Collaboration Diagram Patterns for Common Scenarios
Geschätzte Lektüre: 8 Minuten 58 Ansichten
“I just need to show how the teams interact.”
That’s the most common phrase I hear from first-time modelers—usually after they’ve drawn a single process diagram with five swimlanes, all connected by message flows.
It’s a sign they’re trying to do too much too soon. They’re not modeling a process. They’re trying to capture a conversation. And if you don’t use the right diagram type, you’ll end up with a visual mess that confuses everyone.
Over the past 20 years, I’ve seen hundreds of collaboration diagrams—some brilliant, most messy. The key isn’t complexity. It’s clarity. And that comes from using the right pattern for the right situation.
In this chapter, I’ll walk you through reusable BPMN collaboration patterns for common business scenarios. You’ll learn how to model order handling with suppliers, customer service escalations, and multi-department approvals—each with a proven structure, clear roles, and consistent message flows.
You’ll also get practical guidance on when to use each pattern, how to avoid common pitfalls, and how to leverage BPMN collaboration diagram templates to accelerate your modeling work.
Why Patterns Matter in Collaboration Modeling
When you model a process, you’re focused on sequence. When you model collaboration, you’re focused on interaction.
That shift in focus changes everything. A single process diagram can’t show who sends what to whom. It can’t clarify ownership. It can’t reveal dependencies across teams or organizations.
BPMN collaboration patterns solve this by standardizing how we represent common interactions. They’re not rigid rules. They’re proven structures that reduce ambiguity and speed up modeling.
Think of them like architectural blueprints. You wouldn’t design every house from scratch. You use standard floor plans—kitchen layouts, bedroom placements—because they work. The same applies to BPMN.
These patterns are not just shortcuts. They’re communication tools. When your team uses the same structure for customer escalations, everyone knows what to expect—no matter who’s drawing the diagram.
Pattern 1: Supplier Order Handling
This is one of the most frequent scenarios in supply chain and procurement. A customer places an order. The supplier confirms, ships, and invoices. The customer receives and pays.
Here’s how to model it cleanly with BPMN collaboration patterns.
Participants:
  • Customer (Buyer) – Initiates the order.
  • Supplier (Seller) – Receives the order, ships goods, sends invoice.
Message Flows:
  • Customer → Supplier: Order Request
  • Supplier → Customer: Order Confirmation
  • Supplier → Customer: Shipment Notification
  • Supplier → Customer: Invoice
  • Customer → Supplier: Payment Confirmation
This pattern is ideal for cross-organization workflows. It clearly separates responsibilities and shows the flow of information without diving into internal steps.
Use this pattern when you need to clarify what the supplier must do, or when integrating with external systems like EDI or procurement platforms.
Pro Tip: Always label message flows with clear, actionable names. “Order Request” is better than “Message 1.” It tells the reader exactly what’s being exchanged.
When to Use This Pattern
  • Procurement processes with external vendors
  • Contractual exchanges between organizations
  • Supply chain visibility and SLA tracking
  • Integration design for B2B systems
Pattern 2: Customer Service Escalation
Customer issues don’t always resolve on the first contact. Escalation is a common flow—especially in support teams.
Here’s a clean way to model it using BPMN collaboration patterns.
Participants:
  • Customer Support (Tier 1) – First point of contact.
  • Technical Support (Tier 2) – Handles complex issues.
  • Management (Tier 3) – Reviews unresolved cases, approves exceptions.
Message Flows:
  • Customer → Customer Support: Service Request
  • Customer Support → Technical Support: Escalation Request
  • Technical Support → Customer Support: Resolution Attempt
  • Technical Support → Management: Escalation for Approval
  • Management → Technical Support: Approval to Escalate Further
  • Management → Customer Support: Final Resolution Approval
  • Customer Support → Customer: Resolution Notification
This pattern shows how responsibility moves across levels. It’s not just about who does what—it’s about when and why.
It’s especially useful when setting up SLAs or designing support workflows in CRM or helpdesk systems.
Trade-off: This pattern can get complex. If you’re modeling it in a tool, consider breaking it into two diagrams: one for the escalation path, another for the resolution workflow.
  • Support or helpdesk processes with tiered response
  • SLA and KPI tracking in service operations
  • Customer experience improvement initiatives
  • Integration with ticketing systems like ServiceNow or Zendesk
Pattern 3: Multi-Department Approval Workflow
Approvals across departments are a classic challenge. Finance, Legal, HR, and Operations all need to review a request before it’s approved.
Here’s how to model it with BPMN collaboration patterns.
Participants:
  • Requester – Initiates the request.
  • Finance Department – Reviews budget and cost.
  • Legal Department – Reviews compliance and risk.
  • Operations Department – Reviews feasibility and timing.
  • Approver (Executive) – Final sign-off.
Message Flows:
  • Requester → Finance: Request for Approval
  • Finance → Requester: Feedback or Rejection
  • Finance → Legal: Request for Legal Review
  • Legal → Operations: Request for Operational Review
  • Operations → Approver: Final Recommendation
  • Approver → Requester: Approval or Rejection
This pattern emphasizes parallel or sequential review paths. You can model it as a sequence (one after another) or as a parallel flow (all departments review at the same time).
Use this pattern when you need to show dependencies, bottlenecks, or decision points across departments.
Best Practice: Always include a “Rejection” path. It’s not enough to show approval. The model must reflect what happens when someone says no.
  • Capital expenditure approvals
  • Policy or contract sign-offs
  • HR onboarding or promotion workflows
  • Project initiation processes with cross-functional input
Pattern 4: Cross-Organizational Contract Negotiation
When two organizations negotiate a contract, the flow isn’t linear. It’s iterative. Offers, counteroffers, revisions, and approvals happen back and forth.
This is a perfect use case for BPMN collaboration patterns—especially when combined with choreography.
Participants:
  • Company A – Initiates the contract.
  • Company B – Responds to the offer.
Message Flows:
  • Company A → Company B: Contract Proposal
  • Company B → Company A: Counteroffer
  • Company A → Company B: Revised Proposal
  • Company B → Company A: Final Acceptance
  • Company A → Company B: Contract Signed
This pattern captures the negotiation loop. It’s not a process. It’s a conversation.
Use this when you’re defining agreements, setting expectations, or designing integration points between partners.
Insight: This pattern works best when paired with a choreography diagram. That way, you can define the exact sequence of messages without revealing internal logic.
  • Vendor or partner onboarding
  • Joint venture or alliance agreements
  • System integration contracts
  • Service-level agreements (SLAs)
Choosing the Right Pattern: A Decision Guide
Not every scenario fits a pattern. But most do. Here’s how to decide.
Scenario Recommended Pattern Why
Order with external supplier Supplier Order Handling Clear buyer-seller roles, predictable message flow
Customer issue not resolved by Tier 1 Customer Service Escalation Shows escalation path and ownership
Approval across Finance, Legal, HR Multi-Department Approval Highlights dependencies and decision points
Contract negotiation between partners Contract Negotiation Models iterative exchange without internal detail
When in doubt, ask: Who is sending what to whom? If the answer involves multiple participants and message exchanges, you’re in collaboration territory.
Best Practices for BPMN Collaboration Patterns
Patterns are only as good as their implementation. Here’s how to get them right.
  1. Use consistent naming. Always label message flows with clear, action-oriented names. Avoid “Message 1” or “Data Transfer.”
  2. Limit participants. More than 5 pools can make a diagram hard to read. Use conversation diagrams to summarize.
  3. Separate concerns. Don’t mix internal process logic with collaboration flows. Use collaboration diagrams for interaction, process diagrams for internal steps.
  4. Reuse templates. Save your patterns as BPMN collaboration diagram templates. Reuse them across projects to maintain consistency.
  5. Validate with stakeholders. Show the diagram to the people involved. If they don’t recognize the flow, it’s not clear enough.
What’s the difference between a BPMN collaboration diagram and a choreography diagram?
A collaboration diagram shows the interaction between participants, with each participant having their own internal process. A choreography diagram focuses only on the sequence of message exchanges—without showing internal logic. Use choreography when you want to define a contract or agreement between parties.
Can I use BPMN collaboration patterns in non-technical teams?
Absolutely. These patterns are designed to improve communication. They help non-technical stakeholders understand who does what and when. The key is to keep the diagram simple and use plain language in message labels.
How do I avoid overloading a collaboration diagram?
Limit the number of pools to 3–5. Use conversation diagrams to summarize complex flows. If a diagram has more than 10 message flows, consider breaking it into smaller views.
Are BPMN collaboration diagram templates reusable across industries?
Yes. The patterns I’ve shared—order handling, escalation, approvals, and negotiation—are universal. You can adapt them to healthcare, finance, manufacturing, or government. The structure stays the same; only the roles and messages change.
Do I need a tool to use BPMN collaboration patterns?
No, but it helps. Tools like Visual Paradigm make it easy to create, save, and reuse templates. They also help maintain consistency across diagrams. But you can sketch these patterns on paper or in any diagramming tool.
How do I know if I’m using the right pattern?
Ask: Does the diagram clearly show who sends what to whom? If yes, you’re on the right track. If not, simplify, clarify, or switch to a different pattern.
