Mistake 5: Filling Quadrants With Vague, Generic Statements
Temps estimé :7 minutes 48 vues
Too many SWOT sessions begin with lists that sound impressive but mean nothing. “Good service,” “strong brand,” “innovative team”—these are not insights. They’re noise. I’ve led SWOT workshops across tech, healthcare, and nonprofit sectors, and every time I see these phrases, I know the strategy team is already off track.
Generic SWOT entries don’t help anyone understand what to change, how to act, or why. They create the illusion of progress while hiding real problems. The real issue isn’t the tool—it’s how it’s used.
This chapter shows you how to replace vague language with precise, evidence-backed statements that lead to decisions. You’ll learn to spot weak entries, rewrite them using real data, and build a habit of clarity that turns SWOT from a checklist into a strategic compass.
Why Generic SWOT Entries Fail to Move the Needle
Vague SWOT statements like “strong brand” or “good customer service” are emotionally appealing but strategically useless. They lack evidence, context, and direction.
They don’t tell you what to change. They don’t explain how to measure success. And they don’t help prioritize. In practice, this means teams spend time debating whether “good service” is good enough, instead of fixing what’s actually broken.
These entries also encourage groupthink. When people hear “strong brand,” no one challenges it. No one asks, “What data supports that?” The conversation stalls. Momentum dies.
The Hidden Cost of Vague Language
Imagine a retail team listing “strong brand” as a strength. No follow-up. No evidence. Later, the company loses market share to a competitor with a more focused positioning. The SWOT analysis didn’t warn them. Why? Because “strong brand” was never a signal—it was a placeholder for unspoken assumptions.
Here’s the truth: if a SWOT item can’t be tested, measured, or verified, it’s not a strength. It’s a guess. And guessing isn’t strategy.
From Generic to Specific: The Rewriting Framework
Every strong SWOT item must pass three tests:
  • Is it measurable? Can you track it over time?
  • Is it tied to evidence? Do you have data, feedback, or benchmarks to support it?
  • Does it imply action? Does it point toward a decision, change, or investment?
Use this pattern to rewrite any item:
“[Specific aspect] — [measurable outcome] based on [evidence]”
Let’s apply it to common examples.
Before-and-After Examples
Before: “Good customer service”
After: “Customer service response time under 2 hours — based on 90% of support tickets resolved within 2 hours (Q1–Q2 data)”
This version shows exactly what “good” means, how it’s measured, and what data backs it up.
Before: “Strong brand”
After: “Brand recognition at 72% in target market — based on post-campaign survey (n=500 customers, 2024)”
Now you know what “strong” means. You can compare it to past performance. You can plan to improve it.
Before: “Innovative product team”
After: “Product team introduced 3 new features in Q2 — based on sprint completion rate of 94% and user adoption of 68%”
This links innovation to measurable delivery and impact.
Your Checklist: How to Ensure SWOT Items Are Specific
Before finalizing any SWOT entry, ask yourself:
  • Can I define this in numbers or observable terms?
  • What data or feedback supports this claim?
  • If I removed this entry from the SWOT, would the strategy still make sense?
  • Does this suggest a next step or decision?
  • Would a new team member understand what this means without explanation?
If you can’t answer all of these clearly, the statement is too vague.
Think of this as your specific SWOT examples filter. Use it during brainstorming and review. It’s not about perfection—it’s about accountability.
Common Pitfalls When Writing Clear SWOT Items
Even when teams try to be specific, they often fall into subtle traps.
1. Confusing a Goal with a Strength
“We aim to expand into Europe” isn’t a strength. It’s a goal. A strength is what you already have that helps achieve it.
Fix: “Existing EU compliance team — certified in GDPR and data privacy standards (verified by internal audit, 2023)”
2. Using Subjective Language as Evidence
Phrases like “excellent,” “really good,” or “very strong” are not data. They’re emotional descriptors.
Fix: Replace with metrics. “Excellent support” → “87% customer satisfaction score (CSAT) in 2024”
3. Repeating the Same Idea in Different Words
“Fast delivery” and “quick fulfillment” are synonyms. They dilute focus and waste time.
Fix: Combine into one: “Average delivery under 48 hours — based on 92% of orders fulfilled within 48 hours (Q2 2024)”
How to Train Your Team to Avoid Generic SWOT Entries
Clarity isn’t natural. It’s learned. Here’s how to build it into your process:
  1. Start with a primer. Before the session, share 3–5 clear SWOT examples and 3–5 vague ones. Ask the group to rate them using the checklist above.
  2. Use silent brainstorming. Have everyone write down their ideas individually. This reduces groupthink and forces specificity.
  3. Require evidence tags. In your SWOT template, add a column: “Evidence.” Every item must include a source: “Survey #3,” “Q2 sales report,” “user feedback, May 2024.”
  4. Do a “So What?” check. After listing, ask: “If this item were true, what would we do differently?” If the answer isn’t clear, rewrite it.
These steps are proven. I’ve seen teams go from generic lists to actionable strategy in one session. The difference? They stopped guessing and started measuring.
Final Thought: Clarity Is the First Step to Action
Vague SWOT statements don’t destroy strategy—they mask it. They hide weak performance, obscure real issues, and invite complacency.
But when you replace “strong brand” with “brand awareness at 72% (2024 survey),” you’re not just documenting a number. You’re creating a target. A benchmark. A starting point for improvement.
The goal isn’t to fill quadrants. It’s to build a shared understanding of what’s real, what’s working, and what needs to change. That starts with writing clear SWOT items.
What if our team insists on using “good service” because it’s how we’ve always described it?
Start by asking: “What does ‘good’ mean in this context?” If they can’t define it, the term is meaningless. Use data to shift the conversation. “Last month, 83% of users rated service as ‘good’ or ‘excellent.’ Is that enough? What if we want 90%?”
How do I handle a strength that’s hard to measure, like “skilled leadership”?
Don’t skip it. Translate it: “Leadership team has 10+ years of combined experience in the industry — based on team profiles and project histories.” Pair it with a success indicator: “4 of 5 leadership team members have led product launches.” Now it’s measurable and actionable.
Can I use customer quotes instead of data?
Yes—but only if you can verify them. A single quote isn’t enough. Use: “52% of customer feedback mentions ‘quick response’ — based on 120 NPS follow-up surveys (Q2).” Quotes can support, but evidence must stand alone.
What’s the biggest mistake when trying to be specific?
Overloading with data. Don’t write “Average response time: 1.8 hours (based on 412 tickets, 72% resolved within 2 hours, 91% within 4 hours).” That’s too long. Simplify: “Response time under 2 hours — 72% of tickets, Q2 2024.” Keep it readable.
Should every SWOT item have a number?
No. But every item should be testable. “High employee engagement” isn’t enough. But “93% employee engagement score (2024 engagement survey)” is. If you can’t measure it, ask: “What evidence would prove this is true?”
How often should we review our SWOT items for clarity?
Review during every iteration. When you update your SWOT, re-evaluate each item: “Is this still valid? Is the data current? Is it still specific?” Use this as a habit—not a one-time fix.
