How to Model Capabilities and Interfaces
Temps estimé :7 minutes 51 vues
Imagine a company that’s reorganizing its HR system. Instead of building a monolithic payroll module, the team identifies discrete, reusable functions: employee onboarding, leave management, and performance review. These aren’t just features—they’re capabilities. In SoaML, these capabilities become the foundation for defining service interfaces. The real insight? Capabilities define *what* a system can do, while interfaces define *how* it does it.
Too many teams jump straight into interface definitions without first clarifying what capabilities a system must support. This leads to overlapping, fragile services—often because business intent gets lost in technical syntax. My advice after 20 years: model capabilities first, then map them to interfaces. It’s a shift from thinking in terms of components to thinking in terms of value.
This chapter guides you through SoaML capability modeling and SoaML interface definition with clear steps, real-world examples, and practical modeling decisions. You’ll learn how to align business capabilities with service contracts, avoid common design pitfalls, and create models that scale with your organization’s evolution.
Why Capability-Based Design Matters
Capability-based design is not just a modeling preference—it’s a strategic move toward resilience and reuse. A capability represents a specific business function or operational strength, such as « Generate Payroll » or « Process Employee Termination. »
Unlike technical features, capabilities are meaningful to business stakeholders. They help bridge the gap between IT and business by making service boundaries reflect real-world operations.
Consider a logistics company. Instead of modeling services named “OrderUpdateService” or “ShippingCalculationService,” defining capabilities like “Manage Order Fulfillment” or “Calculate Delivery Estimates” makes the model inherently more understandable and maintainable.
  • Capabilities represent what a system does from a business perspective.
  • Interfaces define how that function is accessed—via operations, message formats, and protocols.
  • One capability may support multiple interfaces, especially in hybrid deployment scenarios.
Mapping Business Capabilities to SoaML Elements
SoaML doesn’t use “capability” as a standalone element in the metamodel—but you can model them effectively using Service and Service Interface constructs.
Here’s how I recommend structuring it:
  1. Start with a Service element representing the core business capability.
  2. Attach one or more ServiceInterface elements to it, each defining a different access pattern.
  3. Use the capability stereotype or a Capability classifier (if supported by your tool) to annotate the intent.
For example:
Service [name="Payroll Processing"]
  └── ServiceInterface [name="PayrollCalculationInterface"]
      └── Operation [name="calculateNetPay"]
          └── input: EmployeeData
          └── output: NetPayResult
This structure makes it clear that Payroll Processing is a capability, and it can be accessed via multiple interfaces—say, one for internal HR systems and another for integration with third-party tax engines.
SoaML Capability Modeling: Practical Steps
Here’s how to build a robust capability model step by step:
  1. Identify core business capabilities from business process models or value streams. Ask: “What value does this service deliver?”
  2. Group related functions under a single capability. Avoid splitting capabilities too finely—granularity should reflect business ownership, not technical convenience.
  3. Define service boundaries around capabilities. Ensure one capability does one thing, and one thing well.
  4. Map capability to service in your SoaML model. Use the Service element to represent the capability.
  5. Define one or more interfaces that expose the capability’s operations.
Use this checklist to validate your model:
  • Does each capability have a clear business owner?
  • Can the capability be independently developed, tested, and deployed?
  • Are interfaces aligned with the capability’s purpose, not just internal implementation?
  • Do interfaces avoid duplicating functionality across services?
Common Pitfalls in SoaML Capability Modeling
Even experienced modelers make these mistakes:
  • Confusing capabilities with technical features: Modeling “process employee data” as a capability instead of “Manage Employee Lifecycle” leads to poor alignment with business goals.
  • Over-granular capabilities: Creating a capability for each step in a workflow (e.g., “Check Employee Status,” “Update Address”) fragments the system and increases communication overhead.
  • Ignoring business ownership: A capability should be owned by a single team. If multiple teams claim ownership, the model will reflect organizational friction.
My rule: If a capability can’t be owned by one team and deployed independently, it’s not a valid capability in SoaML.
SoaML Interface Definition: From Capability to Access Contract
An interface is the public face of a capability. It defines what operations are available, how they are invoked, and what inputs and outputs to expect.
Think of it as a contract between a provider and a consumer. The interface must be stable, discoverable, and reusable across multiple consumers.
Designing Reusable Interfaces
Here’s how to design interfaces that scale:
  • Use standardized operation names (e.g., submitRequest, retrieveStatus) to improve discoverability.
  • Define clear input/output messages using data types that are shared across services.
  • Use versioning to manage changes—e.g., Interface_v2—and avoid breaking existing consumers.
  • Document each operation with a brief description and expected error codes.
For example:
ServiceInterface [name="EmployeeManagementInterface"]
  └── Operation [name="requestLeave"]
      └── input: LeaveRequest
      └── output: LeaveApprovalStatus
      └── exception: InvalidLeaveRequestException
Interface vs. Service Contract: A Key Distinction
It’s tempting to conflate interface and service contract. But they serve different purposes:
  • Interface defines what operations are available.
  • Service contract defines how the service behaves—its policies, security, reliability, and transport details.
In SoaML, the ServiceContract element captures this. It references the ServiceInterface and adds behavioral constraints:
  • Message exchange pattern (e.g., request-response)
  • Security requirements (e.g., OAuth 2.0)
  • Retry policies, time-to-live, and fault tolerance
This separation ensures that interface definition remains stable while contracts can be adjusted for deployment environments.
Capability-Based SoaML Design: A Real-World Example
Let’s model a simple employee onboarding system using SoaML.
Step 1: Identify Business Capabilities
  • Onboard New Employee
  • Assign Workstation and Access
  • Enroll in Benefits Program
Step 2: Map to SoaML Elements
  • Service [name="Employee Onboarding Service"] → represents the top-level capability.
  • ServiceInterface [name="OnboardingInterface"] → defines operations like startOnboardingProcess.
  • ServiceInterface [name="BenefitsEnrollmentInterface"] → for benefits-related operations.
Step 3: Define Interface Operations
  └── Operation [name="startOnboardingProcess"]
      └── input: OnboardingRequest
      └── output: OnboardingReferenceNumber
Now, each interface is tied to a clear capability. The model is not just a technical diagram—it’s a business agreement.
Key Takeaways
Modeling capabilities and interfaces in SoaML is not about notation—it’s about intention. When done well, it fosters:
  • Clearer communication between business and IT.
  • Stronger reusability across systems.
  • Loose coupling between services.
  • Long-term maintainability and evolution.
Remember: capability-based SoaML design is not a one-off exercise. It should be revisited during sprint planning, architecture reviews, or when new business domains emerge.
What is the difference between a capability and a service in SoaML?
A capability is a business function (e.g., “Process Payroll”). A service is the technical implementation of that capability. In SoaML, you model the service to represent the capability, often using the Service and ServiceInterface elements.
Can one capability have multiple interfaces?
Yes. A single capability may support multiple interface types—for example, a REST API and a SOAP endpoint. Each interface defines a different access method, but both serve the same business capability.
How do I avoid interface bloat in SoaML?
Apply the single responsibility principle. Each interface should expose operations tied to one business purpose. If you have 20 operations in one interface, consider splitting it into two or more.
Should I model capabilities in every SoaML diagram?
No. Capabilities are best modeled at the architectural level (e.g., Service Architecture or Participant diagrams). In detailed interface diagrams, focus on operations and message types. Use capability annotations or notes for context.
Can SoaML interfaces represent event-driven capabilities?
Yes. Use ServiceInterface with publish-subscribe patterns. Define operations like publishEmployeeHiredEvent and subscribeToOnboardingEvents. This supports event-driven capabilities like “Notify HR of New Hires.”
How does SoaML capability modeling support microservices?
Each microservice should encapsulate one or more business capabilities. By modeling capabilities first, you ensure service boundaries align with business domains. This reduces cross-cutting concerns and supports autonomous deployment.
