Misusing or Mixing DFD Notations
Geschätzte Lektüre: 7 Minuten 64 Ansichten
“Always pick one DFD notation and stick with it.” This advice is repeated everywhere. It sounds simple. But in practice, it fails when teams don’t define what “one” actually means—especially when tools default to different symbols, or when senior analysts use one style while junior members follow another.
Over 20 years of working with DFDs across dozens of projects taught me this: mixing notations isn’t just a visual inconsistency. It erodes trust. New analysts get lost. Stakeholders question whether the flow is even logical. The problem isn’t the notation itself—it’s the lack of clarity about which one is being used, and why.
What you’ll learn here is how to choose, document, and enforce a single DFD notation. You’ll see real examples where mixing notations caused miscommunication. And most importantly, you’ll get practical strategies—using templates, legends, and tooling—to ensure DFD symbol consistency across your team.
Why Mixing DFD Notations Creates Confusion
DFD notations aren’t interchangeable. Yourdon, Gane & Sarson, and custom variants each carry distinct visual logic. When used together, they create cognitive dissonance.
Consider this: a process box with a rounded rectangle in Yourdon notation may be a rectangle with a circle inside in Gane & Sarson. A data store under one becomes a double line in another. These differences aren’t just aesthetic—they signal different meanings.
Now imagine a team where some use Yourdon for interviews, others use Gane & Sarson in documentation, and a third uses a custom icon set in tools like Visual Paradigm. The same process appears differently across three diagrams. Readers can’t trust the logic. They start questioning the model instead of understanding it.
Real-World Consequences of Inconsistent Notation
I once reviewed a DFD where a data store appeared as a double line in one section and as a rectangle with a label in another. A junior analyst assumed it was a process. The developer implemented a function for a storage mechanism that didn’t exist. A simple misunderstanding—rooted in notation mixing—cost three days in rework.
Another example: a context diagram used Gane & Sarson’s external entity symbol (a rectangle with a rounded corner), but the Level 1 diagram used a simple box for the same entity. Stakeholders had no way to verify alignment. Questions arose: “Is this the same system?” or “Why is it drawn differently?”
The damage isn’t just technical. It undermines the entire purpose of a DFD: to make data movement unambiguous. When notation varies, so does interpretation.
Selecting a DFD Notation: Your Best Practice
There’s no single “best” notation. But there is a best practice: choose one and document your choice.
Most teams fall into one of three paths:
  • Default choice: Use the notation built into your modeling tool. If you’re using Visual Paradigm, it defaults to Gane & Sarson. Accept it—but make sure it’s decided.
  • Team agreement: Choose based on team familiarity. If your developers are used to Yourdon, stay with it. If your business analysts prefer Gane & Sarson, adopt it.
  • Hybrid approach: Rarely recommended. Only if you must blend styles—document the rationale and provide a legend.
The key isn’t which notation you pick. It’s whether the team agrees and enforces it.
Compare: Yourdon vs Gane Sarson DFD
To help you decide, here’s a direct comparison of the two most common notations.
Element Yourdon Notation Gane & Sarson Notation
Process Rounded rectangle Rectangle with a circle inside
Data Store Two parallel horizontal lines Two parallel horizontal lines (double line)
External Entity Rectangle with rounded corners Rectangle with a square corner
Data Flow Arrow with a label on the line Arrow with label near the arrowhead
Notice the subtle differences. Not only do they look different, but the placement of labels and the shape of the process can alter perception. A process drawn with a circle inside (Gane & Sarson) may feel “more operational” than a rounded rectangle (Yourdon).
Choose based on clarity, not preference. Ask: “Which notation reduces ambiguity when explaining to non-technical stakeholders?”
Documenting Your Chosen Notation
Choosing a notation isn’t enough. You must document it.
Every DFD project should begin with a single page: the DFD Notation Standard. It doesn’t need to be long. Just clear.
What to Include in a DFD Notation Legend
Use a legend in every diagram. Or better—place it on the first page of your modeling artifact. Include:
  • Notation name: e.g., “Gane & Sarson – 2013 Standard”
  • Element definitions with visual examples
  • Rules for labeling: e.g., “All data flows must be labeled with a noun phrase”
  • When to use alternatives: e.g., “Custom icons are allowed only in diagrams for executives”
Example: A legend in Visual Paradigm can be saved as a template. Apply it to every new DFD. The tool will auto-apply the correct symbols.
Enforcing DFD Symbol Consistency
Enforcement is where most teams fail. They assume that if they pick a notation, it will be used. But without structure, inconsistency creeps in.
Here’s how to enforce DFD symbol consistency in practice:
  1. Use pre-built templates in your modeling tool. Set up a default DFD template with Gane & Sarson or Yourdon symbols. Never start from scratch.
  2. Enable validation rules. Visual Paradigm lets you define rules: “All processes must be rounded rectangles.” If you violate it, the tool flags it.
  3. Integrate legends into every diagram. A small box in the corner with symbols and definitions prevents confusion.
  4. Assign a DFD reviewer. This person checks every diagram for notation compliance before approval.
  5. Use version control. Store your DFD templates and standards in a shared repository. Update them only via peer review.
These steps aren’t heavy. They’re habits. And habits prevent errors.
When Custom Notations Are Acceptable (And When They’re Not)
Custom DFD notations aren’t always bad. But they’re risky.
They’re acceptable only when:
  • The team agrees on the meaning of each symbol.
  • They’re used in limited contexts (e.g., internal dashboards or executive summaries).
  • A legend is attached.
  • They don’t replace the standard notation in technical or audit-critical diagrams.
They’re unacceptable when:
  • They lack a legend.
  • They conflict with industry standards (e.g., using a diamond for process).
  • They’re used across multiple teams without coordination.
Remember: consistency is the goal. If your custom notation makes the DFD clearer and everyone understands it—then it’s working. If not, it’s a failure.
Final Thoughts: The Power of One
Mixing DFD notations undermines trust. It adds friction. It increases rework.
The real cost isn’t in the diagram—it’s in the time lost trying to interpret it.
Choose one notation. Document it. Enforce it. Use templates, legends, and tooling to keep it alive.
When DFD symbol consistency is guaranteed, your diagrams become reliable. Then, they become valuable.
What’s the difference between Yourdon and Gane & Sarson DFD notations?
Yourdon uses rounded rectangles for processes and single-line data stores. Gane & Sarson uses rectangles with circles for processes and double lines for data stores. The symbols differ in shape and imply different conceptual models.
Can I mix Yourdon and Gane & Sarson in the same DFD?
No. Mixing notations confuses readers and creates inconsistency. If you must use both, document the rules thoroughly and apply them only in specific contexts, like executive summaries.
How do I ensure DFD symbol consistency across my team?
Use a shared template in your modeling tool. Create a legend. Assign a reviewer. Enforce rules through validation. Make consistency a team standard, not a personal choice.
Why should I choose one DFD notation over another?
Because consistency reduces cognitive load. A uniform notation allows stakeholders to focus on data flow, not symbol interpretation. Gane & Sarson is widely used in industry; Yourdon is common in academic settings. Pick the one that fits your audience.
Is it acceptable to create custom DFD symbols?
Only if they’re clearly defined and consistently applied. Custom symbols are acceptable in high-level diagrams for non-technical users, but avoid them in design-level DFDs where precision matters.
How can tools help standardize DFD notation?
Tools like Visual Paradigm allow you to set default templates, define validation rules, auto-generate legends, and enforce consistent symbol sets. Use these features to automate consistency and reduce human error.
