Basic Scaling Concepts: Growing Scrum Sensibly
Temps estimé :7 minutes 57 vues
Too many teams start scaling Scrum by copying frameworks without understanding the core principle: it’s not about adding more ceremonies, it’s about preserving empirical control. For years, I’ve seen teams grow from one to five teams, only to lose alignment, transparency, and rhythm. The real breakthrough comes not from process complexity, but from simplicity. I’ve watched teams thrive when they focused on shared goals, not just more meetings.
Scaling Scrum basics isn’t about doubling down on structure. It’s about creating conditions where teams remain autonomous, yet coordinated. This chapter equips you with practical strategies to grow without fragmentation. You’ll learn how to balance autonomy with alignment, avoid common scaling pitfalls, and keep your teams delivering value—no matter how many teams you have.
When to Consider Scaling Scrum
Scaling isn’t about team size alone. It’s about complexity, dependencies, and delivery pressure. If you’re facing these, scaling may be necessary—but not automatic.
Ask yourself: Are you delivering features that require cross-team coordination? Are sprint goals being blocked by teams waiting on others? Is it taking weeks to integrate work from different groups?
These are signs the team structure is no longer sustainable. But don’t rush to scale. Start with a single, well-structured Scrum team. If you can get a working, stable delivery rhythm, then scale with intention.
Key Triggers for Scaling
  • Work spans multiple product areas with shared dependencies
  • Multiple teams are working on the same product with integrated deliverables
  • Sprint goals are being compromised due to inter-team bottlenecks
  • Stakeholders are waiting for weeks to see end-to-end completed features
  • Backlog refinement becomes unmanageable for one Product Owner
Scaling is not a milestone. It’s a response to need. Treat it like a tool—not a trend.
Introducing Scrum of Scrums: The Heart of Coordination
Scrum of Scrums is not a new role. It’s not a formal event. It’s a meeting structure for aligning multiple teams. It’s where shared dependencies, sprint progress, and blockers are surfaced.
Think of it as the Scrum team’s version of a coordination hub. It’s not about control—it’s about visibility. The goal isn’t to micromanage, but to ensure that inter-team handoffs are smooth and risks are caught early.
How to Run a Scrum of Scrums
Each team designates a representative—typically the Scrum Master or a senior developer. They attend the meeting to share updates, not to report on every task, but on the big picture.
Keep it time-boxed: 15 minutes per team is a good baseline. Use a simple format:
  1. What did your team deliver this sprint?
  2. What’s your plan for the next sprint?
  3. What blockers are impacting your progress or other teams?
These answers are not about details—they’re about spotting risks and dependencies early.
Scrum of Scrums Introduction: Practical Example
I once worked with a fintech startup with five teams building a mobile banking platform. Each team owned a module, but features like account transfers required coordination across three teams.
They introduced a Scrum of Scrums every Monday. Each team’s representative reported on progress and shared any blockers—like a shared API delay. By week three, they caught a dependency conflict before it became a sprint-ending issue.
That’s the power of Scrum of Scrums introduction: early awareness leads to proactive resolution.
Scaling Scrum for Beginners: Step-by-Step Guidance
Scaling Scrum for beginners doesn’t mean adding more roles or events. It means layering coordination on top of strong fundamentals.
Start with one team. Once stable, add teams—only when the Product Owner can still manage the backlog effectively.
Five Steps to Scale Scrum Responsibly
  1. Define a shared product vision: All teams must work toward the same business outcome. This keeps priorities aligned.
  2. Establish shared Definition of Done: Without a consistent quality bar, integration becomes chaotic.
  3. Create a single, prioritized product backlog: Use backlog refinement with all teams involved, not just one.
  4. Implement Scrum of Scrums: Hold regular coordination meetings (daily or every few days) to surface dependencies.
  5. Monitor and adapt: Use metrics like cross-team cycle time or sprint goal achievement rate to assess scaling health.
These steps prevent the “fragmentation trap”—where teams deliver independently but fail to deliver together.
Common Scaling Pitfalls to Avoid
Scaling isn’t inevitable. It’s a choice. And like any choice, it comes with trade-offs. Here are the most common mistakes I’ve seen teams make.
1. Creating Too Many Coordination Layers
Adding more meetings doesn’t fix the problem. It creates overhead. If you’re holding Scrum of Scrums twice a week and sprint planning takes two hours, you’re losing time to coordination, not delivery.
Prioritize what matters. Use the 80/20 rule: focus on the 20% of dependencies that cause 80% of delays.
2. Losing the Product Owner’s Focus
When multiple teams are involved, the Product Owner can easily become overwhelmed. The risk? Prioritization drift. Features get pushed forward because « someone’s waiting, » not because they’re valuable.
Solution: Consider splitting the product into domains. Assign a product owner per domain, with a single lead owner for overarching vision.
3. Over-Engineering the Process
Some organizations turn Scrum of Scrums into a reporting machine: teams must present slides, status charts, and impact analyses.
That’s not scaling. That’s bureaucracy. Keep it simple: one slide max, one goal, one blocker. If it feels heavy, it’s too heavy.
Scaling Scrum vs. Other Frameworks
Scrum of Scrums is not the only way to scale. But it’s the only one built on the same principles: transparency, inspection, and adaptation.
Compare it to SAFe or LeSS:
Aspect Scrum of Scrums (Scalable) SAFe LeSS
Complexity Low High Medium
Autonomy High Low Very High
Training Required Minimal Extensive Moderate
Best For Small to mid-sized teams Large enterprises with rigid governance Organizations with strong culture of autonomy
For beginners, Scrum of Scrums introduction is the right starting point. It preserves the spirit of Scrum while enabling growth.
How many teams can Scrum of Scrums effectively coordinate?
There’s no hard limit, but 5–8 teams is a practical range. More than that, and meetings become unwieldy. Consider breaking into clusters with a lead coordinator.
Who should attend the Scrum of Scrums meeting?
A representative from each team—usually the Scrum Master or a senior developer. They don’t need to be the top performer. They need to understand the team’s progress and dependencies.
Can I scale Scrum without a Scrum of Scrums?
Yes, but only if teams are loosely coupled. If they share code, APIs, or deployment pipelines, coordination becomes essential. Scrum of Scrums is the simplest way to build that.
What if my teams are in different time zones?
Rotate meeting times so no one is always at a disadvantage. Use asynchronous updates via shared documents. The goal is alignment, not real-time presence.
How often should Scrum of Scrums happen?
At minimum, once per sprint. For high-dependency work, daily syncs work. The rhythm should match the pace of integration.
Is Scrum of Scrums introduction suitable for non-software teams?
Absolutely. I’ve run it with marketing, operations, and product teams. The principles of transparency and dependency management apply everywhere.
Do I need a separate Scrum Master for each team when scaling?
Yes, each team should have its own Scrum Master. But they can co-locate or share coordination responsibilities. The focus is on servant leadership—not command and control.
