Common Misunderstandings: Why the Two Are Often Confused
Temps estimé :7 minutes 65 vues
Many professionals and students assume SWOT and TOWS are interchangeable. That’s a mistake. The confusion isn’t accidental—it stems from visual similarity, overlapping terminology, and how both tools begin with the same four elements: Strengths, Weaknesses, Opportunities, and Threats. But appearances can be deceiving.
When I first led a workshop with a group of mid-level managers, I asked them to complete a SWOT analysis. They did so with ease. Then I asked them to turn it into a TOWS matrix. Most paused. Some stared at the blank grid. One said, “We already did this.” That moment revealed the root of the problem: treating analysis as action.
Understanding SWOT TOWS confusion begins with recognizing that SWOT is diagnostic, not directive. TOWS is the next logical step—transforming insights into strategy. In practice, mistaking one for the other leads to stagnation. You may have identified weaknesses, but if you don’t ask, “What can we do to leverage this?” or “How do we counter this threat?”, you’ve stopped at diagnosis.
This chapter clears up misinterpretations, unpacks why the tools look alike but function differently, and gives you a clear framework for when to use each—based not on opinion, but on real-world strategic outcomes.
Why SWOT and TOWS Look So Similar
The visual layout is a major contributor to the SWOT TOWS confusion. Both use a 2×2 grid with the same quadrant labels: Strengths, Weaknesses, Opportunities, Threats. But the flow and intent differ drastically.
Think of SWOT as a mirror. You’re reflecting reality—what you have, what you lack, what’s out there, and what might challenge you. TOWS is not a mirror. It’s a compass. It asks: How do I act based on this reflection?
Here’s where people get tripped up: they assume the SWOT grid is complete. But it’s not. It’s a starting point. The real work begins when you ask, “What strategy can I build from this?” That’s where TOWS comes in.
Overlapping Terminology Creates False Equivalence
Strengths and weaknesses are internal to both. Opportunities and threats are external to both. The shared vocabulary gives the illusion of sameness. But the question each tool answers is different.
  • SWOT asks: “What is the current strategic landscape?”
  • TOWS asks: “What should we do about it?”
Confusing them leads to teams spending hours on a SWOT table and then calling it a strategy. That’s not strategy. That’s planning without direction.
The Core Misunderstanding: Analysis vs. Action
Let me be clear: SWOT is not a strategy. It’s an inventory. TOWS is the action plan.
I once worked with a nonprofit that conducted a SWOT analysis for their annual strategy session. They listed 18 opportunities and 12 threats. They spent two hours discussing them. Then, they said, “We’re done.” No strategies were generated. No priorities set. No owners assigned.
What they didn’t realize was that SWOT only answers the question “What?” TOWS answers “How?” and “Who?”
The difference in practice becomes evident when you compare outcomes:
Element SWOT TOWS
Primary Focus Assessment of reality Formulation of strategies
Output Insight Actionable plan
Decision Point What is? What should we do?
This table isn’t theoretical. I’ve used it in over 50 strategic workshops. The transformation from SWOT to TOWS is where real change happens.
Real-World Example: A Retail Chain’s Confused Approach
A regional retail chain completed a SWOT analysis. Their Strengths included strong brand loyalty and loyal customers. Opportunities included e-commerce expansion and rising demand for organic products.
They believed they’d completed strategy. When I asked, “What’s your plan to grow in e-commerce?”, the leader said, “We’ll use our strengths.” That’s not a strategy. It’s a statement of intent.
I guided the team through a TOWS matrix. We asked: “How can we leverage our brand loyalty to drive online sales?” The answer wasn’t “use strengths.” It was: “Launch a customer reward program for online purchases.” That’s actionable. That’s TOWS in motion.
Why Teams Fall Into the SWOT TOWS Confusion Trap
Here are the most common reasons why professionals conflate the two:
  1. They were taught as a single tool. Many textbooks and online resources present SWOT and TOWS together without clarifying the shift in purpose.
  2. The TOWS matrix is often missing. Some teams do SWOT, then stop. They never apply the TOWS structure, leading to a false sense of completion.
  3. Time and resource pressure. In fast-moving environments, teams skip the strategic step and treat the SWOT as a final deliverable.
  4. Lack of facilitation. Without a guide to ask the right questions—like “What strategy emerges from this?”—teams default to description.
These are not flaws in the tools. They’re gaps in execution. The solution lies in deliberate design.
How to Break the Cycle: A Three-Step Shift
When you complete a SWOT, don’t stop. Shift purpose. Use this simple sequence:
  1. Reflect: What insights stand out? What patterns emerge?
  2. Reframe: Turn “We have strong customer loyalty” into “How can we use this loyalty to gain market share?”
  3. Respond: Build a strategy using TOWS—pairing internal strengths with external opportunities, or threats with weaknesses.
This isn’t a new model. It’s a mindset shift. And it’s essential for turning analysis into action.
When to Use Each: A Practical Decision Framework
Let’s address the core question: when should you use SWOT, and when should you go to TOWS?
  • Use SWOT when: You need to assess the current state—especially in early-stage planning, education, or brainstorming.
  • Use TOWS when: You want to generate specific, prioritized actions—especially in strategic planning, project execution, or crisis response.
Consider this: SWOT tells you “We’re behind in digital.” TOWS says, “We’ll partner with a tech startup to develop a mobile app within 120 days.”
It’s not about choosing one over the other. It’s about sequencing them. SWOT first. TOWS second. The difference in practice is clarity of action.
Why are SWOT and TOWS often confused?
They use the same four categories and similar grids, creating visual and conceptual overlap. Without a clear understanding of purpose—diagnosis vs. action—people assume they’re interchangeable.
Is TOWS just a more detailed SWOT?
No. TOWS isn’t a detailed version. It’s a different framework. While SWOT lists factors, TOWS connects them into strategies. One describes reality. The other prescribes action.
Can I skip SWOT and go straight to TOWS?
Not effectively. SWOT provides the foundation. Without it, you risk missing key insights. TOWS builds on SWOT, not instead of it. Skipping SWOT means you’re strategizing with incomplete data.
What if my team doesn’t understand the difference in practice?
Run a side-by-side exercise. Have them complete a SWOT on a simple problem. Then, ask: “What strategy would you build from this?” Use the TOWS matrix to guide the response. The contrast will become obvious.
Do large companies still use SWOT?
Absolutely. But they don’t stop there. The best strategic teams use SWOT for diagnosis and TOWS to drive execution. I’ve seen Fortune 500 firms use both in sequence. The difference isn’t size—it’s process.
Can I use SWOT and TOWS together in one session?
Yes. In fact, that’s ideal. Start with SWOT to understand the landscape. Then move to TOWS to build strategies. This dual approach ensures you’re not just analyzing, but planning.
