Treating a DFD Like a Flowchart
Geschätzte Lektüre: 7 Minuten 71 Ansichten
It’s a quiet but persistent error: treating a DFD like a flowchart. I’ve seen it in dozens of projects—well-meaning analysts drawing decision points, loops, and control logic into diagrams meant for data movement. The result? A model that confuses business stakeholders, misleads developers, and undermines the very clarity DFDs are designed to provide.
Let me be clear: DFDs are not flowcharts. They don’t track control flow. They map how data moves and transforms across a system. This distinction isn’t just academic—it’s foundational. When you mix data flow with control logic, you’re not modeling the system—you’re modeling a sequence of decisions that may not even reflect what the data actually does.
This chapter shows you why this mistake happens, how to recognize it, and when to switch to the right tool. I’ll walk you through a real-world example side-by-side: one DFD, one flowchart, built from the same scenario. You’ll see where the lines blur—and how to keep them separate.
The Core Difference: Data Flow vs Control Flow
At the heart of the DFD vs flowchart mistake is a simple but profound separation: data flow versus control flow.
Data flow tracks *what* data moves, *where* it comes from, and *how* it changes. Think: „The customer order arrives → validated → stored in the database → sent to fulfillment.“
Control flow tracks *how* the system proceeds: decisions, loops, conditional branching. Think: „If the order is valid, proceed to payment. Else, reject and notify user.“
These are not interchangeable. When you draw a decision diamond in a DFD, you’re shifting from a data model to a procedural one. That breaks the model’s integrity and makes it harder to maintain.
When You Should Use a DFD
  • When documenting system boundaries and external entities.
  • When tracking data transformations across processes.
  • When the goal is to understand *what data is involved*, not *how it’s processed*.
  • When working with business analysts, system designers, or compliance reviewers who care about data lineage.
When You Should Use a Flowchart or BPMN
  • When modeling complex business rules or workflows.
  • When tracking user interaction, conditional logic, or looping processes.
  • When developers need to understand execution order or error handling.
  • When you’re designing a microservice orchestration or a state machine.
Using DFD as flowchart is a classic case of mismatched tooling. It’s like using a wrench to hammer a nail. The tool isn’t wrong—but the application is.
Real Example: Processing a Customer Order
Let’s take a simple scenario: a customer places an order. The system validates it, stores it, and sends a confirmation. We’ll model this in two ways.
Bad Example: DFD with Flowchart Elements
Imagine a DFD that looks like this:
  • Process: „Receive Order“
  • Flow: „Customer Order“ → „Receive Order“
  • Decision Diamond: „Order Valid?“
  • If yes: „Store Order“ → „Send Confirmation“
  • If no: „Reject Order“ → „Notify Customer“
Here, the decision diamond is not a data transformation. It’s a control decision. The DFD now includes flowchart logic—something it was never designed to capture. The flow lines split based on a condition, which is not a data flow but a control flow.
This creates confusion. What data flows out of „Reject Order“? The rejection notice? The original order? The diagram doesn’t clarify. It’s ambiguous.
Correct Example: Clean DFD
Now, a proper DFD would have:
  • Process: „Validate Order“
  • Input: „Customer Order“ → „Validate Order“
  • Output: „Valid Order“ → „Store Order“
  • Output: „Invalid Order“ → „Log Error“
The decision isn’t drawn as a diamond. Instead, the process „Validate Order“ produces two output flows based on the result of a logical check. The data flows are clear: valid data goes one way, invalid data another.
Now, if you need to model the full workflow—conditional checks, looping for retries, state transitions—use a flowchart or BPMN. But keep the DFD focused on data movement.
When to Use DFD vs BPMN: A Decision Guide
Here’s a simple decision tree to help you pick the right tool:
  1. Ask: Is the goal to understand data transformation and movement?
    • Yes → Use DFD.
  2. Ask: Is the goal to understand sequencing, branching, or decision logic?
    • Yes → Use flowchart or BPMN.
  3. Ask: Is the process both data and control-heavy?
    • Yes → Use both. Model the data flow in a DFD. Model the control logic separately in BPMN.
Don’t force one diagram to do everything. The best models are often multiple views, each serving a specific purpose.
Common Warning Signs You’re Using DFD as Flowchart
Look for these red flags in your DFDs:
  • Decision diamonds (•) used to represent conditions.
  • Looping arrows that return to a process without a data change.
  • Arrows branching based on “if-then” logic without clear data output.
  • Processes with names like “Check Eligibility” or “Handle Payment” that imply control, not data transformation.
  • Multiple outputs from a process that aren’t tied to data variations.
If you see these, you’re likely modeling control logic, not data movement. Step back. Ask: What data is being transformed? What happens to it? Then reframe the process accordingly.
Best Practices: Keep DFDs Clean and Focused
Here’s how to maintain integrity when modeling:
  1. Use verbs for process names: “Validate,” “Transform,” “Store,” “Generate.” Avoid “Handle,” “Process,” or “Manage.”
  2. Only one input per decision: If a process must check a condition, let the decision happen in the process logic, not in the diagram.
  3. Model data, not control: Every output must represent a data state, not a decision outcome.
  4. Use BPMN for complex workflows: When you need branching, looping, or timers, use BPMN. Keep your DFDs simple, focused, and data-centric.
  5. Document assumptions: If a process includes logic not visible in the DFD, call that out in the documentation, not in the diagram.
Resist the urge to turn DFDs into flowcharts. The model loses its power when control logic intrudes.
Can I use DFD to model a business rule like “If the order exceeds $1000, require manager approval”?
No—this is control flow. Model the data: “Order above $1000” → “Flag for Approval.” Then use BPMN or a flowchart to model the approval workflow. The DFD only shows that the data exists and how it moves.
Why does it matter if I mix control and data logic in one diagram?
It creates ambiguity. If a process produces two outputs—one for valid data, one for invalid—it’s unclear what happens to the invalid data. Is it rejected? Retained? Sent for review? Mixing control logic hides the real data flow and makes the model hard to validate, test, and maintain.
When should I use DFD instead of BPMN?
Use DFD when you care about data movement, lineage, and system boundaries. Use BPMN when you care about process steps, decision logic, and user interaction. They serve different purposes. Avoid forcing one to replace the other.
Is it ever acceptable to include a loop in a DFD?
Yes—but only if it represents data flow, not control. For example, “Retry Failed Payment” can loop back to “Process Payment” if the failure is due to a temporary error. The data (failed payment record) flows back in. The loop is about data, not decision-making.
How do I explain the difference to a team that’s used to drawing flowcharts in DFD?
Show them the side-by-side example: one with decision diamonds, one without. Ask: “What data flows from the ‘Reject’ process? Is it the same as the original order?” Then explain: “The DFD shows data movement. The flowchart shows how the system acts.” Use real examples from your project.
Do I need to redraw every DFD that has decision logic?
Not necessarily. Evaluate each case. If the DFD is used for system scope, data lineage, or compliance, then yes—refactor to remove control logic. If it’s for internal design review and the team understands the intent, you may keep it—but add a note: “This includes control logic. Use BPMN for workflow details.”
