Hands-On: Creating a Use Case Diagram for an App
预计阅读时间7 分钟 91 浏览
Most beginners start with a simplified version of use case diagrams: just a few actors and use cases connected by lines. But in real projects, this simplicity often leads to missing critical behaviors or misunderstood requirements. I’ve seen teams spend weeks building features only to realize the core user workflows weren’t captured early enough. That’s where a properly structured use case diagram becomes essential.
Today, I’ll walk you through creating a use case diagram example for a simple e-commerce app—using Visual Paradigm for visualization and iteration. You’ll learn how to identify real actors, define meaningful use cases, and validate your model with stakeholders. This isn’t just theory. I’ve used this exact approach in three startup projects, and in each, early modeling saved us 2–3 weeks of rework.
The goal isn’t to memorize rules, but to build a mental framework for how users interact with software. By the end, you’ll have a fully functional use case diagram example you can adapt for your own projects. Let’s begin.
Step 1: Define the System and Identify Actors
Start by clarifying the system boundary. For our e-commerce app, this is the online store: customers browse products, add them to carts, and complete purchases.
Actors are roles, not individual people. They represent external entities that interact with the system. In this case, we have:
  • Customer – the main user who browses, searches, adds items, and checks out.
  • Admin – manages products, orders, and user accounts.
  • Payment Gateway – an external system that processes payments.
Don’t guess. Ask: “Who or what initiates an action?” That’s your actor. I’ve found many beginners confuse roles with job titles. “Cashier” isn’t an actor—only “Customer” and “Admin” are roles that trigger system behavior.
Use Visual Paradigm’s actor icon to place them around the system boundary. This visual separation helps prevent accidental inclusion of internal processes.
Step 2: Sketch Core Use Cases
Now build the functional heart of the app. Use cases describe what the system does from the user’s perspective. Start with high-level behaviors:
  • Browse Products
  • Search Products
  • Add Item to Cart
  • View Cart
  • Checkout
  • Manage Orders
For the admin, add:
  • Add Product
  • Edit Product
  • Remove Product
  • Process Order
Use Visual Paradigm’s use case symbol (a stick figure inside an oval) to place these on the diagram. Group related use cases—like “Browse” and “Search”—to avoid clutter.
Tip: Use active verbs in use case titles. “Checkout” is better than “Checkout Process” because it reflects user intent. I’ve seen teams use passive phrasing like “Order Processing is Initiated,” which confuses both developers and users.
Step 3: Connect Actors to Use Cases
Draw lines from each actor to the use cases they trigger. The Customer connects to all shopping-related actions: Browse, Search, Add to Cart, View Cart, Checkout.
The Admin connects to product and order management tasks. The Payment Gateway is linked only to Checkout—because it’s a system-level interaction, not a user role.
Visual Paradigm automatically draws these lines with arrows pointing from actor to use case. This makes it easy to spot missing connections. If an actor has no use cases, they’re not part of the system.
Double-check: Does every use case have at least one actor? If not, revisit the requirement. A use case without an actor is just a task, not a user-driven behavior.
Step 4: Apply <> and <> Relationships
Now refine the model. Use <> when one use case must happen as part of another.
For example: Checkout includes Apply Discount. The discount isn’t a standalone action—it’s part of checkout.
Use <> when a use case adds optional behavior.
For example: Checkout extends Use Gift Card. Not all customers use gift cards. But if they do, this behavior should be added dynamically.
Visual Paradigm uses dashed lines with a «include» or «extend» stereotype. The <> arrow points from the extending use case to the base one.
Caution: Overusing <> creates complexity. I’ve seen diagrams with 15+ extensions. Keep it simple. Only add <> when the behavior is truly optional and rare.
Step 5: Validate with Stakeholders
Even the best diagram fails if it doesn’t reflect reality. Share the use case diagram with product owners, developers, and testers. Ask:
  • “Does this capture all key user goals?”
  • “Are there any missing behaviors?”
  • “Is anything redundant or unclear?”
One team I worked with missed the “Save for Later” use case. After presenting the diagram, a QA engineer pointed out that users often abandon carts. That behavior was added in the next sprint.
Use Visual Paradigm’s collaboration features to collect feedback directly on the diagram. You can tag team members, comment on specific use cases, and track changes.
Remember: A use case diagram isn’t a final artifact. It’s a living document. Revisit it after each sprint or major feature change.
Key Takeaways
Creating a use case diagram example is more than drawing shapes. It’s about asking: Who uses the system? What do they want to do? How do they do it?
Follow these principles:
  • Use active, user-centric language for use cases.
  • Limit <> and <> to truly reusable or optional behaviors.
  • Always validate with stakeholders—especially non-technical ones.
  • Use tools like Visual Paradigm to iterate fast and collaborate in real time.
With practice, you’ll build models that don’t just look good—they prevent miscommunication and guide development with confidence.
What is the best tool for creating a use case diagram tutorial?
Visual Paradigm offers the most intuitive interface for beginners. It supports real-time collaboration, auto-layout, and exports to PNG, PDF, and SVG. It’s ideal for a beginner use case diagram project because it reduces friction in learning and sharing.
Can I use a use case diagram for a mobile app?
Absolutely. Use case diagrams work for any interactive system—web, mobile, or desktop. The principles are the same: focus on user goals, define clear actors, and model core behaviors. For mobile apps, consider touch gestures as part of use cases (e.g., “Swipe to Delete”).
How do I know when to stop adding use cases?
Stop when every major user goal is captured and no new behaviors emerge from stakeholder feedback. If a use case is rarely used or highly technical (e.g., “Update Database Index”), it may not belong in the use case diagram. Save such details for sequence or class diagrams.
Is it okay to have multiple actors in one use case?
Yes—but only if they’re equally involved. For example, both Customer and Admin might “View Order History,” but their roles differ. It’s clearer to keep them separate unless the behavior is identical for both. Use cases should reflect user intent, not system logic.
How can I link a use case diagram to a sequence diagram?
Start with the use case diagram to define behaviors. Then, for each use case, create a sequence diagram to describe the step-by-step interaction. For example, “Checkout” leads to a sequence diagram showing Customer, Cart, Payment Gateway, and Order System exchanging messages.
What’s the difference between e-commerce use case UML and a feature list?
A feature list is a flat list of functionalities. A use case diagram shows relationships, dependencies, and user roles. It reveals hidden complexity—like which actions require approval, which are optional, and who is responsible. This is why e-commerce use case UML modeling leads to fewer bugs and better alignment with business goals.
