Deep Dive into CMMN Concepts
Estimated reading: 3 minutes 78 views
If you’ve ever struggled to capture a complex, knowledge-intensive process with a rigid flowchart, you’re not alone. Traditional BPMN models often fall short when real-world cases involve unpredictable events, dynamic data, and evolving business needs. This is where CMMN modeling shines—offering a more adaptive and human-centered way to represent real-world decision-making.
This section is where we go beyond surface-level understanding. We’ll explore the core components of the CMMN model—stages, tasks, milestones, and case files—not just as abstract symbols, but as living parts of a case’s journey. By the end, you’ll be able to read, interpret, and design models that respond to real-time context, not just predefined paths.
You’ll see how CMMN elements work together in harmony, how sentries govern transitions, and how case files serve as the backbone of dynamic data. Think of this as your foundation for modeling cases that don’t follow a single path—but adapt when needed.
What This Section Covers
Here’s what you’ll master through four focused chapters:
  • Dissecting the Case Plan Model: Understand the full structure of a CMMN case plan—how stages, tasks, and milestones define a case’s lifecycle and guide its progression.
  • Using Sentries for Event-Driven Control: Learn how entry and exit criteria, event listeners, and sentry conditions allow the model to respond dynamically to business changes, not just time-based triggers.
  • Modeling Case File Items and Data Dependencies: See how data flows through case files, how to manage item references, and how tasks interact with inputs and outputs in adaptive modeling.
  • Milestones and Stages: Structuring Case Progress: Discover how to mark key business checkpoints with milestones and organize work into stages, ensuring visibility and control throughout a case’s life.
  • Identify and apply the key CMMN elements in real-world modeling scenarios
  • Use CMMN sentry conditions to create responsive, event-driven case plans
  • Design robust case plans that reflect actual workflow complexity and data dependencies
  • Structure cases with meaningful stages and milestones for better progress tracking
  • Interpret CMMN models with confidence, even when logic branches unpredictably
  • Apply these concepts in tools like Camunda, Signavio, or IBM BPM without relying on automation
Each chapter builds on the last, creating a cohesive understanding of CMMN notation and its power to represent adaptive work. This isn’t about forcing every case into a straight line—it’s about modeling the human and contextual reality behind each decision. Let’s dive in.
Lên đầu trang
