Designing Clarity: Naming Conventions and Labeling Best Practices
Many beginners assume that EPC diagrams become readable simply by connecting events and functions in the right sequence. That’s a critical misunderstanding. The real power of EPC lies not in the structure alone, but in the precision of labels. A diagram with ambiguous labels may follow all the rules, but it fails the moment a different stakeholder reviews it.
Over two decades of modeling enterprise workflows has taught me this: clarity isn’t an afterthought—it’s a design principle. Poorly named functions or vague events create confusion that compounds over time, especially in cross-functional or distributed teams. Miscommunication leads to rework, delays, and inconsistent interpretations.
This chapter delivers concrete, field-tested EPC best practices to ensure your diagrams are not just correct, but truly understandable. You’ll learn how to apply EPC naming rules that prioritize consistency, and how process labeling conventions enhance readability across business units. We’ll explore real examples where poor labels caused real business issues—and how the right ones prevented them.
By the end, you’ll have a clear, repeatable framework for creating diagrams that communicate reliably, regardless of who’s reading them.
Foundations of EPC Naming Rules
Start with the Event: Use Active Triggers
Events should be named as active, trigger-based occurrences. Avoid passive, vague, or overly abstract terms like „Process Complete” or „Data Available.”
Use the standard format: Subject + Trigger + State. This structure forces clarity about who or what is involved and when the event occurs.
For example:
- Order Received (good)
- Payment Processed (good)
- Customer Onboarded (good)
- Document Approved (good)
Avoid:
- Process Started (ambiguous)
- Data Sent (unclear what data)
- Task Finished (no context)
Function Naming: Action + Object + Purpose
Functions should reflect specific, measurable actions. They must be verbs in the present tense, followed by the object and, where needed, a clarifying purpose.
Structure: Verb + Object + Optional Context.
Examples:
- Verify Customer Identity
- Generate Invoice
- Approve Purchase Request
- Send Confirmation Email
Not:
- Handle Order (too broad)
- Process Data (vague)
- Do Review (not actionable)
One of my early projects involved a procurement EPC where „Process Request” was used in seven places. After redefining it as „Review Purchase Request” and „Approve Purchase Request,” the team’s interpretation accuracy jumped from 58% to 94% in a validation test.
Standardizing Across Teams
Adopt a Shared Glossary
Even with good rules, inconsistencies arise when teams operate independently. A shared glossary prevents misalignment.
Create a master list of accepted terms like:
- Order → Refers only to customer orders
- Request → Refers to internal purchase or HR requests
- Invoice → Excludes credit memos and pro-forma
Use this glossary during modeling sessions. It reduces ambiguity and streamlines reviews.
Use Consistent Capitalization and Punctuation
Apply a single style across all labels. I recommend:
- Title Case: First letter of each major word capitalized
- No punctuation at the end: Avoid periods or commas
- Use of active voice: „Submit Form” not „Form is Submitted”
This ensures visual consistency, especially when diagrams grow large. It also prevents software tools from misreading terms.
Practical Examples: From Ambiguous to Clear
Let’s examine real-world cases where labeling made a difference.
Example 1: HR Onboarding Process
Before:
- Event: „Employee Hired”
- Function: „Set Up Access”
- Event: „Documents Received”
After:
- Event: Employee Offer Accepted
- Function: Grant System Access
- Event: Onboarding Documents Submitted
Why it matters: „Employee Hired” is a state, not a trigger. „Offer Accepted” is the real event that starts the process. „Set Up Access” became „Grant System Access”—more precise and action-oriented.
Example 2: Order Fulfillment
Before:
- Event: „Payment Made”
- Function: „Check Inventory”
- Event: „Stock Available”
After:
- Event: Payment Confirmed
- Function: Verify Product Availability
- Event: Stock Sufficient for Shipment
Why it matters: „Payment Made” lacks confirmation. „Confirmed” ensures the event only occurs when the payment is validated. „Check Inventory” became „Verify Product Availability” — more aligned with business logic.
These refinements transformed a confusing, high-turnover diagram into a stable, reusable model.
Checklist: Your EPC Labeling Quality Audit
Before finalizing any EPC diagram, run through this checklist:
- ✅ Every event begins with an active verb (e.g., „Order Received”, „Invoice Paid”)
- ✅ Every function is a measurable action (e.g., „Send Email”, „Update Record”)
- ✅ No event or function ends with a period or comma
- ✅ All names use Title Case consistently
- ✅ No ambiguous terms (e.g., „Process”, „Handle”, „Do”) without context
- ✅ A shared glossary is referenced in the model’s documentation
Apply this checklist every time you complete a diagram. It prevents hidden errors that only surface during stakeholder review.
Why Clear EPC Diagrams Matter
Clear labeling isn’t about aesthetics. It’s about accuracy, maintainability, and trust.
When events and functions are precisely named:
- Team members interpret the same flow identically
- Change requests are easier to trace
- Automation systems can map logic more reliably
- Compliance audits become faster and more accurate
I’ve seen teams spend weeks fixing logic gaps that started from poorly labeled functions. A single word—like changing “Approve” to “Approve and Notify”—can resolve inconsistencies that led to duplicate approvals.
Investing in EPC naming rules is investing in process integrity. The effort is minimal; the payoff is systemic.
What are the most common EPC naming rules I should follow?
Use active verbs for events (e.g., „Order Received”). Make functions action-oriented (e.g., „Generate Invoice”). Avoid vague terms like „Process” or „Handle.” Always cap each label at a single, clear action or trigger.
How can I ensure consistency in labeling across multiple team members?
Establish a shared glossary defining key terms (e.g., „Order” vs. „Request”). Enforce a single naming style—like Title Case—and use it in all models. Apply peer review with a checklist focused on label clarity.
Should I use full names or abbreviations in EPC diagrams?
Use full, descriptive names. Abbreviations like „PO” or „INV” may save space but reduce readability. If space is limited, define abbreviations in a legend. The goal is clarity, not brevity.
Can EPC naming rules help with automation or system integration?
Absolutely. Clear EPC labels directly translate into business rules in automation platforms. A function like „Verify Customer Identity” can be mapped to a verification service. Ambiguous labels like „Process Customer” become blockers in integration.
How do I handle events that describe outcomes instead of triggers?
Reframe outcome events into triggers. Instead of „Order Shipped,” use „Shipment Confirmation Received.” The event should be something that triggers the next action. Never name events after results — they’re not triggers.
What if a function involves multiple steps? Should I split it?
Yes. If a function includes more than one action (e.g., „Review, Approve, and Notify”), split it into discrete functions. A single function with multiple verbs often signals a missing sub-process. Use decomposition when needed.
Mastering EPC labeling isn’t about memorizing rules. It’s about cultivating a mindset of precision. The goal is to create diagrams that don’t need explanation—because the label says it all.
