From Requirements to DFD: A Practical Workflow
Lectura estimada: 7 minutos 327 vistas
When a model shows a process receiving data but no corresponding input flow in the requirements, it’s a red flag. I’ve seen this repeatedly—not from lack of effort, but from assuming that a flow “must exist” because the process does. The real issue? The data flow wasn’t explicitly defined or mapped during analysis. This is where most models fail silently.
My rule: if a flow appears in the DFD, it must be traceable to a specific requirement. That requirement should explicitly describe data being passed, transformed, or stored. Otherwise, the model is speculative—and will mislead later.
This chapter walks through a proven, field-tested workflow to derive accurate DFDs directly from requirement documents or user stories. You’ll gain a repeatable method that ensures every data flow stems from a verified source, avoiding assumptions and blind decomposition.
Step 1: Extract Functional Elements from Requirements
Start by identifying core verbs in user stories or requirement statements. Look for actions like “process,” “generate,” “validate,” “store,” or “send.” These often map to processes in your DFD.
For example, a requirement like “The system shall generate a monthly report for each department” suggests a process: Generate Monthly Report.
Use this checklist to extract functional elements:
  • Highlight verbs that describe transformation or computation.
  • Identify objects or entities that are acted upon (e.g., “report,” “customer data”).
  • Tag each action with a unique ID from the requirement document.
  • Group similar actions under common processes (e.g., “validate data” and “check eligibility” may belong to “Validate Application”).
Step 2: Identify Data Flows via Input/Output Analysis
For every identified process, ask: What data enters this process? What data leaves it? This is where data flow from requirements becomes critical.
Take this requirement: “The system must accept customer details via a form and validate the email format.”
Here, two flows emerge:
  • Input flow: Customer Data (from External Entity: Customer)
  • Output flow: Validated Customer Data (to Process: Validate Email)
Do not assume flows exist just because a process does. Each flow must be explicitly justified by a requirement.
Use this table to map requirements to flows:
Requirement Process Input Flow Output Flow
The system shall validate the email format. Validate Email Email Data Validated Email
The system shall store valid customer data. Store Customer Data Validated Customer Data Stored Customer Record
Step 3: Define External Entities and Data Stores
External entities represent sources or destinations of data—never internal processes. They are typically people, systems, or organizations that interact with your system.
Common external entity types:
  • Customers – submit forms, receive reports
  • Administrators – manage users, view logs
  • Third-party APIs – supply or receive data
  • Legacy systems – exchange data via interfaces
Data stores hold information over time. They are not active processes—they are repositories. Examples:
  • Customer Database
  • Transaction Log
  • Report Archive
Ensure every data store is referenced in at least one requirement. If not, question its presence. Overuse of data stores is a common error in early-stage modeling.
Step 4: Build Level 0 (Context Diagram) from High-Level Flows
With your core processes, entities, and flows identified, construct Level 0. This diagram shows the system as a single process and highlights key external entities and data flows.
Use this structure:
  1. Place the system as a central process (e.g., “Customer Management System”).
  2. Draw external entities around it.
  3. Connect each entity to the system via data flows that represent the primary exchange.
  4. Label flows with verbs (e.g., “Submit Form,” “Receive Report”).
Example: In a customer onboarding system, flows like “Submit Application” and “Receive Confirmation” are critical to the context diagram.
Do not include sub-processes or data stores at this stage. Keep it simple and high-level.
Step 5: Decompose into Level 1 and Beyond
Now, expand the central process from Level 0 into Level 1. Each subprocess should directly stem from a requirement or functional task.
As you decompose, apply this principle: each child process must consume input data and produce output data. No process can exist in isolation.
Use this decision tree to guide decomposition:
  1. Is the process too complex? Break it into sub-processes.
  2. Are there multiple inputs or outputs? Split into logical steps.
  3. Can this be automated? Consider whether the process should be a system or manual task.
  4. Does every flow in the child diagram have a traceable requirement? If not, pause.
For example, “Validate Application” may decompose into:
  • Check Email Format
  • Verify Identity Documents
  • Confirm Address Validity
Each sub-process should reflect a distinct, well-defined function tied to a specific requirement.
Key Principles for Agile Requirements Modeling
Agile teams often assume DFDs are too formal for sprint-based development. But that’s a misconception. DFDs can be built incrementally and serve as living documentation.
Here’s how to integrate agile requirements modeling with DFDs:
  • Build Level 0 after the first major user story is defined.
  • Decompose Level 1 during backlog refinement for each feature.
  • Review DFDs with each sprint to ensure alignment with actual implementation.
  • Update flows when new requirements emerge, and keep a traceability matrix.
Remember: DFDs aren’t meant to be written once and frozen. They evolve with the system—just like user stories.
These mistakes undermine model integrity and traceability:
  • Creating flows without requirement support: Every flow must be explicitly mentioned in a requirement. If not, it’s an assumption.
  • Over-decomposing processes: Too many levels lead to confusion. Stop decomposing when each process performs a single, atomic function.
  • Forgetting to balance flows: Input flows must equal output flows at each level. An extra flow in the child diagram without a source is a sign of imbalance.
  • Using vague labels: Avoid “data,” “info,” or “details.” Use precise terms like “Customer Payment Record” or “Invoice Validation Result.”
Use the DFD balancing checklist:
  • Does every input flow in a child diagram have a corresponding source?
  • Does every output flow go to an expected destination?
  • Are input and output data types consistent across levels?
  • Do all data stores have at least one write and one read flow?
Conclusion
Turning requirements into DFDs isn’t about drawing diagrams. It’s about thinking in flows. Every process, flow, and store must be traceable back to a verified requirement. This ensures accuracy, alignment, and future maintainability.
By following this workflow, you build models that are not just correct—but trustworthy. The requirements to DFD process becomes a disciplined, repeatable practice, not a guessing game.
Start small. Map one user story. Verify its flows. Expand. Let the model grow with the system—always grounded in what was actually required.
How do I ensure my DFDs are truly traceable to requirements?
Assign a unique ID to each requirement and map it directly to each process, flow, and data store. Use a traceability matrix to verify all elements have a source. No requirement? No traceability.
Can DFDs be used in agile environments?
Absolutely. DFDs can be built incrementally. Start with Level 0 after a release plan, then refine Level 1 during sprint planning. Use them to validate scope and detect ambiguity early.
What’s the best way to handle data flows that aren’t explicitly stated in requirements?
Don’t assume them. If a flow isn’t in the requirements, it doesn’t belong in the model. Ask: “What specific data is being passed?” and trace it. If no requirement supports it, it’s speculative.
How do I balance flows between Level 0 and Level 1?
Recreate the parent process in the child diagram. Ensure all input and output flows from the parent are represented in the child, possibly split across multiple subprocesses. If a flow is missing or extra, revisit the source requirements.
How often should I revise my DFDs during development?
Revisit DFDs during major milestones—sprint reviews, release planning, and system integration. Update when new requirements are added or when implementation reveals model gaps. Treat them as living documents.
Scroll al inicio
