be vague. Teams often build something that works technically but fails to meet user needs.
Can a user story be a single sentence?
Yes, but only if all three parts are present. “As a user, I want to save my work so that I don’t lose progress” is valid. But “I want to save” is not a story—it’s a fragment.
Is it okay to write stories without a role?
No. Every story must represent a real user or stakeholder. “I want to update the page” lacks context. Who is “I”? What do they need? Without a role, the story can’t be evaluated for relevance or value.
How do I handle stories with multiple users?
Write separate stories for each role. Don’t combine “As a shopper and a seller, I want to list products.” That’s two different goals. Instead, split: “As a shopper, I want to search for items” and “As a seller, I want to list my products.”
Can technical stories be written in ‘As a’ format?
Not directly. Technical stories are chores or enablers. They should be separate from user stories. If you have a story like “As a developer, I want to refactor the login module,” it’s a technical task, not a user story. Use a separate backlog for engineering work.
What if the user role is complex?
Keep it simple. If you find yourself writing “As a customer who has made over five purchases and lives in New York,” consider splitting it. Focus on one primary role. You can still capture edge cases in acceptance criteria, but the story should center on a single user.
Mastering user story format is not about memorizing a template. It’s about developing a habit of asking: Who? What? Why? That’s the real skill. And it’s the key to avoiding story writing mistakes that derail entire projects.
