Advanced Extensions: Using CRC Insights for Sequence or Use Case Diagrams
Leitura estimada: 7 minutos 47 vistas
Many teams treat CRC cards as a one-off brainstorming phase—fill them out, move to class diagrams, and forget them. But that’s a missed opportunity. The real power of CRC models lies not just in defining static structure, but in revealing how objects interact over time.
When you’ve captured responsibilities and collaborations on CRC cards, you’re not just naming classes—you’re outlining a narrative. That narrative is the seed for sequence diagrams, where behavior unfolds across time and objects.
Don’t jump to drawing interactions without first mapping what your CRC cards already tell you. The best sequence diagrams don’t emerge from guesswork—they emerge from the logic already present in your CRC insights.
By the end of this chapter, you’ll know how to extract behavioral intent from CRC modeling, translate it into sequence diagrams using real-world patterns, and leverage multi-view UML modeling to maintain consistency across your architecture.
Why Sequence Diagrams Start with CRC Responsibility
Sequence diagrams are not standalone; they’re derived. They show the flow of messages between objects over time, which means they need a foundation in object behavior.
The key is to treat each responsibility on a CRC card not as a static method name, but as a potential message in a sequence.
For example: a Book object with the responsibility “check out to member” isn’t just a function—it’s an action that happens across a timeline involving a Member and a LibrarySystem.
Here’s how to extract that into a sequence diagram:
  1. Identify the primary object initiating the interaction.
  2. List all objects involved in fulfilling the responsibility.
  3. Map each responsibility as a message in the correct order.
  4. Use the CRC collaboration relationships to determine message direction.
This is where CRC extension use becomes powerful: your earlier brainstorming already defines the roles and timing of interaction.
From Responsibility to Message: A Practical Mapping
Consider a CRC card for OnlineOrder with responsibility: “submit payment via credit card.”
This isn’t just a method—it’s a sequence of steps:
  • OnlineOrder sends “validateCard” to CreditCard.
  • CreditCard returns “valid” or “invalid.”
  • If valid, OnlineOrder sends “charge” to PaymentGateway.
  • PaymentGateway confirms “charged” or “failed.”
  • OnlineOrder updates status accordingly.
That sequence, derived directly from CRC responsibilities, is now the skeleton of your sequence diagram.
Don’t invent behavior—reveal it. The CRC model already contains the intent.
CRC to Use Case: Mapping Roles to Actors
Use case diagrams often start with user stories or interviews. But when you have a solid CRC model, you can derive use cases with precision.
Each major responsibility on a CRC card can become a use case. The object performing the responsibility becomes the primary actor—or the system if it’s internal.
For example: CRC card for Administrator with responsibility “delete user account.”
This directly maps to a use case: Delete User Account, with Administrator as the actor.
But here’s where it gets deeper: CRC collaborations help define the flow of events. If the Administrator must consult SystemLog before deletion, that’s a pre-condition or an extension point.
Use case diagrams built from CRC insights are more consistent and behaviorally accurate than those built from vague user stories.
Mapping CRC to Use Case: A Step-by-Step Workflow
  • Step 1: Extract all responsibilities from CRC cards that involve external interaction.
  • Step 2: Identify the object initiating the action—it becomes the use case.
  • Step 3: List collaborating objects as part of the use case’s actors or supporting systems.
  • Step 4: Use CRC collaboration relationships to define the boundaries of the use case.
  • Step 5: Refine with scenarios: when does it fail? When is validation needed?
This process ensures your use cases are not just named after features, but grounded in real object behavior.
Building a Consistent Multi-View UML Model
One of the most common missteps is treating UML diagrams as isolated artifacts. But the real value comes from alignment across views.
When you derive sequence diagrams from CRC responsibilities and use cases from CRC roles, you create a multi-view UML modeling system where each diagram reinforces the others.
Here’s how the pieces connect:
UML View Source in CRC Model Key Insight
Class Diagram Classes, Responsibilities, Collaborations Structure: what objects exist and what they can do.
Use Case Diagram Responsibilities involving external interaction Role: who triggers what behavior.
Sequence Diagram Order of responsibilities and collaborations Behavior: the flow of messages over time.
Each view should be traceable to the CRC model. If you can’t point to a CRC card for a particular sequence message or use case, you’ve gone off-script.
Use case diagrams become more than documentation—they become a direct reflection of how your team thinks about responsibility.
Advanced CRC Extension Use: Beyond the Diagram
Once you’ve linked CRC insights to use case and sequence diagrams, you can extend the model further.
For example: if a sequence diagram shows repeated use of “validate” across multiple steps, that suggests a shared validation service. That insight can be returned to the CRC model to introduce a new object: Validator.
This creates a feedback loop: CRC extension use becomes a path for continuous refinement. You don’t need to start over—you build on what you’ve already validated.
Another example: if a sequence shows inconsistent error handling, revisit the CRC cards for the involved objects. Ask: “Did we miss an error response in the responsibility?”
That kind of feedback is only possible when you maintain the link between CRC and higher-level diagrams.
Even with a solid CRC foundation, teams still stumble when building sequence or use case diagrams.
  • Pitfall 1: Creating sequence diagrams with objects not present in the CRC model. Solution: Only include objects that were already in the CRC collaboration.
  • Pitfall 2: Overloading sequence diagrams with irrelevant messages. Solution: Focus only on messages that fulfill the responsibility—omit fluff.
  • Pitfall 3: Treating use case diagrams as high-level summaries instead of traceable artifacts. Solution: Each use case must map back to at least one CRC card.
  • Pitfall 4: Ignoring the temporal order in sequence diagrams. Solution: Use the CRC responsibility sequence as your guide.
These aren’t just technical rules—they’re guardrails for maintaining design integrity.
How do I know if my CRC model is ready for sequence diagrams?
When you’ve identified at least two objects and a clear flow of responsibilities, you’re ready. The CRC card should describe a sequence of actions, not just isolated tasks.
Can I create sequence diagrams without a class diagram?
Yes, but not effectively. The class diagram grounds your sequence diagram in real objects. Without it, you risk modeling with unverified or fictional objects.
How does CRC to use case mapping help in agile teams?
It turns user stories into executable models. A story like “As a user, I want to cancel my order” becomes a clear use case: “Cancel Order,” triggered by the User object, supported by Order and PaymentProcessor—all from CRC cards.
What if multiple CRC cards have the same responsibility?
That’s a sign of shared behavior. Consolidate into a single use case or sequence fragment. Use CRC to identify whether this is duplication or intentional parallelism.
Can CRC insights help with exception handling in sequence diagrams?
Absolutely. When a CRC responsibility includes “handle errors,” map that as a conditional branch in the sequence. The collaboration with ErrorLog or NotificationService becomes part of the flow.
How often should I revisit CRC cards during design refinement?
At every major design review. Use them as living documents. If a sequence diagram reveals a missing object, update the CRC card. This is CRC extension use at its finest—evolution through insight.
