Use Case Modeling for Clear Requirements
Geschätzte Lektüre: 8 Minuten 147 Ansichten
Use case modeling isn’t about drawing pretty diagrams—it’s about turning user needs into a shared blueprint for development. Too many teams confuse use case diagrams with high-level flowcharts. The real difference? Use cases describe *behavioral intent* across system boundaries, not just steps. A well-structured use case reveals what the system must do, not how it does it. This distinction is critical: the goal isn’t to document process, but to define *value delivery*.
Over two decades of working with engineering teams has taught me that clarity in requirements reduces rework by up to 60%. When stakeholders and developers speak the same language, misalignment drops. This chapter focuses on how to build use case diagrams that are not just accurate, but actionable—tools that guide design, drive testing, and align teams from day one.
By the end, you’ll be able to define actors with precision, draw system boundaries that reflect true responsibility, and structure use cases that are traceable, testable, and resistant to scope creep.
Defining Actors: Who or What Interacts?
Actors are not roles. They’re external entities that engage with the system—people, systems, or devices. Confusing a user role with a real actor is a common mistake that leads to missing critical interactions.
Ask this: Who or what initiates or receives a service from the system? If it’s not part of the system’s boundary, it’s a candidate actor.
  • Primary Actors—The main users who trigger the main flow of a use case.
  • Secondary Actors—Entities that the system relies on but don’t initiate the use case.
  • System Actors—External systems (e.g., a payment gateway or IoT sensor).
When defining actors, avoid vague labels like “user” or “someone.” Be specific: “Registered Patient,” “Third-Party Payment Processor,” or “Automated Inventory API.” Precision prevents ambiguity downstream.
Common Pitfalls in Actor Definition
  • Using “User” as an actor without specifying type — leads to unclear requirements.
  • Grouping multiple roles under a single actor — fragments responsibilities.
  • Defining an actor that doesn’t interact with the system — adds noise.
Use case diagrams fail when the actors aren’t real participants. Define them early and validate with stakeholders. A single misidentified actor can hide entire workflows.
Establishing the System Boundary
The system boundary is not a visual flourish—it’s a legal and functional boundary. Everything inside is within the system’s responsibility. Everything outside is not.
Think of it as a contract. The system promises to fulfill certain behaviors. If an external entity initiates or receives data, it must be accounted for in the use case.
When drawing the boundary:
  1. Use a rectangle with rounded corners.
  2. Label it with the system name (e.g., “Order Processing System”).
  3. Place all use cases and actors relative to this boundary.
  4. Ensure no use case crosses the boundary unless it’s an interaction with an external system.
Example: In a hospital system, “Patient” is an actor. “Appointment Scheduling System” is the system. “Lab Result Integration” is a use case that interacts with an external lab system. The use case must be connected to the boundary, not the external system directly, unless it’s a sub-system.
When to Use a Separate System vs. a Subsystem
Use Case When to Model as Separate System When to Use Subsystem
Interfacing with a third-party service External system isn’t owned by your team (e.g., payment gateway). Part of the same system with a well-defined sub-domain.
High-level process coordination Multiple systems collaborate in a workflow. One system with modular components.
Keep the boundary consistent. Reuse it across diagrams to maintain alignment. If the boundary shifts between diagrams, your model loses coherence.
Constructing Use Cases: The Power of Storytelling
Use cases are not just bullet points. They’re mini-stories about value. Each one describes a goal, a beginning, and a meaningful outcome.
Structure use cases with the following elements:
  • Use Case Name – Clear, active verb (e.g., “Process Payment,” “Schedule Appointment”).
  • Primary Actor – Who initiates the scenario.
  • Goal – What the user wants to achieve.
  • Preconditions – What must be true before the use case starts.
  • Basic Flow – Main success path, step by step.
  • Alternative Flows – Branches (e.g., failed payment, invalid input).
  • Postconditions – What’s true after completion.
Example: Use Case Name: “Cancel Order”
Goal: Allows a customer to cancel an unshipped order within 24 hours of placement.
Preconditions: Order status is “Pending Shipment,” customer is logged in.
Basic Flow:
  1. Customer selects “Cancel Order” from their order history.
  2. System displays cancellation confirmation.
  3. Customer confirms.
  4. System updates status to “Canceled” and refunds payment.
  5. System sends confirmation email.
Alternative Flow A: Payment not yet processed → System alerts user. Cancellation not allowed.
Postcondition: Order status is “Canceled.” Refund is initiated.
This format ensures traceability and testability. Every step can be validated. Every edge case can be tested.
Use Case Templates: A Practical Checklist
Use this checklist when writing or reviewing use cases:
  • Does the use case name start with a verb?
  • Is the goal aligned with user value—not system capability?
  • Are all actors clearly defined and relevant?
  • Is the basic flow concrete and actionable?
  • Are alternative flows documented for likely exceptions?
  • Can a test be written for each step?
When you can’t answer “yes” to all, the use case is incomplete. Revise before moving to design.
Diagramming with Clarity: Best Practices for Use Case Diagrams
Use case diagrams are not required to be perfect—but they must be unambiguous. A good diagram doesn’t require a legend. It should be readable in under 15 seconds.
Follow these principles:
  • Limit use cases per diagram to 6–8—more than that, and the diagram becomes cluttered.
  • Group related use cases under a package or subsystem when needed.
  • Use generalization only when the inheritance is real (e.g., “Admin” extends “User”).
  • Use dependencies for optional or conditional interactions (e.g., “Generate Report” depends on “Export Data”).
  • Label all relationships—don’t rely on arrows or position to imply intent.
Visual clarity reduces misinterpretation. A poorly drawn diagram leads to assumptions, which lead to defects.
Use Case Diagram: Real Example – Online Store
System: E-Commerce Platform
Actors: Customer, Payment Gateway, Admin
Use Cases:
  • Place Order
  • View Order History
  • Cancel Order
  • Process Payment
  • Manage Products
  • Generate Sales Report
Relationships:
  • Customer → Place Order (association)
  • Place Order → Process Payment (dependency)
  • Admin → Manage Products (association)
  • Admin → Generate Sales Report (association)
This diagram is simple but captures the core workflows. It’s not exhaustive—but it’s a starting point.
From Model to Development: Ensuring Traceability
Use case modeling isn’t an end in itself. It’s the foundation for software development. Each use case should be traceable to:
  • Functional requirements
  • Test cases
  • Design elements (e.g., class diagrams)
  • Code components
Use Visual Paradigm’s requirement linking feature to map each use case to its corresponding test case or component. This ensures nothing is lost in translation.
When you can’t trace a use case to a test, it’s not ready. When a use case isn’t linked to a design element, it’s a risk.
Traceability Matrix: Mapping Use Cases to Tests
Use Case Test Case ID Test Description Status
Process Payment TC-001 Valid credit card: payment completes Passed
Cancel Order TC-005 Cancel after 24h: system blocks action Failed
Generate Sales Report TC-012 Report includes daily totals and categories Passed
Regularly review this matrix. It’s your insurance against missing functionality.
How do I decide between a use case and a user story?
Use cases are better for complex, multi-step processes involving multiple actors or conditional logic. User stories are effective for lightweight product backlog items. Use cases map the full behavior. User stories focus on the outcome.
Can a use case have multiple primary actors?
Yes, but only if both actors are jointly responsible for initiating the use case. For example, in a shared booking system, both the “Traveler” and “Travel Agent” may need to confirm a reservation. Document how their roles interact.
Are use case diagrams necessary for agile teams?
No, but use case thinking is. Agile teams often use user stories, but the underlying behavioral model should still be captured. Use case diagrams help visualize workflow complexity and are valuable for onboarding or stakeholder alignment.
What if a use case is too broad?
Break it into smaller, focused use cases. A use case should describe a single goal. “Manage Order” is too broad. Instead, use “Place Order,” “Update Order,” “Cancel Order,” and “Track Order.” Keep it atomic.
How detailed should use case descriptions be?
Enough to guide implementation. The basic flow should be detailed enough to write testable steps. Include only what’s necessary. Avoid technical jargon. Assume the developer knows the system, but not the user’s intent.
Can use case modeling be automated?
Yes, with tools like Visual Paradigm, you can auto-generate use case descriptions from diagrams. But automation doesn’t replace review. Always validate descriptions for clarity and completeness. Automation enhances speed, not quality.
