Diagrams Without Narrative: No Supporting Explanation
Geschätzte Lektüre: 6 Minuten 218 Ansichten
“This diagram shows how the system works.” That’s the most common sentence I hear from analysts when they hand over a DFD. It’s a start—but it’s not enough.
Even a perfectly laid out, flawlessly structured DFD can fail if it lacks context. A diagram without narrative is like a book without a table of contents: it may contain all the right words, but no one knows where to begin.
As someone who’s reviewed hundreds of DFDs over two decades, I’ve seen how easy it is to assume the structure speaks for itself. It doesn’t. The real value of a DFD lies not just in its elements, but in the story they tell—and that story must be told.
What you gain from this chapter is a practical framework for turning your DFDs from isolated visuals into trusted, communicative artifacts. You’ll learn how to write concise explanations, craft meaningful captions and legends, and embed assumptions so clearly that no stakeholder is left guessing.
Why a DFD Needs a Narrative
Diagrams are visual tools—but they don’t replace communication. They’re shorthand for complex logic, and without explanation, they become ambiguous.
Consider this: a single DFD may contain 15 processes, 30 data flows, and 8 data stores. Even if laid out cleanly, a new reader will struggle to answer simple questions:
  • What problem is this diagram solving?
  • Why was this boundary chosen?
  • What does the “Order Validation” process actually do, and how is it different from “Order Processing”?
  • Why does this data flow go to a data store instead of a process?
These aren’t questions best answered by staring at lines. They require a narrative.
Think of the DFD documentation narrative as your model’s executive summary. It answers the “why” behind the structure and sets expectations for how the diagram fits into the bigger picture.
Key Elements of a Strong DFD Narrative
1. Purpose and Scope Statement
Begin with a one-sentence summary of what the diagram is meant to show. Be specific.
Example:
This Level 1 DFD models the data flow during order fulfillment in the customer portal, covering the stages from order submission to shipment confirmation. It excludes payment processing, which is handled in a separate system.
Use this to set boundaries and manage expectations early.
2. Captions That Explain, Not Just Label
Don’t treat captions as afterthoughts. Use them to clarify intent.
Instead of:
Figure 1: Order Processing Flow
Try:
Figure 1: Order validation and dispatch flow. This diagram shows how incoming orders are validated, assigned to warehouses, and scheduled for shipment. The data store ‘Pending Orders’ holds orders not yet processed.
This version tells a story. It explains the flow, defines key components, and helps the reader build mental models.
3. Legends That Clarify Meaning
Legends are not optional—they’re essential for consistency.
When you use custom symbols, color coding, or annotations, document them in a legend.
Example:
Symbol Meaning
Green rectangle External entity controlled by the customer
Dashed line Non-functional or exception flow
Red arrowhead Flow that triggers automation
Even if your team uses standard notation, a legend prevents misinterpretation when diagrams grow complex.
4. One-Page Diagram Summary
For complex models, create a one-page summary that sits before the diagram. This is not a replacement for full documentation, but a scaffold.
Structure it like this:
  • Diagram Title: Order Fulfillment Process
  • Level: Level 1
  • Primary Focus: End-to-end order processing from receipt to dispatch
  • Key Assumptions:
    • Payment is confirmed before order is received.
    • Only one warehouse handles each order.
    • No manual overrides occur at the order validation stage.
  • Intended Audience: Business analysts, developers, and quality assurance leads
  • Relation to Other Diagrams: Links to Level 0 (context) and Level 2 (inventory allocation)
This summary helps readers orient themselves before diving into details. It’s especially useful in large models where context can be lost.
Where to Capture the Narrative
Don’t leave your narrative in a Word document or a comment thread. Embed it where it belongs: with the DFD.
Modern modeling tools like Visual Paradigm allow you to attach narrative text directly.
  • Tool Tip: Use the “Description” field or “Notes” panel in your DFD tool to store the summary and assumptions.
  • Version Control: When using Git or similar, ensure the narrative is saved in the project repository—not just the diagram image.
  • Export Strategy: When generating reports, include narrative sections in PDFs or web exports. Avoid sending images alone.
By anchoring your narrative to the DFD, you ensure that context travels with the artifact—no matter how many times it’s shared or reused.
Practical Checklist: Building a DFD Narrative
Use this checklist every time you finalize a DFD.
  1. Write a 2–3 sentence purpose statement explaining the diagram’s role in the system.
  2. Assign a descriptive caption that goes beyond naming—explain intent and scope.
  3. Create a legend if custom symbols, colors, or annotations are used.
  4. Summarize the diagram in one page: include scope, assumptions, and audience.
  5. Store all narrative content directly in your modeling tool.
  6. Review with a colleague: “Could you explain this diagram in your own words?” If not, revise.
Done right, this process turns a static diagram into a dynamic communication tool.
Real-World Example: The Overlooked Assumption
I once reviewed a DFD where an “Order Confirmation” process sent data to a “Customer Notification” data store. No one questioned it—until a customer complaint surfaced about missing notifications.
Upon review, we discovered the assumption: “The notification system runs separately and is always available.” But in reality, it failed during peak hours.
The DFD had no mention of this. The narrative? Missing.
That’s why documenting assumptions in DFD is not just helpful—it’s critical. A single line in the narrative could have saved days of debugging.
Why not just rely on the diagram itself?
Diagrams are visual, but they can’t show intent, assumptions, or exceptions. Two people can look at the same DFD and interpret it differently. A narrative closes that gap.
How long should a DFD documentation narrative be?
Keep it concise: 150–300 words is ideal. The goal is clarity, not completeness. Save detailed explanations for appendices or supporting documents.
Can I use the same narrative for multiple DFD levels?
No—each diagram has a unique purpose. A Level 0 needs a different narrative than a Level 1. Adjust scope, assumptions, and focus accordingly.
Is a legend necessary for standard DFD notation?
Yes. Even when using standard notation, legends clarify how exceptions, controls, or optional flows are represented. They prevent misinterpretation during reviews.
What if I don’t have time to write a full narrative?
Start small. At minimum, write a one-sentence purpose statement and a short caption. Even that reduces ambiguity. Over time, you’ll build a habit and a template.
How do I ensure stakeholders actually read the narrative?
Make it part of the review process. Ask: “What’s the purpose of this diagram?” If they can’t answer, the narrative isn’t clear. Use it as a quality gate.
