Key Terminology and Concepts Every Beginner Needs
Lectura estimada: 7 minutos 58 vistas
Imagine walking into a meeting where developers, product owners, and ops engineers all speak different versions of the same system. The confusion isn’t about code—it’s about understanding. That’s where the C4 model makes a difference. It’s not about drawing pretty pictures; it’s about aligning teams through shared language.
Many beginners start by copying templates or mimicking diagrams they’ve seen. The mistake? Treating C4 as a rigid notation instead of a communication framework. You don’t need to know every symbol upfront. You need to understand what each level represents and why it matters.
This chapter gives you the essential vocabulary to speak confidently about software architecture. You’ll learn the four core abstractions—system, container, component, code—how they relate, and when to use each. By the end, you’ll be able to sketch a context diagram without overthinking, explain your choices clearly, and avoid the common trap of drawing too much too soon.
Core Abstractions: The Building Blocks of C4
The C4 model isn’t built on arbitrary labels. Each abstraction serves a purpose: to guide attention, reduce cognitive load, and enable structured conversation.
System: The Big Picture
A system is a single, complete application or service that delivers value to users. It’s bounded by clear edges—what’s inside, what’s outside. Think of it as the «black box» view.
For example, a banking app is a system. The users are external, and the system includes everything from the frontend to backend APIs and databases. You don’t need to show internal details here.
  • Represents the entire application as a single unit
  • Defined by who uses it and who it interacts with
  • Used in Level 1: System Context Diagrams
Container: The Building Blocks of a System
A container is a runtime environment where code runs. It’s a logical boundary that houses components. Think of it as the host for your application.
Within a web application system, containers might include:
  • Frontend web app (React, Vue)
  • API service (Node.js, Spring Boot)
  • Database (PostgreSQL, MongoDB)
  • File storage (S3, Blob)
Each container runs in a separate process or deployment unit. The key is to avoid mixing containers with components—this is where confusion often starts.
Component: Functional Units Inside a Container
Components are the functional building blocks inside a container. They’re responsible for specific behaviors or data handling.
Take an order management system. Its containers might be a web API and a database. Inside the API container, components could include:
  • Order Service
  • Payment Processor
  • Inventory Validator
  • Email Notification Handler
Components should be cohesive—each should have a clear, single responsibility. If a component starts handling unrelated logic, it’s a sign it needs to be split.
Code: The Implementation Detail
Code is the lowest level. It shows how components are implemented in actual source files. This level is optional and should be used sparingly—only when it adds real value.
For example, if a team is struggling with dependency issues in a payment module, a code-level diagram showing the actual classes and their relationships can help clarify the problem.
But don’t fall into the trap of diagramming every class. Focus only on high-impact areas. The goal is not to document all the code—but to make the critical architecture visible.
Diagram Types and Zoom Levels
Each level of the C4 model maps to a specific diagram type. These aren’t just categories—they’re tools for communication at different levels of detail.
Shows the system in its environment. Who uses it? What other systems does it connect to?
  • Primary audience: Stakeholders, business teams
  • Focus: External interactions
  • Notation: Boxes for systems, arrows for interactions
Level 2: Container Diagram
Dives into the system’s structure. What containers exist? What technologies are used?
  • Primary audience: Developers, DevOps, architects
  • Focus: Technology stack and boundaries
  • Notation: Labeled containers, with tech names (e.g., “Spring Boot API”) and interaction lines
Level 3: Component Diagram
Breaks down a container into components. What are the major functional parts?
  • Primary audience: Developers, tech leads
  • Focus: Responsibility and dependencies
  • Notation: Rectangles for components, lines showing dependencies
Level 4: Code Diagram (Optional)
Shows how components are implemented. Best for complex systems or critical paths.
  • Primary audience: Developers, reviewers
  • Focus: Specific classes, methods, and relationships
  • Notation: Class diagrams, method-level diagrams
Decision Tree: When to Use Each Level
Not every diagram needs to go to Level 4. The right level depends on your audience and purpose.
Use Case Recommended Level Why
Presenting system to non-technical stakeholders Level 1 Focus on users and external systems
Onboarding new developers Level 2 Shows tech stack and structure
Debugging a complex dependency issue Level 3 Reveals internal logic and flow
Reviewing a critical module design Level 4 Clarifies implementation details
Notation Principles: Clarity Over Complexity
The C4 model uses simple, consistent symbols. Don’t worry about mastering every convention at first—focus on clarity.
  • Use rectangles for containers and components
  • Use double-lined rectangles for systems
  • Use arrows to show interaction direction
  • Label all elements clearly—avoid abbreviations unless widely understood
  • Keep the diagram clean. Remove clutter. Use whitespace.
Remember: A diagram is not a map. It’s a conversation starter. If someone can’t understand it in 30 seconds, it’s too complex.
Common Misconceptions About C4 Terminology
Let’s address a few myths that trip up beginners.
Myth: C4 is a UML variant
It’s not. C4 uses UML-like shapes but doesn’t follow UML rules. For example, you don’t need to show multiplicity or inheritance unless it adds value. The goal is not precision—it’s communication.
Myth: Every part of the system needs to be modeled at all levels
No. Only model what matters. A small microservice might only need a Level 2 diagram. A large enterprise system might benefit from all four levels.
Myth: You must start with Level 1
Not always. If you’re deep in an architecture review, you might begin with a component diagram. The key is to know your audience and purpose.
Best Practices for C4 Model Beginners
These are lessons learned from real projects, not theory.
  • Start with context: Always define the system and its users first. This prevents scope creep.
  • Use consistent naming: “User Management Service” is clearer than “UMS” unless your team agrees.
  • Limit interactions: More than 5–6 external connections make diagrams hard to read.
  • Update iteratively: Don’t wait to perfect a diagram. Share early, get feedback, refine.
  • Document assumptions: Use a legend to explain decisions like “Why is this database in a separate container?”
What is the difference between a container and a component in C4?
A container is a runtime environment (e.g., a web app, database). A component is a functional unit inside that container (e.g., a payment service). Containers group components by deployment and technology.
Can I use C4 model without any tools?
Yes. You can sketch on paper or whiteboards. The model works at any scale. Tools help with consistency and sharing, but they’re not required.
When should I use Level 4 code diagrams?
Only when architectural decisions are hard to understand at Level 3. For example, if a component relies on a complex dependency graph, a code-level view can clarify it.
How do I decide which abstraction level to start with?
Ask: Who am I talking to? If it’s business stakeholders, start with Level 1. If it’s engineers, Level 2 is better. The audience shapes the abstraction.
Are there rules for colors in C4 diagrams?
There are no strict rules. Use colors to group or highlight—but avoid overloading. Stick to 2–3 colors max. Red for critical, blue for services, green for data.
Can I mix C4 with other modeling techniques like BPMN?
Yes. Use C4 for structure and architecture. Use BPMN for workflows. They serve different purposes. C4 answers “what” and “how,” while BPMN answers “when” and “who.”
