What Is a BPMN Process Diagram?
Geschätzte Lektüre: 9 Minuten 69 Ansichten
When you first see a BPMN diagram with a sequence of shapes and arrows, it’s easy to assume it’s just a flowchart. But a BPMN process diagram is far more intentional. It’s not just a visual aid—it’s a precise, standardized model of how work unfolds inside a single participant, whether that’s a department, a role, or a system.
What sets it apart is its focus: internal workflow. No external messages. No cross-pool interactions. Just the step-by-step logic of a single entity executing a task or series of tasks.
I’ve worked with hundreds of teams trying to map their processes. The most common mistake? Trying to use a process diagram to show collaboration. That’s not wrong—it’s just the wrong tool for the job. A process diagram is the orchestration view. It’s about internal control, not external coordination.
By the end of this chapter, you’ll know how to identify a true BPMN process diagram, what it’s meant to show, and how to model it clearly—without cluttering it with elements that belong elsewhere.
The Core Purpose of a BPMN Process Diagram
Orchestration, Not Choreography
Let’s start with a simple truth: a BPMN process diagram is about orchestration. It defines the internal sequence of activities for one participant.
Think of it as the conductor’s score for a single instrument. The orchestra (the organization) may have many parts, but the process diagram shows only what one player does—and in what order.
This is why it’s called a private process. It’s not meant to reveal how the player interacts with others. It’s about the internal rhythm.
What It’s Not
A BPMN process diagram is not a collaboration diagram. It does not show message exchanges between teams or systems. It does not model interactions with external partners.
It’s also not a choreography diagram. That one defines the order of messages between participants, regardless of internal logic. A process diagram, by contrast, is about what one party does, not what they say to others.
And it’s not a conversation diagram. That’s a high-level summary of communication topics across multiple participants. A process diagram dives deep into one actor’s actions.
Essential Building Blocks of a Process Diagram
Events: The Triggers and Endpoints
Every process begins with an event. This is not just a start symbol—it’s a signal that something has happened. A start event can be a timer, a message, or a manual trigger.
End events are equally important. They signal completion—whether normal, error, or cancellation. I’ve seen teams forget to define end events, leading to models that appear to run forever. Always include them.
Activities: The Work Being Done
Activities are the core of any process. They represent work—manual, automated, or system-based. Use task for a single unit of work. Use sub-process when a group of activities forms a logical unit that can be collapsed or expanded.
Don’t confuse activities with events. An event is a moment. An activity is a duration. A task is something that happens. A start event is when it begins. An end event is when it ends.
Gateways: Decision Points
Gateways control flow. They’re the logic points where choices are made. Use an exclusive gateway when only one path can be taken. Use a parallel gateway when multiple paths must execute simultaneously.
Never use a gateway without a clear business rule. I’ve seen models with gateways that had no condition attached—just a fork in the road with no reason. That’s not modeling. That’s guessing.
Sequence Flows: The Path of Execution
Sequence flows are the lines that connect elements. They show the order of execution. They are always unidirectional. Never use a sequence flow to represent a message.
And never use a sequence flow to cross between pools. That’s a message flow. Mixing them creates confusion and breaks BPMN semantics.
How a Process Diagram Fits Into the Larger BPMN Model
Part of a Multi-View Architecture
A BPMN process diagram is not a standalone artifact. It’s one piece of a larger modeling framework. In a full BPMN model, it sits alongside collaboration, choreography, and conversation diagrams.
Think of it as the internal engine. The collaboration diagram shows how that engine interacts with others. The choreography diagram shows the agreed-upon message exchange pattern. The conversation diagram summarizes the key communication topics.
Each serves a different purpose. The process diagram answers: What does this one participant do?
Executable vs. Descriptive Models
There’s a critical distinction between a descriptive process diagram and an executable one.
A descriptive model is for understanding. It shows the intended flow, even if some steps are manual or undefined. It’s used for documentation, training, or stakeholder alignment.
An executable model is for automation. It includes technical details: service task names, data inputs/outputs, error handling, and timers. It must be compatible with a process engine like Camunda or Activiti.
Many teams start with a descriptive model and evolve it into an executable one. But don’t skip the descriptive phase. You can’t automate what you haven’t understood.
A Real-World Example: Order Fulfillment Process
Step-by-Step Modeling
Let’s walk through a simple but realistic example: an order fulfillment process in a retail company.
  1. Start Event: „Order Received via Web Portal“ (message start event)
  2. Activity: „Validate Order Details“ (manual task)
  3. Gateway: „Is Order Valid?“ (exclusive gateway)
  4. If yes → Activity: „Reserve Inventory“
  5. If no → Activity: „Notify Customer of Error“
  6. Activity: „Generate Shipping Label“
  7. Activity: „Hand Off to Warehouse Team“
  8. End Event: „Order Shipped“ (normal end event)
This is a clean, single-pool process. It shows exactly what the fulfillment team does, from receipt to dispatch. No mention of the customer, the warehouse, or the payment system—because this is about internal workflow.
Why This Structure Works
By keeping the model internal, we avoid unnecessary complexity. The team can focus on their own process without being distracted by external dependencies.
Later, we can link this process to a collaboration diagram that shows how it interacts with the warehouse and customer service teams.
Best Practices for Modeling a BPMN Process Diagram
Keep It Focused
Stick to one participant. If you find yourself adding message flows or cross-pool connections, you’re likely in the wrong diagram type.
Ask yourself: Is this about what one team or system does, or how it works with others? If it’s the latter, move to a collaboration diagram.
Use Lanes Only When Necessary
Lanes divide a process into roles or responsibilities. Use them only when the process involves multiple roles within the same pool.
Don’t use lanes just to organize visually. They represent actual ownership. If a task is owned by “Sales,” “Finance,” or “IT,” then use a lane. Otherwise, keep it simple.
Validate Against BPMN Semantics
Use your tool’s built-in validation. Most BPMN tools (like Visual Paradigm) will flag invalid connections, missing events, or incorrect gateway usage.
Don’t ignore warnings. They’re not arbitrary—they’re based on the BPMN 2.0 specification.
Use Clear Naming
Name your tasks and events descriptively. Avoid vague terms like “Step 1” or “Process.” Instead, use: “Verify Customer Credit,” “Update Order Status,” or “Send Confirmation Email.”
Clear names make the diagram self-explanatory. You’ll save hours of explanation later.
Common Mistakes to Avoid
  • Mixing sequence and message flows: Sequence flows are internal. Message flows are external. Never connect them across pools.
  • Overloading with detail: A process diagram isn’t a system design document. Keep it focused on workflow, not data structures or technical logic.
  • Using process diagrams for collaboration: If you’re showing interactions between departments, use a collaboration diagram instead.
  • Skipping end events: Every process must end. If it doesn’t, it’s incomplete and misleading.
Summary: What Is a BPMN Process Diagram?
A BPMN process diagram is a model of internal workflow for a single participant. It uses events, activities, gateways, and sequence flows to define the orchestration of work within one role, team, or system.
It is not a collaboration diagram. It is not a choreography diagram. It is not a conversation diagram. Each has its place—and each answers a different question.
When used correctly, a BPMN process diagram brings clarity. It makes internal logic visible. It becomes the foundation for documentation, automation, and improvement.
So when you’re modeling a process, ask: Who is doing this? What are they doing? In what order? And how does it end? Answer those, and you’ve built a solid BPMN process diagram.
What is a BPMN process diagram definition?
A BPMN process diagram is a visual model that shows the internal sequence of activities, events, and decisions for a single participant. It defines the flow of work within one role, department, or system, without showing external interactions.
How does a BPMN process orchestration differ from collaboration?
Process orchestration focuses on internal logic—what one participant does. Collaboration diagrams show how multiple participants exchange messages. The process diagram is internal; the collaboration diagram is external.
Can a BPMN process diagram include multiple lanes?
Yes, but only if they represent distinct roles within the same participant. For example, a single department with a “Sales” lane and a “Support” lane is valid. But if you’re modeling interactions between departments, use a collaboration diagram instead.
What’s the difference between a BPMN internal workflow diagram and a collaboration diagram?
A BPMN internal workflow diagram (i.e., process diagram) shows only one participant’s actions. A collaboration diagram shows how two or more participants interact via message flows. The former is about internal control; the latter is about external coordination.
When should I use a BPMN process diagram instead of a choreography diagram?
Use a process diagram when you need to model the internal steps of a single entity. Use a choreography diagram when you want to define the agreed-upon message exchange pattern between participants, without revealing internal logic.
Is a BPMN process diagram always executable?
No. A BPMN process diagram can be descriptive (for documentation) or executable (for automation). The executable version includes technical details like service task names, data mappings, and error handlers. The descriptive version focuses on business logic and flow.
