Capturing Functions with Activity Diagrams
Temps estimé :8 minutes 129 vues
When a system’s behavior spans multiple subsystems and decision points, the moment to model it accurately is not during integration testing—but at the start of design. That’s where SysML activity diagrams deliver their greatest value: capturing functional logic before implementation begins. Many beginners miss this, focusing instead on component architecture or sequence flows without first mapping out how decisions propagate through a process.
As a systems engineer who’s led model-based redesigns for aerospace and smart device platforms, I’ve seen time and again how incomplete activity modeling leads to logic gaps in control systems—especially when inputs are misclassified or flows are untracked. The key isn’t just to draw “boxes and arrows,” but to model decisions, object flows, and exceptions with intention.
This chapter teaches you how to model system workflows using SysML activity diagrams with full control and object flow semantics. You’ll learn when and how to use actions, control nodes, and object flows to represent not just *what* happens, but *why* and *how* it happens. You’ll walk away with a solid foundation in activity modeling SysML and a working grasp of how to apply it in real projects.
Understanding Activity Diagrams in SysML
Activity diagrams are one of the nine core SysML diagram types. They focus on the flow of control and data through a system’s behavior, making them ideal for modeling processes, workflows, and decision logic.
Unlike sequence diagrams, which emphasize timing and interaction order, activity diagrams prioritize the path of execution—from start to end—with decision points, parallel branches, and exception handling explicitly represented.
Every activity diagram begins with an initial node and ends with a final node. Between them, actions, control flows, and object flows form a structured path that models the system’s functional behavior.
Key Elements of an Activity Diagram
  • Initial Node: The starting point of the activity. Represented as a black dot.
  • Final Node: Marks the end of the activity. A filled circle within a circle.
  • Action: A single step or operation in the workflow. Enclosed in a rounded rectangle.
  • Control Flow: Arrows that represent the sequence of execution. Direction matters.
  • Decision Node: A diamond that splits control into multiple paths based on conditions.
  • Fork and Join Nodes: Represent parallel execution. Fork splits into multiple concurrent flows; join waits for all to complete.
  • Object Flow: Shows the movement of objects (inputs or outputs) between actions. Dashed line with an open arrowhead.
These elements work together to define how a process evolves—not just as a linear path, but as a structured, condition-driven workflow.
Steps to Build a Robust SysML Activity Diagram
Modeling a workflow in SysML isn’t just about drawing; it’s about thinking through the logic. Here’s how to do it right.
  1. Define the scope: What process are you modeling? A user login, a sensor validation loop, a diagnostic routine? Be specific.
  2. Identify the initial and final nodes: Start with the trigger (e.g., “User submits form”) and end with the outcome (e.g., “Access granted” or “Error logged”).
  3. Break down actions: List the core steps—each as a distinct action. Avoid combining multiple tasks into one action.
  4. Model control flow: Connect actions in order of execution. Use decision nodes to model choices (e.g., “Is input valid?”).
  5. Integrate object flows: Link inputs and outputs between actions. For example, “Sensor data” flows from a “Read Sensor” action to a “Validate Input” action.
  6. Handle concurrency: Use fork and join nodes when multiple tasks run in parallel (e.g., “Process data” and “Log event”).
Each step should reflect a decision point, a task, or a data movement—never a vague label like “Do something.” Precision prevents ambiguity.
Example: Validating a User Access Request
Consider a system that validates user login attempts. The workflow involves checking credentials, verifying account status, and logging failed attempts.
[Initial] → [Read Input: Username, Password] → [Validate Credentials?]
                ↓ (Yes)
            [Check Account Status?]
                ↓ (Active)
           [Grant Access → Final]
                ↓ (Inactive)
           [Log Failure → Final]
                ↓ (No)
           [Show Error → Final]
Here, the control flow splits at the validation step. Object flows can show that “credentials” are passed from one action to the next. The diagram reveals both the path and the conditionality.
Mastering Object Flows: The Key to Real-World SysML Flow Example
One of the most misunderstood aspects of SysML activity diagrams is object flow. It’s not just about data—it’s about *what* data, *where* it comes from, and *how* it’s transformed.
Each object flow must connect to an action that consumes or produces an object. For example:
  • “Sensor reading” flows from Read Sensor to Filter Noise.
  • “Validated data” flows from Validate Input to Process Data.
  • “Error message” flows from Handle Exception to Log Error.
These flows are not passive—they define dependencies. If an action lacks an input object flow, it’s either a standalone operation (like “Display Result”) or a design flaw.
Use object flow to make your model traceable. If a requirement says “The system shall validate user input before processing,” then the flow from “Validate Input” to “Process Data” directly supports that requirement.
Best Practices for Object Flow Modeling
  • Always name the object being flowed (e.g., “User Credentials,” not “Data”).
  • Use object flow only when an action depends on an object. Avoid flow for actions like “Check Status” unless they require input.
  • Label flows clearly with object name and possibly a cardinality (e.g., “1 × User Data”).
  • Link object flows to object nodes when needed—especially for complex objects.
  • Use guard conditions on object flows to indicate when a flow is allowed (e.g., “only if valid input”).
Common Mistakes and How to Avoid Them
Even experienced modelers stumble when modeling activity diagrams. These are the most frequent errors—and how to fix them.
Mistake Why It’s a Problem Fix
Overusing control flow instead of object flow Obfuscates data dependencies and reduces traceability. Map inputs and outputs explicitly. Ask: “What object is being passed?”
Using actions without clear inputs/outputs Creates ambiguity and breaks model integrity. Define object flows for every action that takes or produces data.
Ignoring decision node guard conditions Leads to incorrect path selection in simulation. Add guard conditions: e.g., “if input > 0” or “if status = active”.
Forgetting to model exception paths Can cause system failure in real deployment. Add dedicated actions like “Log Error” and “Notify Admin” with control flow.
These aren’t just syntax errors—they’re design flaws that can manifest as runtime bugs or untraceable logic gaps.
Connecting Activity Diagrams to the Broader SysML Model
Activity diagrams don’t exist in isolation. They connect to other SysML diagrams through allocations and requirements.
For example, you can allocate actions in an activity diagram to specific blocks (e.g., “User Authentication Module”) or operations (e.g., “validateCredentials()”). This ensures that functions are not just modeled, but assigned to real components.
You can also link actions directly to requirements. If a requirement states “The system shall reject invalid inputs,” then the “Validate Input” action should be allocated to that requirement.
Use the Allocation relationship to build traceability between behavior and structure. This is where activity modeling SysML becomes truly powerful—not just for design, but for verification, validation, and auditing.
What is the purpose of an activity diagram in SysML?
It models the sequence of actions, decisions, and data flows in a system’s functional behavior. It’s ideal for workflows, process logic, and control flow analysis.
How do I know when to use object flow instead of control flow?
Use control flow for the order of execution. Use object flow when an action requires or produces an object. If an action depends on input data (like “Input: Sensor Reading”), use object flow.
Can I model parallel processes in SysML activity diagrams?
Yes. Use fork nodes to split into parallel flows and join nodes to synchronize them. This is useful for concurrent data processing or multi-threaded tasks.
How do I handle exceptions in an activity diagram?
Model exception paths explicitly. Use decision nodes with conditionals like “if error occurred,” then route to an “Handle Exception” action. This ensures all failure modes are accounted for.
What’s the difference between a SysML activity diagram and a UML activity diagram?
They are nearly identical in syntax. SysML adds constraints and extensions for model-based systems engineering, such as allocation to blocks, integration with requirements, and support for parametric constraints.
Can you show a real-world SysML flow example?
Yes. Imagine a smart thermostat: “Read Temperature” → “Compare to Setpoint” → “If temperature < setpoint, then turn on heater.” The object flow of “current temperature” from the first to second action makes the logic explicit. This is a practical activity modeling SysML example.
