Template Library for Porter’s Five Forces Modeling
Temps estimé :6 minutes 63 vues
When you’re facing a competitive challenge and feel like every insight you gather leads to more questions, it’s time to pause and restructure your thinking. That moment—when confusion sets in—is often the signal that you’re not just analyzing an industry, but trying to decode its underlying structure. The right visual model can cut through noise and reveal where power truly lies.
As someone who’s guided dozens of strategy workshops across sectors—from tech startups to global manufacturing—I’ve seen how a blank canvas can paralyze even seasoned decision-makers. But when you use a proven template, you shift from guessing to seeing. The Porter’s Five Forces diagram template isn’t just a visual aid. It’s a structured way to map competitive intensity and identify where strategy can create real advantage.
This chapter gives you direct access to industry-specific, ready-to-use templates in Visual Paradigm. Each template is built on real competitive patterns, so you’re not starting from scratch. You’re accelerating insight with a framework that’s been tested in boardrooms, investor pitches, and market-entry planning.
Why Use a Pre-Built Diagram Template?
Creating a Five Forces diagram from nothing isn’t inherently wrong—but it’s inefficient when you already know the patterns. Templates save time, reduce errors, and help maintain consistency across teams.
Think of it like using a blueprint instead of designing a house from sand. You still apply your judgment, but you’re not reinventing the foundation.
These templates are not just placeholders. They reflect actual competitive dynamics observed in industries like SaaS, manufacturing, consumer goods, and agriculture. You’ll see the forces adjusted for different market structures—low, medium, or high rivalry—based on real data and case studies.
Key Benefits of Using Editable Strategy Templates
  • Immediate application. Start analyzing today—no setup delay.
  • Team alignment. Shared templates ensure all members interpret forces the same way.
  • Reusability. Adapt for new markets, new products, or new competitors with minimal rework.
  • Visual clarity. Pre-designed layouts guide your thinking and avoid clutter.
Industry-Specific Templates: See the Patterns That Matter
Not all industries face competition the same way. The forces that shape a software company are not the same as those affecting a utility provider. That’s why each template is calibrated for a specific sector.
After two decades of fieldwork, I’ve found that the most effective models don’t just follow a formula—they reflect the actual behaviors of buyers, suppliers, and entrants in a given context.
Available Templates
  • SaaS and Cloud Platforms – Emphasizes switching costs, network effects, and the concentration of key suppliers (e.g., cloud infrastructure providers).
  • Consumer Electronics – Highlights rapid innovation cycles, low buyer loyalty, and the threat of substitution from new product categories.
  • Industrial Manufacturing (B2B) – Focuses on supplier concentration, long-term contracts, and buyer power in procurement-driven markets.
  • Retail (Grocery and Supermarkets) – Shows low differentiation, high rivalry, and buyer dominance due to price sensitivity.
  • Agricultural Commodities – Illustrates low buyer power, high supplier concentration in some regions, and the impact of weather and regulation.
  • Healthcare Services (Non-Pharma) – Captures regulatory barriers, payer influence, and low threat from new entrants due to licensing and infrastructure.
How to Use These Templates
  1. Download the relevant template from your Visual Paradigm dashboard.
  2. Open it in your preferred modeling tool or export to PDF for review.
  3. Replace placeholder text with your company, market, and competitor names.
  4. Assess each force using data from public filings, market reports, or customer interviews.
  5. Assign severity levels (Low, Medium, High) and add brief justifications.
  6. Share the final diagram with stakeholders—no further explanation needed.
Transforming Insight into Strategy
Having a diagram is only the start. The real value comes when you ask: What does this tell me about how to compete?
For example, in the SaaS template, if you see high buyer power and low threat of substitution, the implication isn’t just “buyers are strong”—it’s that you must offer unique value, long contracts, and strong onboarding to retain customers.
On the other hand, if supplier power is high, you may need to plan for vertical integration or dual sourcing. The template doesn’t give you the answers—but it shows you where to focus your investigation.
Comparing Forces Across Industries
Force SaaS Consumer Electronics Agribusiness
Industry Rivalry High (fast innovation) High (brand wars) Medium (commodity pricing)
Supplier Power Medium (cloud vendors, but options exist) Low (many component suppliers) High (local cooperatives, limited processors)
Buyer Power High (enterprise contracts, long-term) High (retailers, price-sensitive users) Low (small farmers, fragmented buyers)
Threat of Entry Medium (high tech barrier, but SaaS lowers startup cost) High (low entry cost, high R&D cost) Low (regulatory, land, infrastructure)
Threat of Substitution High (open source, AI tools) High (smart devices, wearables) Medium (alternative protein sources)
Best Practices for Using Industry Analysis Visuals
Even the best template can mislead if used carelessly. Here’s how to avoid common missteps:
  • Do not assume symmetry. A high force in one industry may be low in another—context matters.
  • Avoid overloading the diagram. Prioritize the two or three forces with the most impact on your business.
  • Update regularly. Markets shift. Reassess every 6–12 months or after major changes (mergers, regulation, tech breakthroughs).
  • Pair with data. Use real metrics—like customer churn rate, supplier concentration ratio, or R&D spend—to justify force levels.
Next Steps: From Template to Tactical Advantage
Using a Porter’s Five Forces diagram template isn’t about ticking a box. It’s about moving from intuition to evidence-based strategy.
Once you’ve completed a template, ask: Where can we defend? Where can we attack? Where are we exposed?
Then, link your findings to business model decisions—pricing, partnerships, go-to-market tactics, or R&D priorities. That’s where templates become more than visuals. They become strategic tools.
Do these templates include real data or just placeholders?
They use real industry benchmarks and patterns. For example, the SaaS template reflects known trends like high switching costs and buyer power from enterprise contracts. But you should always update with your own data—these are starting points, not final answers.
How often should I update my Five Forces diagram?
Reassess at least once per year, or whenever a major market shift occurs—like new regulation, a disruptive technology, or a competitor’s acquisition.
What if my industry isn’t listed?
Start with the closest match—e.g., use the SaaS template for digital services, or the manufacturing template for industrial products. Adapt the forces based on your reality. The structure is what matters most.
Are these templates suitable for presenting to executives?
Absolutely. The visual clarity of a properly filled template makes it easy to communicate complex market dynamics in a single glance. I’ve used these in investor decks and board reviews with success.
Can I share these templates with my team?
Yes. They’re designed for team-based strategy work. Use them in workshops, align on force levels, and build consensus. Just remember: the power comes from discussion, not just the diagram itself.
