Mistake 2: Defining Too Broad or Too Narrow a Scope
Lectura estimada: 8 minutos 43 vistas
Scope isn’t just a detail—it’s the foundation of whether your SWOT analysis delivers insight or noise. I’ve seen teams waste hours on a SWOT that was too broad, only to realize later they’d missed a critical market trend. I’ve also seen workshops collapse under the weight of a scope so narrow, they ignored the one external force that could’ve reshaped their entire product roadmap.
The key isn’t choosing between broad and narrow. It’s getting the scope right for your purpose. Too broad? You’re analyzing everything and nothing matters. Too narrow? You’re blind to the bigger picture.
This chapter shows you how to define a meaningful SWOT scope—without guesswork. You’ll learn practical rules, real-world examples, and decision aids that help you answer: What belongs in the SWOT? What should stay out? And how to keep the analysis focused, honest, and actionable.
Why Scope Sets the Stage for Insight—or Collapse
Most SWOT failures begin not in the analysis, but in the setup. A misdefined scope distorts everything that follows.
Think of the SWOT matrix as a lens. The scope determines the field of view. If the lens is too wide, you get distortion and blur. If it’s too tight, you miss context and risk. The right scope focuses attention on factors that truly matter for your decision.
Here’s the trap: people assume the scope is obvious. They start with “our company” or “our product” without asking: What’s the real strategic question? That’s where the problem begins.
Defining SWOT scope is not a formality. It’s the first strategic act in your analysis. Get it wrong, and the best-laid strengths and opportunities become irrelevant.
Too Broad: When SWOT Becomes a Dumping Ground
I once facilitated a SWOT session for a mid-sized SaaS company. The team started with “the company” as the scope. Within minutes, their list included: “strong leadership,” “high employee turnover,” “growing market demand,” and “regulatory uncertainty.”
By the end, the matrix had 40+ items. The strengths section listed “good culture” and “innovative team.” The threats quoted “global economic instability” and “new competitors.” There was no focus, no clarity, and no actionability.
This is a textbook case of too broad SWOT analysis. The scope was so large, it absorbed everything and nothing stood out. The team spent 90 minutes analyzing factors they couldn’t possibly act on.
Too broad SWOT analysis often stems from a desire to be comprehensive. But comprehensiveness without focus is noise. It distracts from the real strategic questions.
Too Narrow: When You Miss the Real Threats
Now consider a product team that ran a SWOT for a single feature—“the new checkout flow.” Their scope was so narrow that they didn’t consider competitor behavior, changing customer expectations, or broader platform shifts.
They listed “fast implementation” as a strength. “User feedback is positive” as an opportunity. But they missed the threat: “major competitors are rolling out one-click checkout with AI-driven personalization.”
That threat wasn’t in their SWOT because it wasn’t tied directly to their feature. But it was real. And it could’ve derailed their launch.
Too narrow SWOT analysis creates blind spots. It assumes the boundaries are self-evident. But strategic risks often emerge at the edges of what you’re analyzing.
Here’s the reality: a SWOT should reflect the strategic question—not the default. If you’re deciding whether to launch a product, your scope should be the product. If you’re evaluating a market pivot, the scope should be the market. Not the company. Not the team. The decision context.
Rules of Thumb for Setting the Right SWOT Scope
Let’s move from theory to practice. The goal isn’t to have a perfect scope on the first try. It’s to have a scope with a clear purpose and defined boundaries.
Use these rules to guide your defining SWOT scope process.
Rule 1: Anchor to a Strategic Question
Ask: “What decision are we trying to inform?” The answer shapes the scope.
Examples:
  • “Should we launch this product in Germany?” → Scope: the product in the German market.
  • “How do we improve customer retention?” → Scope: customer retention strategy.
  • “Can we restructure our sales team?” → Scope: the sales team’s performance and structure.
Without this anchor, the scope drifts. With it, you stay focused.
Rule 2: Limit the Scope to One Decision Unit
Don’t mix levels. A SWOT for a company-level strategy shouldn’t include details about a single product’s user interface.
Ask: “Is this factor relevant to the decision at hand?” If yes, include it. If it’s too granular or too high-level, it doesn’t belong.
Think of it as a single layer of analysis. Not too deep. Not too high.
Rule 3: Use the “So What?” Test
For every item, ask: “If this factor changes, does it impact our decision?”
If the answer is “no,” it’s likely out of scope.
This test helps filter noise. It also forces you to think critically about relevance.
Rule 4: Define In-Scope and Out-of-Scope in Writing
Before the session, write a short statement: “This SWOT covers [X] in the context of [Y]. The following are excluded: [Z]”
Examples:
  • “This SWOT analyzes the new mobile app version 2.0, including user adoption and feature performance. It does not cover internal team dynamics or budget approvals.”
  • “This SWOT focuses on the customer support function in the EMEA region. It does not include product roadmap changes or revenue forecasts.”
Having this written boundary prevents drift. It gives the team a shared reference point.
Practical Example: Company-Level vs. Product-Level SWOT
Let’s compare two SWOTs for the same company: a digital health platform.
SWOT Type Scope Strengths Threats
Company-Level Entire organization Strong brand recognition, diversified revenue streams Regulatory pressure from new healthcare laws
Product-Level (App) Mobile app user experience High user retention in early access group Competitor launching AI-powered symptom checker
Notice the difference? The company-level SWOT includes broad, high-level factors. The product-level SWOT focuses on specific user behavior and competitive innovation.
Both are valid. But they answer different questions. The company-level SWOT might inform a merger strategy. The product-level SWOT guides feature development.
Choosing the wrong scope is like using a ruler to measure the ocean. The tool is right, but the job is impossible.
Quick Checklist: Is Your SWOT Scope Right?
Use this checklist before your next session:
  1. Have you identified a clear strategic question?
  2. Is the scope focused on one decision unit (team, product, market, project)?
  3. Have you defined what’s in and out of scope in writing?
  4. Can you explain why each item in the SWOT matters to your decision?
  5. Would a competitor or customer recognize the relevance of this scope?
If you can answer “yes” to all five, your scope is likely sound. If not, go back and redefine.
How do I know if my SWOT scope is too broad?
If your SWOT includes items that don’t directly affect your decision, or if you have more than 10–12 entries per quadrant, it’s likely too broad. Ask: “Could this factor change the outcome of my decision?” If not, it’s out of scope.
Can a SWOT scope be too narrow to be useful?
Yes. If your scope excludes external trends or competitor actions that affect your decision, you’re at risk of missing critical threats or opportunities. A scope is too narrow when it isolates a factor from the broader environment.
Should I run separate SWOTs for different levels (company, product, project)?
Yes—when the strategic question differs. A company-wide SWOT is for long-term strategy. A product-level SWOT supports tactical decisions. Never mix them in one matrix. They serve different purposes.
Can I use the same SWOT scope for multiple decisions?
Only if the decisions are closely related and share the same strategic context. For example, a SWOT for “expanding into Latin America” can inform both pricing and marketing decisions. But don’t reuse it for unrelated decisions like internal restructuring or new hires.
What if stakeholders disagree on the SWOT scope?
Disagreement is common. Use the strategic question as the tiebreaker. If stakeholders still disagree, run a lightweight risk assessment: “What happens if we ignore this factor?” The factor with higher impact should be included.
How often should I revisit the SWOT scope?
Revisit the scope when your strategic goal changes, after major market shifts, or when you’re updating your SWOT for the next cycle. The scope should evolve with your context—not remain static.
