Adapting CRC Concepts to Business or UX Modeling
Temps estimé :7 minutes 60 vues
Too many teams start business process modeling with swimlanes and flowcharts, treating roles and systems as static boxes to be connected. It’s a common trap: these diagrams look structured but often miss the real issue — who is *responsible* for what, and what do they *do* when they collaborate? That’s where CRC for business modeling shifts the focus from “what happens” to “who does what.”
After years of facilitating design sessions across software, finance, and healthcare teams, I’ve seen the same pattern: confusion arises not from complexity, but from vague responsibility assignment. CRC cards, even in non-software contexts, offer a lightweight yet powerful way to clarify who owns what — not just in code, but in real business processes and user experiences.
This chapter will show you how to apply CRC thinking outside of code. You’ll learn how to translate business roles into classes, define actionable responsibilities, and identify critical handoffs between departments or UX states — all while keeping the model simple, collaborative, and grounded in real decision-making.
Why CRC Works Beyond Code
Traditional business modeling often focuses on *what* happens: “The invoice is reviewed,” “The form is submitted.” But what if we asked: “Who is responsible for reviewing the invoice?” and “What does that person actually *do*?” That shift — from process steps to responsible agents — is where CRC shines.
When you use CRC for business modeling, you’re not just diagramming workflows. You’re modeling responsibility allocation, handoffs, and decision points. This is especially powerful in cross-functional teams where boundaries blur and ownership is ambiguous.
Consider a loan approval process. A flowchart might show: “Application → Review → Approval → Disbursement.” But with CRC, you define actual roles: Loan Officer, Underwriter, Compliance Analyst. Each becomes a class with clear responsibilities.
For example:
  • Loan Officer: Collects applicant documents. Explains loan terms. Submits application.
  • Underwriter: Assesses creditworthiness. Verifies income. Makes approval recommendation.
  • Compliance Analyst: Checks regulatory requirements. Flags high-risk cases. Signs off on compliance.
Now the workflow isn’t just a sequence — it’s a chain of responsibilities with defined handoffs.
From Flowchart to Responsibility Map
Here’s how to convert a standard process diagram into a CRC-based model:
  1. Identify real-world agents: Replace abstract process steps with actual people, roles, or systems.
  2. Define responsibilities: Use active verbs. Avoid “handles,” “manages,” or “involves.” Instead, say “evaluates credit history” or “confirms identity.”
  3. Map collaboration: Show what each agent *does* and what they *need* from others.
  4. Validate handoffs: At each boundary, ask: “What does the next agent receive? Is it clear, unambiguous, and complete?”
This approach surfaces gaps and overlaps that flowcharts often hide. For instance, if both the Loan Officer and Underwriter are responsible for “checking employment,” it’s a red flag — who owns it? CRC forces clarity.
Applying CRC UX: Designing User-Centered Flow
UX designers increasingly use CRC for business modeling to align user journeys with operational realities. When a user completes a form, the backend may need to trigger multiple actions — but the user only sees one step.
Here’s where CRC UX helps: model not just the user action, but the *system’s responsibility* behind it.
Take a customer onboarding flow:
Example: Onboarding Process CRC Model
Class Responsibility Collaboration
User Provides personal and financial details. Interacts with onboarding form.
Onboarding Form Validates input format. Stores data temporarily. Relays to Identity Verification.
Identity Verification Checks ID documents. Confirms identity via third party. Notifies Compliance and Onboarding Workflow.
Compliance System Checks AML/KYC rules. Flags suspicious patterns. Signals back to Onboarding Workflow.
Onboarding Workflow Coordinates steps. Notifies user of status. Depends on all above.
This model does more than document steps — it reveals who determines success, what decisions are made where, and where delays are likely. It’s a blueprint for UX, operations, and compliance.
Why CRC UX Reduces Misalignment
Too often, UX designers assume the backend will “just handle it.” But when responsibilities are not defined, handoffs become ambiguous — leading to delays, errors, or frustration.
Using CRC UX ensures that every interaction has a clear owner. A user sees “Document verified” — but who verified it? What criteria? CRC makes the invisible visible.
It also helps teams identify where automation can replace manual steps. If a system is responsible for “checking credit history,” and the input is always the same, perhaps that step can be automated — but only if the responsibility is clear.
Non-Software CRC: Real-World Applications
CRC isn’t just for software teams. I’ve used non-software CRC in healthcare, insurance, and even nonprofit operations. The principles remain the same — classes, responsibilities, collaborations — but the context changes.
Example: Hospital Patient Admission Process
Instead of a flowchart showing “Admission → Registration → Room Assignment,” map it with CRC:
  • Receptionist: Gathers patient info. Logs admission. Contacts nurse.
  • Nurse: Confirms medical history. Prepares patient for exam. Assigns room.
  • Admitting Physician: Reviews case. Orders tests. Approves admission.
  • Admission Coordinator: Manages bed availability. Updates system. Notifies department.
Now, when a patient arrives and the nurse says, “We need the doctor,” you can ask: “Who is responsible for confirming the physician is on duty?” This prevents delays.
These models don’t replace process flowcharts — they complement them. You can use CRC to annotate and validate the flow.
Business Responsibility Mapping: A Step-by-Step Approach
Here’s a proven way to apply CRC for business modeling:
  1. Identify key stakeholders: Who is involved in the process? Name real roles, not labels like “System A” or “Team B.”
  2. Define one clear responsibility per role: Use a verb + object. “Verifies identity” not “Manages verification.”
  3. Map handoffs: What information or artifact does each agent receive? Is it complete? Is it timely?
  4. Check for redundancy or gaps: Does one role do too much? Is there an unassigned step?
  5. Revisit in iteration: After implementation, review whether the model still holds. Update as needed.
When done well, business responsibility mapping with CRC becomes a living document — a shared mental model that evolves with the process.
Even simple models can go off track. Here are the most common mistakes in non-software CRC and how to fix them:
  • Too many responsibilities per class: A single agent shouldn’t be responsible for “managing,” “reviewing,” and “approving.” Split them.
  • Vague responsibilities: “Handles documents” is too broad. Be specific: “Sends documents to compliance for review.”
  • Ignoring handoffs: If the nurse receives data but doesn’t know what to do with it, the model is incomplete.
  • Misaligned ownership: If the system says “approve” but no one is accountable, the process breaks.
Always ask: “If this responsibility fails, who is accountable?” If no one, then the model is incomplete.
How do I know which roles to include in a business CRC model?
Include every party that performs a distinct action. Start with the people or systems directly involved in key steps. If one person handles “data entry,” but another “reviews it,” they are two classes. Avoid grouping roles that perform different functions.
Can CRC UX help with user research or personas?
Yes — but not directly. CRC doesn’t replace personas, but it complements them. Use personas to understand *who* the user is, and CRC to define *what they do* and *who they depend on*. Together, they create a clearer picture of user-centered workflows.
What if multiple teams own a responsibility?
This is a red flag. CRC helps identify shared responsibilities — but it should be explicit. If two teams share a duty, define how they coordinate: “Team A initiates, Team B confirms.” This clarifies ownership and prevents gaps.
How do I keep CRC models from becoming outdated?
Treat CRC models as living artifacts. Review them after major process changes or audits. Update only when the responsibility or handoff changes. Use versioning or labels like “Q3 2024” to track updates.
Is CRC UX the same as user journey mapping?
No. User journey maps focus on emotions, touchpoints, and experiences. CRC UX focuses on *responsibilities* and *handoffs*. You can use both together: the journey map shows the user’s path, and CRC UX explains what actually happens behind the scenes.
Can I use CRC for non-technical teams without training?
Yes — but with caution. Start simple: use sticky notes, write one responsibility per card, and ask “Who does this?” in a group setting. Avoid jargon. The goal is clarity, not perfection. With practice, teams learn to think in responsibilities naturally.
