Modeling Human vs System Tasks
Lectura estimada: 8 minutos 100 vistas
About 8 out of 10 process models I review in the field start with incorrect task types. The problem isn’t complexity—it’s confusion between human and system actions. You can’t automate a task that needs a person. You can’t assign a human to a task that runs on a server. Getting this right from the start saves time, prevents rework, and keeps stakeholders aligned.
BPMN task types define who or what performs an activity. This isn’t just labeling—it’s about communication, automation readiness, and responsibility clarity. In this chapter, you’ll learn to identify and apply three foundational task types: manual, service, and user. You’ll see real examples, understand the logic behind choosing each, and avoid common modeling errors.
By the end, you’ll confidently distinguish tasks that require human judgment from those that run automatically—and know when to combine both. This is where process logic meets reality.
Understanding the Three Core BPMN Task Types
Every activity in a BPMN diagram must be classified. It’s not optional. The task type determines how it’s executed, validated, and often, how it’s automated.
There are three primary task types you’ll use in almost every real-world process:
  • Manual Task BPMN – A task that must be performed by a person. No automation. No triggers.
  • User Task BPMN – A task assigned to a specific role or individual, typically requiring interaction with a system (like a form).
  • Service Task BPMN – A task executed automatically by a system, such as a database query or API call.
These aren’t just visual differences—they represent real-world operational logic.
Manual Task BPMN: The Human-in-the-Loop
Use a manual task when a person must perform an action without system support. The task is not triggered by a system. It’s initiated by a process flow, but the execution depends entirely on human judgment or input.
Example: A manager signs off on a leave request. They read the details, consider the team’s coverage, and decide. No form, no system prompt—just a decision.
Key indicators:
  • No system interface involved.
  • Person performs the task independently.
  • Often used for decisions, approvals, or complex judgments.
Visual cue: A rounded rectangle with a single line at the top, often labeled “Manual Task” or using the default icon.
Tip: Avoid assuming all human tasks are manual. If a person fills out a form, it’s likely a user task.
User Task BPMN: Human Interaction with Systems
A user task is a task assigned to a person, but it involves interacting with a system interface. It’s not just about “being done by a person”—it’s about how that person engages with digital tools.
Example: An employee logs into the HR portal to submit a vacation form. The system presents a form. The person fills it out and submits. This is a user task.
Key indicators:
  • Requires a digital form or interface.
  • Often linked to a role or user.
  • May include due dates, escalations, or notifications.
Visual cue: A rounded rectangle with a small icon of a person, or the “User Task” label.
Why it matters: User tasks are often automated through workflow engines. When modeled correctly, they can trigger system actions like sending emails, updating databases, or creating tickets.
Service Task BPMN: Automated System Execution
Service tasks are performed by software systems without human input. They’re the backbone of automation. These tasks are executed via APIs, scripts, database operations, or third-party services.
Example: After a leave request is approved, the system updates the employee’s leave balance in the HR database and sends a confirmation email. This is a service task.
Key indicators:
  • No human involvement.
  • Often linked to an external system or internal service.
  • May be marked with a service icon or labeled “Service Task”.
Visual cue: A rounded rectangle with a small icon of a gear or cloud, or the term “Service Task”.
Best practice: Always specify what service is being called. In tools like Visual Paradigm, you can name the service (e.g., “Update Leave Balance API”) to improve traceability.
How to Choose the Right Task Type: A Decision Tree
When in doubt, ask these three questions:
  1. Is a person involved? If no—go to step 3. If yes—go to step 2.
  2. Is the person using a system interface (form, portal, app)? If yes—use User Task BPMN. If no—use Manual Task BPMN.
  3. Is the task performed by a system? If yes—use Service Task BPMN.
This simple flow prevents misclassification and ensures your model communicates reality.
When to Use Each: Real-World Examples
Scenario Correct BPMN Task Type Why
A manager reviews a policy and signs off. Manual Task BPMN No system interface; judgment-based.
An employee submits a vacation request via a portal. User Task BPMN Uses a digital form.
An API updates inventory after an order is confirmed. Service Task BPMN System-to-system execution.
A clerk enters data into a spreadsheet. Manual Task BPMN No system interface—just human input.
Notice the pattern: if a human types or clicks, ask whether they’re using a system. If yes, it’s a user task. If not—manual.
Hybrid Tasks: When Human and System Work Together
Some tasks involve both. For example: a user fills out a form, and then the system runs a background check. This is not one task—it’s two.
Never combine manual and service tasks in a single activity. You’ll lose clarity and automation potential.
Instead, split it:
  • User Task BPMN: Submit application form.
  • Service Task BPMN: Run credit check via external API.
This separation makes it clear where human input ends and automation begins—critical for system integration and audit trails.
Common Mistakes and How to Fix Them
Mistakes in task type selection are among the most frequent in early BPMN models. Here’s how to catch them:
  • Calling a user task “manual”: If someone logs in and fills a form, it’s not manual—no system access means it’s manual. Use a user task.
  • Using service task for human decisions: No—service tasks are for automation. A manager’s approval is manual or user task.
  • Overusing manual tasks: They slow processes down. If a task can be automated, model it as a service task and assign it to a system.
  • Ignoring task assignments: A user task should have an assignee or role. A missing assignee leads to confusion during execution.
Best practice: Always validate with a simple question: “Can this be done by a machine without human input?” If yes—service task. If no—then determine if a person uses a tool.
Key Takeaways
BPMN task types are not just visual choices—they’re operational truths. Confusing them leads to miscommunication, failed automation, and stakeholder frustration.
  • Use manual task BPMN when a person acts without system support.
  • Use user task BPMN when a person interacts with a form or interface.
  • Use service task BPMN for automated, system-driven actions.
  • Never combine manual and service tasks in one activity.
  • Always ask: “Who or what performs this?” before placing a task.
Mastering task types is the foundation of trustworthy BPMN modeling. You’re not just drawing shapes—you’re defining execution logic.
Can a manual task be automated later?
Yes, but only if you re-model it as a service task. Manual tasks are defined by the absence of system interaction. If automation is added, the task type must change.
Is a form submission always a user task BPMN?
Yes—any time a person interacts with a digital form, it’s a user task. Even if the form is simple, the interface means it’s not manual.
How do I know if a task is service or user?
Ask: “Does a human perform this?” If yes and they use a system—user task. If yes and no system—is manual. If no—service task.
Can a user task be automated?
Not directly. A user task is always human-initiated. But the activity after a user task—like sending an email or updating a database—can be automated using a service task.
Why use manual task instead of user task when someone is involved?
Because manual tasks imply no system interface. If the person is filling a form, it’s a user task. If they’re reviewing a report and deciding, it’s manual.
What if I don’t know who will do the task?
Use a role (e.g., “Manager”, “HR Specialist”) as the assignee. If no assignee is defined, the task cannot be properly executed in most systems. Always assign a role or user.
